I have a matched ring and pinion gear set. It's 7.625" but fits the 7.5" and 7.625" 10-bolt rears. Ratio is 3.42. These fit the 3-series carriers. Also have new ring gear bolts.
These gears are used but in great condition. $100.00 plus shipping. Jack Last edited by Jack_K; 02-21-2013 at 08:09 AM. |
| Sponsored Links | ||
Advertisement | ||
I'm checking with Ralph, but that just might be what I need for my 78. Will send you a pm if so! Thanks!
To view links or images in signatures your post count must be 0 or greater. You currently have 0 signatures. Terry Duct tape extraordinaire |
I'll take $75.00 plus shipping. Remember, this is a 7.625" ring gear. It's bigger than the 7.5" but still fits the same carrier and rear end.
Anybody? |
Who makes that?
Do you have a good 26 spline 3 series carrier??
hey yall,,,watch this... To view links or images in signatures your post count must be 0 or greater. You currently have 0 signatures. |
No carrier.
I have no idea who made the gears. There's no marking on either. |
Quote:
In case you need more info, my rear is a 10 bolt in a 82 Camino.
Matthew W. Clark, Sr. Proud owner of a 1982 El Camino SS Z16 Royal Knight. Under Construction: 2/2012 Planned things to change(Updated): 334 w/TBI, T5 5-speed, 3:42 Posi, Rear Disc Brakes, Some 3rd gen Camaro interior (Dash, Seats, Center console, etc.)....and of course, all the body work. Will take photos and keep ECC updated on progress. |
#8
Quote:
There are ring gear spacers available (ebay for instance) that will let you use these gears on your carrier. So, you need my gears and a ring gear spacer. Jack |
#9
Quote:
#10
Ok, I really am clueless on rear ends. But I do know a little terminology for them. You are saying it won't work because I have a 2 series carrier. So that means a series 2 is 3.08 and numerically lower and 3.08 and higher is series 3, correct?
So in order for me to use these gears I would need something like what is on this eBay link? http://www.ebay.com/itm/Ring-Gear-Sp...73d59e&vxp=mtr |
#11
To anyone upgrading gears....check first before purchasing! GM had an overlap between the "series." Mine had a set of 3.08's with 2 series carrier from the factory. The 3.42's are also available for a 2 series carrier aftermarket. Spacers would be ok if the gears were obsolete but otherwise should be avoided in my opinion.
http://www.summitracing.com/parts/rmg-4900051/overview/ |
#12
Quote:
#13
Quote:
Everyone has an opinion and MINE is that the spacer is totally acceptable. What's the difference between a spacer and a thicker gear? Same spacing. Sure, a thicker gear might be a tad bit tougher, but the thin gear is stock and used in the 3-series carrier, so what's the problem? |
#14
Quote:
I'm not an expert but Richmond Gear is. They don't sell them and don't recommend them either. |
#15
Jack K .....thanks for the PM to me about ruining your "potential sale"
I apologize and I was only concerned for the safety of others. Last edited by jojothetattooboy; 03-03-2013 at 08:54 AM. Reason: apology |
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
| Display Modes | |
| ring and pinion | Steve84Ec | Parts for sale | 0 | 08-15-2008 09:20 AM |
| 3.23 ring and pinion | Steve84Ec | Parts for sale | 0 | 07-23-2008 07:07 AM |
| 3.42 ring and pinion | speedy86 | Parts for sale | 2 | 09-26-2005 10:08 AM |
| ring gear and pinion | workNprogress | General BS Topics | 7 | 06-14-2003 06:16 AM |
| 7.5" Ring and Pinion sets | Mecheng | Parts for sale | 1 | 06-07-2003 11:02 PM |
