Pulling Transmission. Hold up Trans? - El Camino Central Forum : Chevrolet El Camino Forums
Old 02-04-2013, 02:01 PM
chevyefi chevyefi is offline
Member
Loose Nut
Year: 1987
Model: Black Knight
Region: 15(AZ,MN)
NECOA #: 19609
chevyefi will become famous soon enough
Default Pulling Transmission. Hold up Trans?
I promised my nephew a transmission for his high school shop class. The TH350-C in the 83 SS is bad and I wouldn't ever fix it when I could almost as easily put a 200-4R in. So I'll probably pull it tomorrow.
Now, if I let the engine sag in back, it would eventually junk the 30 year old engine mounts as it's my "haven't done much with it in a long time" project. I guess I could stab a 200-4R or 700-R4 core in and prop it up with the crossmember (don't have a correct crossmember right now since the 83 lacks the frame support for it.)
Or should I just use a strip of steel and hang a bellhousing bolt off a bolt at the firewall?
Hmm.
Member
Loose Nut
Year: 1987
Model: Black Knight
Region: 15(AZ,MN)
NECOA #: 19609
Hold up *Engine*
Old 02-04-2013, 02:22 PM
Skandolis's Avatar
Skandolis Skandolis is offline
Year: 1977
Region: 14(AR,LA,MS)
NECOA #: 19697
Skandolis will become famous soon enough
Just opinion, but if the mounts are bad enough to let the engine "sag" to the rear, they should probably be replaced anyways, mounts are cheap. but a block of wood between the oilpan and crossmember works well.
77 Classic with one piece main 350, .60 over,Flattops, vortec heads, edelbrock single plane,2800 stall converter, 1-3/4 heddman headers,lt4 "hotcam", tbi running at 22psi ,3.73 gears custom tune with a lot of fuel and a scary amount of timing.......
Old 02-04-2013, 03:22 PM
Keyser Sose's Avatar
Keyser Sose Keyser Sose is offline
Year: 1983
Model: El Camino SS
Region: 8 (OH,WV)
NECOA #: 15853
Keyser Sose is a name known to all
Put a 8-10 inch length of 2 X 6 or 8 between engine bellhousing and the firewall and let engine lean back and rest against it (pull the wiring out of the way). My elkie rode on a trailer like that for 2.5 hrs when Matty came and got it with no problems, yours can sit around like that ok.
WHEN YOU KNOW WHAT THE MAGICIAN KNOWS, IT'S NOT MAGIC ANYMORE!
Old 02-04-2013, 07:10 PM
TrannyMike's Avatar
TrannyMike TrannyMike is offline
Deputy Director, Region 18
Year: 1985
Region: 18(CA)
NECOA #: 18805
TrannyMike is of outstanding character
Normally if your mounts and exhaust are in good shape, all you do is remove the distributor cap and lower the trans slowly, The exhaust holds the trans up more than the mounts unless you had to disconnect the exhaust to remove the trans. Keysers way is another way you can keep the trans up too. As mentioned by Skandolis you really should replace the motor mounts..... they're cheap!
Mike
Old 02-04-2013, 07:25 PM
Year: 1975
Region: 9 (IN,KY,MI)
NECOA #: 13978
Things can get interesting on some cars, when a mount fails..like jamming the gas pedal and shift linkage etc....
AKA Pila
El Camino resto
The Malibu
You may not post new threads
You may not post replies
Pulling motor and trans with intake plate? DONE DEAL DONNY Engine Topics 36 10-25-2012 05:08 AM
Could not hold it !!! fixitman1 General BS Topics 6 03-28-2012 07:29 PM
Will They Hold Up? theelcaminoman Transmission & Drive line 5 01-09-2012 10:30 PM
Will the 200-4r hold up? Movieboy08 Transmission & Drive line 35 07-30-2007 03:59 PM
Pulling motors, need trans bolt suggeations. Chief Smackaho Engine Topics 3 04-06-2006 04:59 PM
