5th Gen window re-seal question? - El Camino Central Forum : Chevrolet El Camino Forums
Old 02-03-2013, 04:51 AM
1980SteelBeast's Avatar
1980SteelBeast 1980SteelBeast is online now
Senior Member & Belton Committee Member
Year: 1980
Region: 13(TX)
NECOA #: 16503
1980SteelBeast is of outstanding character
Question 5th Gen window re-seal question?
So I brought some clear winshield glue to seal up my rear window since I kept noticing drops of water on the bottom of the plastic under the rear window. I sealed the window from inside on top of the plastic,but now my question is how to remove the plastic to seal the window from the bottom?
Itd be nice to know how to remove this without breaking anything since Im about to freshen up the interior once the plastic is out of the way.
Steel Beast
"I don't drink and drive,I pull over and sip!"
80 El Camino 6.3L
Old 02-03-2013, 05:42 AM
chevcamino's Avatar
chevcamino chevcamino is offline
Year: 1985
Region: 13(TX)
NECOA #: 12097
chevcamino will become famous soon enough
Hey Beast, before I got my 85 painted, the back glass was leaking and loose, it would rattle. The body man removed the glass and resealed it from the outside. And all is well. Hope it helps your dilemma.
1985 ElCamino
Old 02-03-2013, 06:42 AM
texas78's Avatar
texas78 texas78 is offline
Motor Mouth
Year: 1978
Region: 13(TX)
NECOA #: 22253
texas78 will become famous soon enough
Garage
if you are talking about the piece in the picture, there are 4-5 screws accessible from those little cut-outs next to the snaps you see along the bottom of the piece which need to be unscrewed first. then some tabs along the outsides that need to be dislodged in order to simply lift the piece off. lift the piece up as there are a few minor tabs along the top also that hold it in place. unless you really get physical with it, you should not break anything once the screws are out.
a work in progress
Old 02-03-2013, 07:07 AM
DONE DEAL DONNY's Avatar
Event Master & Deputy Director, Region 13
Year: 1968
Model: El Camino SS
Region: 13(TX)
NECOA #: 12098
DONE DEAL DONNY has a brilliant future
Garage
I guess I told you wrong, what I said was
What I should have said was
1968 El Camino S/S 396 " Yellow Rose of Texas"
1980 Blu Buy U
Old 02-03-2013, 08:01 AM
matty man's Avatar
matty man matty man is offline
Deputy Director Region 8 (OH-WV)
Year: 1966
Region: 8 (OH,WV)
NECOA #: 13930
matty man will become famous soon enough
Beast,, do yourself a favor and have a glass or body shop pull both front & rear glass and reseal them both,, thats the firsy thing I do when I get a 5th gen project,, and doesn`t the B pillar help hold that under the window peice in as well?? I just Keyser`s back in and it had little hooks or finger`s for the B & C pillar to hold that peice in,, I think,, Matty man
Old 02-03-2013, 08:26 AM
woody31 woody31 is offline
Year: 1981
Region: 13(TX)
NECOA #: 14520
woody31 is just really nice
matty man is right,,the only way to do it RIGHT is pull all the plastic then take it to a glass shop,,
what do i know,,i run a wore out truck motor,,
Old 02-04-2013, 11:55 AM
texas78's Avatar
Motor Mouth
Year: 1978
Region: 13(TX)
NECOA #: 22253
Garage
DDD
matty man is correct- those tabs i spoke of are under the B pillar, luckily i could wiggle mine loose, didn't have to remove the pillars, however most probably do.
Mine will go a glass shop for the seals when i get it re-done, but i work right next door to one so its not a hassle.
  #8
Old 02-04-2013, 02:59 PM
Year: 1980
Region: 13(TX)
NECOA #: 16503
I found the screws. I only had 2 out of 4 holding it in place.Used my drill and went to work.
I had to wiggle the B pillars to get it loose to finish day 2 of the re-seal after letting it set 24 hrs overnight.
Went and tested it good with a water hose for 25 minutes and no more leaks! Glad I didnt have to call my buddy at the glass shop for this easy job.
This is the reason why I love ECC! Thanks guys!
  #9
Old 02-07-2013, 04:47 PM
Year: 1975
Region: 9 (IN,KY,MI)
NECOA #: 13978
The El Camino rear windows are like airplanes with retractable landing gears. There are those folks who have landed with the gear "up", and those who will..(crunch)....so......
El Camino rear windows.........those that leak, and those that will....
Have it removed & done right, or it will come back to haunt you later......
AKA Pila
El Camino resto
The Malibu
You may not post new threads
You may not post replies
5th Gen window seal problem 69/84 Interior Restoration 3 09-12-2012 04:12 PM
Window rubber seal ridgeline Body Restoration 6 02-20-2008 11:36 PM
5th gen Quarter Window Seal for $190.00 ?? 87ElCamino Ebay / Craigslist Alert 15 05-16-2006 06:48 AM
5th gen drivers window seal / adjustment ThRoad86 General BS Topics 1 10-10-2004 04:00 PM
5th Gen. Window Weatherseals- HOW DO YOU GET TO SEAL?!! elrockss Body Restoration 5 04-07-2004 01:18 PM
