700R4 Verses 200-4R? - El Camino Central Forum : Chevrolet El Camino Forums
View Poll Results: 700R4 or 200 4R
700 20 42.55%
200 27 57.45%
Voters: 47. You may not vote on this poll
Old 02-21-2013, 03:18 AM
DONE DEAL DONNY's Avatar
Event Master & Deputy Director, Region 13
Year: 1968
Model: El Camino SS
Region: 13(TX)
NECOA #: 12098
DONE DEAL DONNY has a brilliant future
Garage
Default 700R4 Verses 200-4R?
I think I've had both of them in at least a couple of El Caminos
I know the Pinko had a 700R4 and I (think I remember) Thumper having a 200 4R?
It seems like both had a sissy second gear that I hated. 1st and 3rd were fine but second always seemed mushy????
The Pinko you could not hold in first it would shift to second anyways. It would sit there and burn off the tires all day long but at very low RPMS
So dollar for dollar which would you go with. 200s are a lot more costly right? And this is for the 79 with 350 motor and 410 posi rear end that I'm sure will be dogged all day!!
Thoughts?
1968 El Camino S/S 396 " Yellow Rose of Texas"
1980 Blu Buy U
Old 02-21-2013, 03:31 AM
cam81's Avatar
cam81 cam81 is offline
Year: 1981
Model: El Camino SS
Region: 5 (NC,SC)
NECOA #: 20188
cam81 will become famous soon enough
If I'm not mistaken, both can be built to handle the same abuse. Although the 700R4 can be done for less. If they are set up for the same level of performance, then the question really boils down to 1st gear ratios. The 700R4 has the 3.08 gear while the 200-4R has the 2.74 gear. With 4.10 gears in the back, it might not make any real difference at all what that gear ratio is, so I might suggest finding the least expensive one available to you keeping in mind the modifications you have to make to fit either one into the Camino.
-Jarod
1981 El Camino Super Sport "Cruiser"
2005 GMC Envoy XL "Family Car"
Old 02-21-2013, 03:38 AM
Year: 1968
Model: El Camino SS
Region: 13(TX)
NECOA #: 12098
Garage
Oh come on, I can just open the glove box and put it in that way can't I????
Your right, the mounts and everything else will come into price!!
woody31's Avatar
woody31 woody31 is offline
Year: 1981
Region: 13(TX)
NECOA #: 14520
woody31 is just really nice
Garage
same as above ,,,and the 200-4r has a better gear split between 1-2 gears,,(less rpm drop)..
hey yall,,,watch this...
Old 02-21-2013, 05:48 AM
1980SteelBeast's Avatar
1980SteelBeast 1980SteelBeast is offline
Senior Member & Belton Committee Member
Year: 1980
Region: 13(TX)
NECOA #: 16503
1980SteelBeast is of outstanding character
with those gears,theres no way either of those will help you. Go with 3.73's and a 200 4r.
If you need one,my buddy who beefed mine up is available...
Steel Beast
"I don't drink and drive,I pull over and sip!"
80 El Camino 6.3L
Old 02-21-2013, 06:13 AM
TrannyMike's Avatar
TrannyMike TrannyMike is offline
Deputy Director, Region 18
Year: 1985
Region: 18(CA)
NECOA #: 18805
TrannyMike is of outstanding character
Interesting beastie. What trans would you say should go with that diff?
Mike
Old 02-21-2013, 06:39 AM
Year: 1980
Region: 13(TX)
NECOA #: 16503
Quote:
He should be rolling Fred Flinstone style! The feet are the trans and engine! Lol. Havent had my coffee. He should go with a 200 4r. Right?
  #8
Old 02-21-2013, 06:53 AM
andiamo's Avatar
andiamo andiamo is offline
Year: 1986
Region: 6 (FL)
NECOA #: 11774
andiamo will become famous soon enough
I have a question, what transmission is in the car now? The cost of having the driveshaft cut down if a 200-4r would be a direct bolt on could offset some of the cost of building the 200-4r beefier. If you want a deep trans pan for the 200 be prepared to pay double what one for a 700r4 costs sadly. I do love my 200 though and it had 370k miles on the factory build when I had it rebuilt.
