Axle saver bearing ? - El Camino Central Forum : Chevrolet El Camino Forums
Old 02-17-2013, 04:17 PM
DOUG213XRJ's Avatar
DOUG213XRJ DOUG213XRJ is offline
Year: 1978
Region: 9 (IN,KY,MI)
NECOA #: 13817
DOUG213XRJ will become famous soon enough
Default Axle saver bearing ?
Hey, Has anyone used these ? The bearings on my axles are scuffed up from bad axle bearings. Ive been told these will fix the problem and Ive also been told axle saver bearings are not SAFE.. Just looking for a more opinions. I plane on doing burnout and all the other fun stuff.
Doug
79 Malibu
78 El Camino
81 Malibu
Old 02-17-2013, 04:31 PM
matty man's Avatar
matty man matty man is offline
Deputy Director Region 8 (OH-WV)
Year: 1966
Region: 8 (OH,WV)
NECOA #: 13930
matty man will become famous soon enough
I have used just a few in the past years,, about 10 years ago,, I did not have any issues,, not sure what would be unsafe about them?? Matty man
Old 02-17-2013, 04:42 PM
DOUG213XRJ's Avatar
Year: 1978
NECOA #: 13817
Ive heard the wear spot on the axle where the factory bearing was/is creates a week spot and thats where the axle will break. That makes the axle unsafe not the bearing.
Doug
Old 02-17-2013, 04:48 PM
woody31's Avatar
woody31 woody31 is online now
Year: 1981
Region: 13(TX)
NECOA #: 14520
woody31 is just really nice
Garage
that is a myth,,the axle saver only moves the rollers to a fresh surface,,by doing such it does not alter the structural composition of the metal,,so i highly dismiss the thought of being unsafe,,however,,if you were running low 12s or high 11s on the strip with slicks,,i wouild consider replacing thewm with a set of moser axles,,rest easy my friend,,swap it out,,never look back,,plus its better than riding on a bad bearing,,,
in answer to your ??? yes i have used them with no issues
hey yall,,,watch this...
Old 02-17-2013, 07:15 PM
LOCKJAW's Avatar
LOCKJAW LOCKJAW is online now
Year: 1964
Region: 6 (FL)
NECOA #: 19368
LOCKJAW is just really nice
Garage
Precisely why I have a GTO posi rear with bolt in axles with sealed Timken bearings. A better set up.
To Err Is Human, To Forgive Is Divine...Neither Is Marine Corps Policy!
It's hard to function while constantly doubting the validity of my previous thought.
1964 restomod. Wht/red, ZZ4 w/ mods, Muncie , QFT, Hookers, Flowmasters.
Old 02-17-2013, 08:19 PM
Year: 1975
NECOA #: 13978
I used an axle saver bearing in my Malibu a few years ago. Like said above, don't know why it would cause an un-safe condition. Sounds like part of a bar room conversation
AKA Pila
El Camino resto
The Malibu
You may not post new threads
You may not post replies
Clutch Release Bearing - Throw out bearing BK Transmission & Drive line 4 07-28-2012 05:45 AM
Proper Axle Bearing Fit...? Dinosdad Transmission & Drive line 13 10-08-2010 01:27 PM
axle-saver bearing steelybill Transmission & Drive line 2 06-27-2009 08:29 AM
gas saver cams porkchops Performance Modifications 6 03-13-2008 04:56 AM
Can I pack a bearing without a "bearing packer"? 77SS Suspension & Steering 13 05-03-2006 07:36 PM
