Ethanol safe? - El Camino Central Forum : Chevrolet El Camino Forums
Old 01-27-2013, 04:34 PM
pbouker's Avatar
pbouker pbouker is offline
Member
Loose Nut
Year: 1986
Region: 14(AR,LA,MS)
NECOA #: 20966
pbouker will become famous soon enough
Garage
Question Ethanol safe?
Hey everyone
I'm not an ethanol fan by any means but the old stuff is getting hard to find.
Questions is:
Is ethanol safe to use long term on my '86 305?
Thank you all
Old 01-27-2013, 04:37 PM
Mr.NastyTimes_86_eLky's Avatar
Mr.NastyTimes_86_eLky Mr.NastyTimes_86_eLky is offline
Year: 1986
Model: El Camino SS
Region: 6 (FL)
NECOA #: 21911
Mr.NastyTimes_86_eLky will become famous soon enough
itll burn.. ethanol just doesnt burn clean.. alot of carbon build up.. but what can you do?
Old 01-27-2013, 05:10 PM
69 SS396's Avatar
69 SS396 69 SS396 is offline
Silver Contributor
Year: 1969
Model: El Camino SS
Region: 6 (FL)
NECOA #: 19132
69 SS396 has a spectacular aura about
Garage
Not as many beety you's as gasoline but wont really hurt much as long as you dont let your car sit for very long.
When it sits it tends to sludge up and clog things. Also the rubber seals in older fuel systems dont care for it either.
Cheers, Sean
Proud owner of "Misty Meaner" 1969 Elky SS
Yes Terry, you do need another El Camino
Old 01-27-2013, 05:14 PM
LOCKJAW's Avatar
LOCKJAW LOCKJAW is online now
Year: 1964
Region: 6 (FL)
NECOA #: 19368
LOCKJAW is just really nice
Garage
Sure is ironic..half the world is starving.. we are converting food into fuel for our vehicles while huge deposits of oil are waiting to be pumped out of the ground. We don't have a dependence on foreign oil..we have a dependence on idiot politicians.
To Err Is Human, To Forgive Is Divine...Neither Is Marine Corps Policy!
It's hard to function while constantly doubting the validity of my previous thought.
1964 restomod. Wht/red, ZZ4 w/ mods, Muncie , QFT, Hookers, Flowmasters.
Old 01-27-2013, 05:41 PM
mrblanche's Avatar
mrblanche mrblanche is offline
Year: 1986
Region: 13(TX)
NECOA #: 21555
mrblanche has a spectacular aura about
Well, as far as "safe" is concerned, if you mean for the environment, it's much better than...what was it, MBTA that it replaced? That stuff is poison. Ethanol can be safely ingested in moderate amounts, as you may know.
Now...as to the sense of making it out of corn, and all that sort of thing, that's up to the debaters to debate. Mostly it's made out of corn that would have been used as cattle feed. The cattle can't digest the sugar in it, and that's what the ethanol is made from. It's just as good for cattle feed after it's "spent" as it was before. In fact, a very popular cattle feed. If we made it out of something that wasn't food, that would be smarter.
Now, as far as your car is concerned, 5% probably won't be a problem. If you put a pint of dri-gas in your tank with 10 gallons of gas, that would be a little less than 3%. But the old hoses and carb parts and mechanical fuel pump parts, if they're original, could be affected.
You COULD put a blower on and run it on E85. About 105 octane for 10% less than regular gas.
I'm surprised there's any move at all to put more ethanol in the gas. The subsidies for ethanol production expired last year, and all the "conspiracy under every rock" types were sure that that was the only reason ethanol could even compete in the marketplace. Guess they were wrong.
carlfan's Avatar
carlfan carlfan is offline
Year: 1978
Model: Conquista
Region: 7 (AL,GA,TN)
NECOA #: 20575
carlfan will become famous soon enough
Garage
You got it right Lockjaw!
78 conquista 350 with turbo 350
12 Camry SE
11 avalon
Old 01-27-2013, 06:19 PM
WhisperPC WhisperPC is offline
Year: 1973
Model: El Camino SS
Region: 18(CA)
NECOA #: 5463
WhisperPC will become famous soon enough
No to the first part. The sugar and starch are converted to ethanol. The protein is left behind after the brewing is done. I thought a Marine would know something about the brewing process.
