Fast Idle and Automatic Choke adjustment. - El Camino Central Forum : Chevrolet El Camino Forums
Old 01-24-2013, 01:29 PM
Dimitri13's Avatar
Dimitri13 Dimitri13 is offline
Motor Mouth
Year: 1973
Model: El Camino SS
Region: 20(HI)
NECOA #: 23291
Dimitri13 will become famous soon enough
Default Fast Idle and Automatic Choke adjustment.
Hey guys, I finally got my manual, but the directions for both of these are a bit unclear to me as I've never done them before on cars. Well, I've never done either of them on bikes either because the carbs on my bike are ooooold and very basic.
It's a quadrajet M4MC.
Does anyone have a walkthrough, hopefully with detailed pictures and explanations?
Thanks in advance.
1977 El Camino Classic - Acquired 1/3/13
Build thread:
1973 El Camino SS - Acquired 4/13/13
Old 01-24-2013, 03:14 PM
BillyJack's Avatar
BillyJack BillyJack is offline
Year: 1987
Model: Conquista
Region: 3 (DE,NJ,PA)
NECOA #: 13628
BillyJack will become famous soon enough
Since I'm at work and not close to a manual, I can't quote you fast idle specs. Many, many years ago, my late father, a lifelong auto mechanic and service manager taught me some basics of choke adjustment that have served me well for years.
Set the choke thermostat so the choke blade is just barely closed at 60-70 degrees ambient temperature.
Using a drill bit or allen wrench as a gage, adjust the primary vacuum break until it pulls the choke open 1/8 inch. If that particular carb has a delayed secondary vacuum break, adjust it to open the choke 1/4". That will put you in the ballpark. Once you've put it through a few cooldown and drive cycles, adjust from there in small increments depending on driveability characteristics.
Bill
Old 01-25-2013, 08:11 PM
Dimitri13's Avatar
Motor Mouth
Year: 1973
Model: El Camino SS
Region: 20(HI)
NECOA #: 23291
Alright guys, I figured out my choke issue. I had the tang of the thermostatic coil outside of the slit where it goes. My issue now is (possibly) the fast idle. It idles high like it should in Park (around 13-1500 RPM), but when I put it in gear, it'll slow down to very slow, like 3-400 RPM (I don't have a tach to check atm). And no amount of feathering the throttle would fix it, and any revving would cause it to stumble and die. I've tried adjusting both the fast idle and regular idle screw, but no amount of adjustment in either direction would help. It was so bad that putting it in drive to trying and scoot it up in the driveway (it's a very slight incline) would cause it to stall out immediately.
I'm pretty fed up with it and may just get a Mountain Man carb, but I'd realllllly like to fix this issue.
You may not post new threads
You may not post replies
Automatic Choke on V6 JimIsbell Engine Topics 11 02-04-2012 08:42 PM
Idle Too Fast When In Gear El_Ron84 Engine Topics 14 09-29-2011 06:46 PM
Cold start-fast idle too fast - where is adjustment jjx Engine Topics 2 01-07-2006 03:37 PM
fast idle cam??????? merc62 Engine Topics 3 08-17-2005 10:28 PM
Choke Adjustment gcooley Engine Topics 1 12-08-2003 09:51 AM
