Corvette Axle? - El Camino Central Forum : Chevrolet El Camino Forums
Old 02-03-2013, 07:02 PM
FlatBlack65's Avatar
FlatBlack65 FlatBlack65 is offline
Year: 1965
Region: 18(CA)
NECOA #: 21586
FlatBlack65 has a spectacular aura about
Default Corvette Axle?
So, here goes a question i need help with. I'm doing research for a friend that has an '89 chevy Z-71 with a bunch of modifications: suspension lift, body lift, different transmission, and a rear end with disc brakes out of what the previous owner said was from a corvette. The stamping sais: LAS K201 2
anyone with any links or code books or info on where to find these rearend codes in a list or anything will be greatly appreciated
Old 02-03-2013, 07:08 PM
Keyser Sose's Avatar
Keyser Sose Keyser Sose is online now
Year: 1983
Model: El Camino SS
Region: 8 (OH,WV)
NECOA #: 15853
Keyser Sose is a name known to all
here's a link to the codes over the years
http://home.comcast.net/~jmasperi/vetrears.htm
and here's a link to the locations. Apparently they moved them around some
http://images.search.yahoo.com/searc...rear+end+codes
WHEN YOU KNOW WHAT THE MAGICIAN KNOWS, IT'S NOT MAGIC ANYMORE!
Old 02-03-2013, 07:44 PM
jlcustomz's Avatar
jlcustomz jlcustomz is offline
Year: 1983
Model: Caballero
Region: 6 (FL)
NECOA #: 19307
jlcustomz has a spectacular aura about
Does he have an independant rear suspension ? Or just a straight truck axle with a vette brake swap? I think truck diff covers were 14 bolt.
No true hot rod is ever finished. If it doesn,t command respect, fear will do.
Old 02-03-2013, 07:49 PM
Year: 1965
Region: 18(CA)
NECOA #: 21586
its a gm 12 bolt solid axle, so i'm thinking it was from the earlier years
Old 02-03-2013, 07:54 PM
Year: 1965
Region: 18(CA)
NECOA #: 21586
Quote:
yeah, its a solid axle, so i'm just wondering with the stampings (LAS K201 2), what its out of. He's just trying to track it down so he knows what he's dealing with. On a side note, i never knew till now that corvettes even now the 2013 ones use a rear leaf spring!!! Such low tech, but obviously it works, right? go figure
Old 02-03-2013, 08:04 PM
Year: 1983
Model: El Camino SS
Region: 8 (OH,WV)
NECOA #: 15853
is transverse, like on a Model A furd, so even older than you thought
Old 02-03-2013, 08:08 PM
Year: 1965
Region: 18(CA)
NECOA #: 21586
Quote:
well he has a traditional, solid rear axle with the normal leaf spring set-up. I was making a comment on the new vettes using the transverse leaf spring even today. I would have thought that they would be using progressive rate coil springs. but they are still using the leaf. interesting.
  #8
Old 02-04-2013, 01:55 AM
melissadunagan's Avatar
melissadunagan melissadunagan is offline
Year: 1981
Model: Conquista
Region: 13(TX)
NECOA #: 12939
melissadunagan will become famous soon enough
Corvettes have had IRS since 1963. The transverse spring helps keep the car flat in corners, it puts weight on the side trying to lift.
the ferret lady
  #9
Old 02-04-2013, 03:40 AM
464elky's Avatar
464elky 464elky is offline
Year: 1984
Region: 6 (FL)
NECOA #: 8926
464elky has a reputation beyond repute464elky has a reputation beyond repute
the gen 1 corvettes with solid rears were very narrow. I can't imagine getting any wheel clearance under a truck frame unless the frame is narrowed. They were also the pumpin type like a ford 9 inch. If the carrier housing doesn't unbolt from the front it is not a solid axle vette.
84 Elky with 455 Stage 2 Buick, Tremec TKO600 5 speed, 8.5 3:23 posi 98 Acura CL custom upholstered seats, Dakota Digital Instrumentation-
Car Domain:
Another 3 to 9 years should finish it.
  #10
Old 02-04-2013, 05:17 AM
mrblanche's Avatar
mrblanche mrblanche is offline
Year: 1986
Region: 13(TX)
NECOA #: 21555
mrblanche has a spectacular aura about
The independent rear on a Corvette is one reason hot rod builders refer to Corvettes as "donor cars."
The single-leaf transverse spring works very well. It is progressive in its own way, due to the taper in the spring. In fact, I guess you could say all leaf springs are progressive to a certain extent.
  #11
Old 02-04-2013, 04:10 PM
jlcustomz's Avatar
Year: 1983
Model: Caballero
Region: 6 (FL)
NECOA #: 19307
Another point to think about here, once a rear has been worked on ,the only way to know what ya got is to pull the cover.
  #12
Old 02-04-2013, 08:46 PM
chevyefi chevyefi is offline
Member
Loose Nut
Year: 1987
Model: Black Knight
Region: 15(AZ,MN)
NECOA #: 19609
chevyefi will become famous soon enough
6 lug truck with a "Corvette" rear.
Can't say I'd give it too much thought.
  #13
Year: 1965
Region: 18(CA)
NECOA #: 21586
No, i totally get it. I was just commenting that i never knew that corvettes used transverse leaf springs in the rear, even in the newest edition 2014 re-designed Vette. I think its cool though. Gonna let my buddy know that his rear is not vette. Maybe the rear disc brake conversion is from a vette? Is THAT a common swap? I've never had any experience with rear-ends......well, AUTOMOBILE rear-ends anyway....um.....uh....er.....yeah.
  #14
Old 02-05-2013, 10:05 AM
lorandolph lorandolph is offline
Junior Member
Gear Head
Year: 1970
Model: El Camino SS
Region: 6 (FL)
NECOA #: 23471
lorandolph will become famous soon enough
Talking Transverse Spring
Quote:
Having owned 8 Vettes now ranging from 75 on... and lately an '09 ZO6 - I can attest to the fact that the transverse spring works extraordinarily well thank you very much! Chevrolet transitioned from a traditional steel leaf spring somewhere around 1980 to a fiberglass composite one first to save weight. The spring design has evolved over the years with tapering and variation in the composites and how they are layered and composed from the center outwards. I believe you could indeed say they are "progressive". Just because it is transverse doesn't make it primitive - it is in fact a pretty thoroughly engineered piece of tech.
  #15
Old 02-05-2013, 07:52 PM
Year: 1965
Region: 18(CA)
NECOA #: 21586
its all good. I love Corvettes. I'm not knocking them by saying i didn't know that they had leaf springs, and mistakenly thinking that leafs are low tech. Obviously i'm ignorant of all the high tech leafs GM is using on those. A 7:19 lap time at Nordschleife (Nurenburgring) in 2008 mind you, only bested by quarter million plus super exotics says allot for the technology in the Vette.....rear leafs and all. No offense meant to the corvette folks. My deepest apologies
You may not post new threads
You may not post replies
Anyone need any Corvette ...... scraps!!! DONE DEAL DONNY Ebay / Craigslist Alert 10 01-02-2013 06:03 PM
C2 corvette rims jgaray Suspension & Steering 0 04-12-2010 09:57 AM
LT1 corvette rgile Parts for sale 0 11-23-2008 08:40 AM
Corvette 65RiceEater General BS Topics 3 03-25-2006 11:20 PM
corvette adam78 Body Restoration 1 11-03-2005 02:09 PM
