New 2004r Tranny - El Camino Central Forum : Chevrolet El Camino Forums
Old 01-24-2013, 09:39 PM
RTT's Avatar
RTT RTT is offline
Year: 1984
Region: 18(CA)
NECOA #: 20475
RTT will become famous soon enough
Default New 2004r Tranny
Drove my 84 ELKY today for the first time with the new overdrive tranny. It is awesome! Has a mild shift kit and shifts are nice and positive but not overly aggressive. Downshifts are hardly noticeable. She hits 4th at about 50mph. I like the fact that it revs higher between shifts than the old 250c did. That old tranny almost immediately shifted into second gear. not allowing the motor to start making power. I really notice the deficiency of the stock brakes now as this tranny in overdrive has less rolling resistance. I got 12 mpg before. It will be interesting to see how much improvement. The crossmember had to be modified a little but the drive shaft bolted right up. It has a two year unlimited mileage warranty. Cruising 80 mph is no problem now!
RTT
Old 01-24-2013, 09:50 PM
HKDUP87's Avatar
HKDUP87 HKDUP87 is offline
Year: 1987
Model: Conquista
Region: 18(CA)
NECOA #: 18458
HKDUP87 is a glorious beacon of light
Garage
Great glad your happy with it I thought something maybe be wrong and was taking longer than expected.
I have learned to never characterize any of my cars as fixed....they are just temporarily between malfunctions. .....Dan ( old_coot)
Old 01-24-2013, 09:53 PM
1980SteelBeast's Avatar
1980SteelBeast 1980SteelBeast is online now
Senior Member & Belton Committee Member
Year: 1980
Region: 13(TX)
NECOA #: 16503
1980SteelBeast is of outstanding character
Never had OD in my elco but im sure its nice to have a good 2004r
Steel Beast
"I don't drink and drive,I pull over and sip!"
80 El Camino 6.3L
Old 01-25-2013, 04:41 AM
camox2343's Avatar
camox2343 camox2343 is offline
Junior Member
NooB
Year: 1980
Region: 6 (FL)
NECOA #: 21916
camox2343 will become famous soon enough
Garage
My 1980 el camino came with a 2004r when my son and I bought it. The speedometer does not work and I found out the driven gears are broken. The car came with a brown 26 tooth gear with a metal stem. After looking around found the part number is GM 25502669 but have not been able to find it anywhere. Any suggestions where I could buy it? Or could I replace it with something else? Not sure what size rear differential I have but the car still has the stock 14" inch tires so I believe its stock. Thanks
Old 01-25-2013, 09:47 AM
mrblanche's Avatar
mrblanche mrblanche is offline
Year: 1986
Region: 13(TX)
NECOA #: 21555
mrblanche has a spectacular aura about
Did you install any sort of lockup kit?
Old 01-25-2013, 10:45 AM
TrannyMike's Avatar
TrannyMike TrannyMike is offline
Deputy Director, Region 18
Year: 1985
Region: 18(CA)
NECOA #: 18805
TrannyMike is of outstanding character
Quote:
I just gave the part number to my supplier to cross reference it to an aftermarket number. He may have it. I'll know in a little while and let you know ASAP.
Mike
Old 01-25-2013, 12:55 PM
RTT's Avatar
RTT RTT is offline
Year: 1984
Region: 18(CA)
NECOA #: 20475
Yes, It has a lock up that kicks in at highway speeds.
RTT
  #8
Old 01-25-2013, 02:49 PM
Jack_K's Avatar
Jack_K Jack_K is offline
Site Contributor
Year: 1980
Model: Conquista
Region: 13(TX)
NECOA #: 18056
Jack_K will become famous soon enough
Look here
http://www.bowtieoverdrives.com/cata...AT&CATID=DA1A2
And here for cheaper price
http://www.gmpartsgiant.com/parts/gm-gear-25502669.html
  #9
Old 01-25-2013, 02:53 PM
Wayne Parrish's Avatar
Wayne Parrish Wayne Parrish is offline
Silver Contributor
Year: 1986
Model: El Camino SS
Region: 5 (NC,SC)
NECOA #: 19316
Wayne Parrish has a spectacular aura about
RTT, You'll really love that trans when you pass the gas pumps ! I love mine and wondered what shift kit you're using ? I'm using a B&H lockup kit thats variable from 30-90 mph,they say, but keep it at about 45-48 mph . What rear end gear are you running ? WP
  #10
Old 01-25-2013, 02:56 PM
TrannyMike's Avatar
Year: 1985
Region: 18(CA)
NECOA #: 18805
I'm glad it all worked out for you!
  #11
Old 01-25-2013, 06:16 PM
RTT's Avatar
RTT RTT is offline
Year: 1984
Region: 18(CA)
NECOA #: 20475
It was rebuilt by a father and son shop in business for 42 years! My rear gear is a 3.08 posi. Here is a list of the new parts....
Master overhaul kit
New torque converter
Filter
New Int. band
New Planetary Front and Rear gears
Direct Housing
5 steels
2 Accum w/seals
bushing kit
Roller clutch
case connector
Superior Shift kit
TV cable
Dust Cover
New Trans Mount
Modified Crossmember
Warranty 24 months unlimited miles
Cost about what TrannyMike said it would.
RTT
  #12
Old 01-25-2013, 06:17 PM
RTT's Avatar
RTT RTT is offline
Year: 1984
Region: 18(CA)
NECOA #: 20475
According to my I-phone GPS speedo is dead on!
RTT
  #13
Old 01-25-2013, 07:21 PM
TrannyMike's Avatar
Year: 1985
Region: 18(CA)
NECOA #: 18805
I used to be a Transgo only guy. Then another builder I know talked me into running a Superior kit in a 4R70W Ford trans in an F150. I was impressed and now use both Transgo and Superior. I have a Superior kit in my 2004R and love it. I'm sure you'll be happy with yours for a long time!
  #14
Old 01-25-2013, 08:12 PM
Keyser Sose's Avatar
Keyser Sose Keyser Sose is offline
Year: 1983
Model: El Camino SS
Region: 8 (OH,WV)
NECOA #: 15853
Keyser Sose is a name known to all
That Superior kit is what HKDUP has in his too. I know because I put it there!
WHEN YOU KNOW WHAT THE MAGICIAN KNOWS, IT'S NOT MAGIC ANYMORE!
  #15
Old 01-25-2013, 08:28 PM
HKDUP87's Avatar
Year: 1987
Model: Conquista
Region: 18(CA)
NECOA #: 18458
Garage
Now it's time to hook up with other members for a drive
You may not post new threads
You may not post replies
3rd gen th-350 to 2004r fasst450 Transmission & Drive line 27 10-02-2012 05:12 AM
2004r texaselky Transmission & Drive line 14 11-22-2010 05:05 PM
700R4 or 2004R?? elcamino74guy Transmission & Drive line 16 07-04-2008 10:05 PM
2004r 406gbody Transmission & Drive line 3 11-07-2005 12:44 PM
Swap 2004R to ? 350/400 thebugbox Transmission & Drive line 18 01-20-2004 06:28 PM
