SBC 350 Modifications - El Camino Central Forum : Chevrolet El Camino Forums
Old 01-29-2013, 08:37 AM
caballerokid00 caballerokid00 is offline
Junior Member
Twisted Wrench
Year: 1984
Model: Caballero
Region: 12(MO,OK,KS)
NECOA #: 19761
caballerokid00 will become famous soon enough
Default SBC 350 Modifications
I have a sb 350 that I am going to put into my 1984 Caballero. It is completely disassembled and the only part I don't have is the crankshaft. I was wondering if anyone could recommend any things that I should consider when rebuilding this and any other upgrades I should do to create alot of horsepower on a budget. Thanks
Old 01-29-2013, 09:09 AM
darbysan's Avatar
darbysan darbysan is offline
Year: 1985
Region: 17(NV)
NECOA #: 910
darbysan is of outstanding character
It really depends on your budget. You have to consider the cost of just rebuilding/re-assembling your engine ( Gaskets, rings, bearings, machining, etc). Beyond that, your HP gain is in direct relation to how much you want to spend.
Give us some budget parameters, and I'm sure others will chime in with suggestions. No need to give you suggestions that will cost $5000 when your budget might be less.
'85 SS, Wicked Ruby Red, Gm Crate 350, Vortec heads,TPI, Serp, TES headers, Choo Choo nose, Acura Leather heated buckets, 2004 Gp Console and Shifter, 8.5 GN rear with 3.73, GN 200-4r, Craftec Tonneau w/ Electric release, Power Mirrors, Electronic HVAC, ZQ8 rims, Blazer Front brake upgrade, LS1 rear brake upgrade.
Old 01-29-2013, 10:01 AM
mugzilla's Avatar
mugzilla mugzilla is offline
Year: 1981
Model: Diablo
Region: 18(CA)
NECOA #: 22372
mugzilla will become famous soon enough
What year 350. I'd go with a pre 76 head fer shure, or later vortec style.
Old 01-29-2013, 05:42 PM
JJLT1's Avatar
JJLT1 JJLT1 is offline
Year: 1985
Model: El Camino SS
Region: 13(TX)
NECOA #: 12122
JJLT1 is a jewel in the rough
it depends on what you call alot of horsepower..
if you need a crank?? and you have to bore it??
might as well get a 383 kit.. its about the same price and it seems there getting cheaper..
used roller cams and heads can be found,, saves some moneys..
get the numbers off the block and heads and run them,, see where your starting from..
JJ
85 SS LT1 383 4L60 8.5 3.73
Tags
350, engine, ignition, machining, rebuilt
You may not post new threads
You may not post replies
DEQ and Modifications Wolfskin Performance Modifications 0 09-17-2009 11:28 PM
Potential Modifications and need opinions and speculation:) Court1100f Engine Topics 9 02-20-2007 12:28 PM
Body Modifications almost complete.................. Elcaminonyc General BS Topics 1 04-24-2006 04:22 PM
ckperformance 2004r transmission overhaul and modifications chris718 Transmission & Drive line 36 01-03-2006 05:12 PM
performance modifications BLVD.OG Site Topics 0 08-24-2004 10:26 PM