As for the second part, unfortunately it's far too close to the truth for comfort
  #8
Old 01-27-2013, 07:47 PM
Roy!'s Avatar
Roy! Roy! is offline
Year: 1973
Region: 5 (NC,SC)
NECOA #: 20077
Roy! will become famous soon enough
I use non-ethanol in my Durango & Toyota - costs about 10% more - I save about 15% in gas mileage - you do the math! Also both vehicles run better/idle lower. I agree about growing an inferior fuel substitute instead of food on US farms
  #9
Old 01-28-2013, 04:54 AM
Lostinwisc's Avatar
Lostinwisc Lostinwisc is offline
Motor Mouth
Year: 1974
Region: 10(IL,MN,WI)
NECOA #: 19635
Lostinwisc will become famous soon enough
The stuff is just great for destroying 2 stroke engines---talk to the people who survice boats or snowmobile engines ... it just ruined a carb on my 460 rat rod engine (let it set in the carb for aprox 6 months ) my carb guy tried to rebuild it..told me to throw it in the can.
  #10
Old 01-28-2013, 04:58 AM
aeilenstein's Avatar
aeilenstein aeilenstein is offline
Year: 1977
Model: El Camino Classic
Region: 12(MO,OK,KS)
NECOA #: 22058
aeilenstein is a jewel in the rough
Ethanol draws water. So if you don't use the 91 or 93 ethanol-free octane, like PhillipsConoco uses, then you need to make sure you drive your car often. You'll be dealing with both sludgy buildup and possibly rust issues.
I purchased my ElCamino about 2 years ago, and for about a year and a half of driving it, the bottom of my carburetor was getting filled with deposits the ethanol was pulling from the old fuel lines (car was not driven previously). This continually made my Quadrajet flood when the deposits built up on the needle and seat.
  #11
Old 01-28-2013, 05:34 AM
FIRST ELKY 4 ME's Avatar
FIRST ELKY 4 ME FIRST ELKY 4 ME is offline
MORE IDEAS THAN MONEY!
Year: 1981
Region: 1 (NY)
NECOA #: 14415
FIRST ELKY 4 ME has a spectacular aura about
Hard to find ethanol free gas in these parts.
'81 El Camino
'70 Skylark 3
50 (2nd Owner)
  #12
Old 01-28-2013, 08:19 AM
87next2last1's Avatar
87next2last1 87next2last1 is offline
Year: 1987
Model: Conquista
Region: 6 (FL)
NECOA #: 16317
87next2last1 is a glorious beacon of light
Garage
Here is a list of Ethanol-Free gas stations !!
Just click on your State !
http://pure-gas.org/index.jsp?
1987 EL Camino Conquista 4.3L Daily Driver (My Car)
1984 EL Camino SS V8 Work Truck & Toy (My Truck)
Check out both of my Caminos on link Below !
  #13
Old 01-28-2013, 08:51 AM
Year: 1981
Region: 1 (NY)
NECOA #: 14415
Thanks, great link. Closest one to me is about an hour away.
  #14
Old 01-28-2013, 08:59 AM
Year: 1987
Model: Conquista
Region: 6 (FL)
NECOA #: 16317
Garage
Quote:
You could get one of those spare gas tanks for the back of pickups (or 55 Gal drum) & Go fill it up & Have your Ethanol free fuel at the house !!
  #15
Old 01-28-2013, 09:01 AM
LOCKJAW's Avatar
Year: 1964
Region: 6 (FL)
NECOA #: 19368
Garage
Anyone have experience or opinion on octane boosters? I can only buy 89 pure gasoline locally.
You may not post new threads
You may not post replies
Gotta love the ethanol 85'Cab Engine Topics 13 10-09-2012 04:18 PM
North Carolina requires Ethanol labeling CopperTop Legislative Alerts 6 06-10-2012 07:49 PM
10% Ethanol vs 100% Gasoline Carretera Performance Modifications 67 10-06-2011 08:02 PM
Ethanol and your Classic 464elky Engine Topics 7 09-29-2011 07:21 PM
Ethanol and Your Engine FIRST ELKY 4 ME Engine Topics 8 02-14-2010 01:51 PM
