Mothers and Mag Wheels go together - El Camino Central Forum : Chevrolet El Camino Forums
Old 02-23-2013, 08:09 PM
HKDUP87's Avatar
HKDUP87 HKDUP87 is offline
Year: 1987
Model: Conquista
Region: 18(CA)
NECOA #: 18458
HKDUP87 is a glorious beacon of light
Garage
Default Mothers and Mag Wheels go together
O.k. it was time to try and clean up my mag wheels so I went out to try and buy a cloth ball for polishing and they don't exist in stores or detail supply shops only online. I used my drill with some buffing pads and Mothers Aluminum polish and this is what came out. It's still not the way I want them to look but they came out pretty nice.
Before
First round
done for now will try another way to get it perfect.
I have learned to never characterize any of my cars as fixed....they are just temporarily between malfunctions. .....Dan ( old_coot)
Old 02-23-2013, 08:17 PM
1980SteelBeast's Avatar
1980SteelBeast 1980SteelBeast is online now
Senior Member & Belton Committee Member
Year: 1980
Region: 13(TX)
NECOA #: 16503
1980SteelBeast is of outstanding character
Looking good!
Steel Beast
"I don't drink and drive,I pull over and sip!"
80 El Camino 6.3L
Old 02-23-2013, 08:25 PM
HKDUP87's Avatar
Year: 1987
Model: Conquista
Region: 18(CA)
NECOA #: 18458
Garage
I can't get a mirrored shine it's blurred and watching YouTube I should be able to. If not I may take them to Original Wheels down here and have them refinished .
Old 02-23-2013, 08:28 PM
Elly Girl's Avatar
Elly Girl Elly Girl is offline
Year: 1983
Region: 13(TX)
NECOA #: 22435
Elly Girl will become famous soon enough
Did you take them off the truck to do the cleaning?
Old 02-23-2013, 08:40 PM
83RS's Avatar
83RS 83RS is offline
Master Dipstick
Year: 1983
Model: Conquista
Region: 6 (FL)
NECOA #: 17447
83RS will become famous soon enough
Did you try Harbor Freight for a cloth ball ? I found one there (cone shaped) works great om my polished intake manifold. If I remember the had a few different shapes and sizes.
That wheel and tire combo looks great... Nice choice
"Some Day" Came
Old 02-23-2013, 09:25 PM
Ductape's Avatar
Ductape Ductape is offline
Motor Mouth
Year: 1979
Model: Caballero
Region: 16(CO,MT,WY,UT)
NECOA #: 18375
Ductape is a jewel in the rough
Looks good man.
I'm gonna do the same thing once it warms up and stops snowing here in Utah.
Old 02-23-2013, 09:42 PM
HKDUP87's Avatar
Year: 1987
Model: Conquista
Region: 18(CA)
NECOA #: 18458
Garage
Yea I got a couple of the cones but I want one that has strips of cloth to beat the living crap out of it. You need a long shaft that's padded so you don't scratch anything. Maybe these rim's have a coating on them I can't tell. I was thinking about some buffing compound but I think Original Wheels may only charge like $40.00 or $50.00 ea. to refinish them like new and get all the little pits out at the same time. I'm only going to use these in the summer to keep them nice and low maintenance by swapping the Iroc's I also keep the extra set in my spare bedroom parts dept.
Elly Girl Did you take them off the truck to do the cleaning?
I'm giving you a pass on this question because your " PLUM CRAZY PURPLE IN LOVE" No I only took them off to take the pictures.
  #8
RTT's Avatar
RTT RTT is offline
Year: 1984
Region: 18(CA)
NECOA #: 20475
RTT will become famous soon enough
Looks Great Robert!
Todd RTT
  #9
Old 02-23-2013, 10:21 PM
TrannyMike's Avatar
TrannyMike TrannyMike is offline
Deputy Director, Region 18
Year: 1985
Region: 18(CA)
NECOA #: 18805
TrannyMike is of outstanding character
Robert if your polishing cloth or buffers are turning gray the wheels are not coated.
Mike
  #10
Old 02-23-2013, 11:20 PM
HKDUP87's Avatar
Year: 1987
Model: Conquista
Region: 18(CA)
NECOA #: 18458
Garage
Quote:
That's true I have plenty of gray. I saw on YouTube to seal them use bees wax???
  #11
Old 02-24-2013, 02:20 AM
jkk's Avatar
jkk jkk is offline
Year: 1967
Region: 13(TX)
NECOA #: 21960
jkk will become famous soon enough
Garage
1967 - GM ZZ 383 700R4 12 BOLT 3.73 POSI . Ranchero Eater!
My motor can out run your stereo
  #12
Old 02-24-2013, 03:52 AM
jlcustomz's Avatar
jlcustomz jlcustomz is offline
Year: 1983
Model: Caballero
Region: 6 (FL)
NECOA #: 19307
jlcustomz has a spectacular aura about
The metal does look scuffed up close, you could try a little 2000 grit wetsanding on a section & see if that polishes back a little smoother.If your're fine polishing over fine scratches with a non agressive cleaner, it may take forever to get them like mirror. Last year I tried white diamond polish from advanced auto parts on my custom aluminum air scoop I made & it was faster at getting me to the final shine. Worked faster than anything on old diamond plate, but was pretty messy for my aluminum engine parts that weren't fully polished. Every product has it's good & bad points.
At least aluminum is pretty thick compared to clearcoat, so you can experiment all you want with it.
No true hot rod is ever finished. If it doesn,t command respect, fear will do.
  #13
Old 02-24-2013, 04:53 AM
HKDUP87's Avatar
Year: 1987
Model: Conquista
Region: 18(CA)
NECOA #: 18458
Garage
How about Mcquire's 105 cutting compound with a cloth buffing wheel or rubbing compound? I tried wet sanding a small spot on the back with 2000 and it scratched or scuffed it so it quit. I know you have to do that but I'm still not confident enough. I have an extra two of the same rims and tires that came with the others so maybe today I will try the wet sanding.
  #14
Old 02-24-2013, 05:39 AM
matty man's Avatar
matty man matty man is offline
Deputy Director Region 8 (OH-WV)
Year: 1966
Region: 8 (OH,WV)
NECOA #: 13930
matty man will become famous soon enough
What about the salt from the ice and snow??? It will dull them up quickly,,,, Matty man
  #15
Old 02-24-2013, 06:45 AM
dirtpoor's Avatar
dirtpoor dirtpoor is offline
Year: 1983
Model: Conquista
Region: 10(IL,MN,WI)
NECOA #: 20106
dirtpoor will become famous soon enough
Ive used 0000 steel wool I thought it did a great job.
You may not post new threads
You may not post replies
What a little Mothers under the hood can do for you!! HKDUP87 Detailing 21 08-16-2012 08:04 PM
Happy mothers day !! 87next2last1 General BS Topics 9 05-13-2012 08:40 PM
Happy mothers day woody31 General BS Topics 2 05-13-2012 08:34 AM
Happy Mothers Day!!!!! DONE DEAL DONNY General BS Topics 3 05-09-2010 07:47 AM
mothers powerball oddball383 Product Review 8 08-13-2005 04:55 PM