86 elk being restored
85 Monte SS Daily Driver
  #9
Old 02-21-2013, 08:00 AM
jkk's Avatar
jkk jkk is offline
Year: 1967
Region: 13(TX)
NECOA #: 21960
jkk will become famous soon enough
Garage
I have a 700r4 in mine the one two shift rpm drop not a real issue as my 383 makes enough torque it will burn em off all the way thru third till you get off it.............impresses the ladies
1967 - GM ZZ 383 700R4 12 BOLT 3.73 POSI . Ranchero Eater!
My motor can out run your stereo
  #10
Old 02-21-2013, 08:27 AM
cam81's Avatar
Year: 1981
Model: El Camino SS
Region: 5 (NC,SC)
NECOA #: 20188
Quote:
the driveshaft for the 700 is one consideration in the overall cost, the crossmember for the 200 is another consideration. If he doesn't already have a core, finding an inexpensive core that isn't ruined is probably going to be the deciding factor. As far as the 700R4, I think there are two different ones available with 27 or 30 spline input shaft. I think this difference correlates to strength of the transmission. I will have to defer to others here about this information though.
-Jarod
  #11
Old 02-21-2013, 08:55 AM
BigAl 327's Avatar
BigAl 327 BigAl 327 is offline
Site Contributor
Year: 1966
Model: El Camino Classic
Region: 18(CA)
NECOA #: 4005
BigAl 327 has a spectacular aura about
Garage
Go with the 700R4. Biger number means biger HP, RIGHT?? I think $$$$ factor would be a big factor. I have heard they both are good.
1966 El Camino " The Mistress"
Big Al
  #12
Old 02-21-2013, 07:34 PM
Year: 1968
Model: El Camino SS
Region: 13(TX)
NECOA #: 12098
Garage
It sounds like the 700 might be the best deal for the money.
I'm still going to be thinking on it but I wish to thank everyone for your input!!!!
  #13
Old 02-22-2013, 07:50 AM
JJLT1's Avatar
JJLT1 JJLT1 is offline
Year: 1985
Model: El Camino SS
Region: 13(TX)
NECOA #: 12122
JJLT1 is a jewel in the rough
never had a 200-4r,, i allways assuumed?? there was a reason they never put them in trucks?? and they quit making them??
i have had several 700s,, and do love that 3.06 first gear.. it can save you a rear gear change, sometimes..
700s do have there weak links/parts.. i have broke a few..
the 1st to 2nd rpm drop allways comes up,, so i looked and its about 242 rpm???
and about 100 rpm for the 2nd to 3rd shift.. not much difference to me..
do the math maybe i did it wrong??
http://www.gtsparkplugs.com/GearCalc.html (just add in the 200-4r ratios)
any more info TranyMike?? price to rebuild each one that would handle 500ftlb torq??
i need a early 4L60E repair now..
Trans1st Gear2nd Gear3rd Gear4th GearReverse
Powerglide 1.76/1.82 1.00-
TH350 2.52 1.52 1.00---1.94
TH400 2.48 1.48 1.00---2.07
TH200-4R 2.74 1.57 1.000 .67 2.06
TH700-R4 3.06 1.62 1.000 .70 2.29
4L80E 2.43 1.49 1.000 .75 2.07
JJ
85 SS LT1 383 4L60 8.5 3.73
  #14
Old 02-22-2013, 01:02 PM
melissadunagan's Avatar
melissadunagan melissadunagan is offline
Year: 1981
Model: Conquista
Region: 13(TX)
NECOA #: 12939
melissadunagan will become famous soon enough
Hey Donny just put a T5 in it and not worry about those slush boxes. That is what I am doing.
the ferret lady
  #15
Old 02-22-2013, 05:02 PM
Mr.NastyTimes_86_eLky's Avatar
Mr.NastyTimes_86_eLky Mr.NastyTimes_86_eLky is offline
Year: 1986
Model: El Camino SS
Region: 6 (FL)
NECOA #: 21911
Mr.NastyTimes_86_eLky will become famous soon enough
Im going with the 2004r.. its the best!!!! you know how i know....
because i have one...
You may not post new threads
You may not post replies
Eldelbrock verses Rochester? DONE DEAL DONNY Engine Topics 35 07-11-2011 02:32 PM
305 verses 350 DONE DEAL DONNY Engine Topics 35 06-21-2010 08:17 PM
700R4 done, now the???? Jpz85 Transmission & Drive line 8 04-01-2009 07:27 PM
700r4 ? 65 ELKY Transmission & Drive line 4 07-31-2008 07:34 PM
700r4?????? JRSoct24 Transmission & Drive line 1 12-12-2005 04:44 AM
