So I got this 86 Elky...... - El Camino Central Forum : Chevrolet El Camino Forums
Old 02-24-2013, 02:47 PM
Tony W's Avatar
Tony W Tony W is offline
Year: 1981
Region: 15(AZ,MN)
NECOA #: 19522
Tony W will become famous soon enough
Default So I got this 86 Elky......
And it's a beautiful ride. I just went through emission with great results. The previous owner installed a manual choke on the carb. When the choke is pushed in the car is a dog off the line. Really slow , then a somewhat hard shift into second where she finally feels like she's getting some steam.
The funny thing to me is when I position the choke just right, that sluggish start off the line goes away and she's strong with no hard shifting.
I don't want to screw with anything seeing that I passed emissions but it seems that something on the ccc is bad.
Any ideas would be greatly appreciated.
Sent from AutoGuide.com App
Tony Watlington
Old 02-24-2013, 03:05 PM
Year: 1975
Region: 9 (IN,KY,MI)
NECOA #: 13978
If that carb is old & been on there for a long time, it may have some debris in it, causing what you describe. Getting it rebuilt may be what you will have to do. Lots of posts on here about rebuilt carbs & who does it.
Taking it apart your self may not be a good idea if you aren't into carbs at all.
Bill
AKA Pila
El Camino resto
The Malibu
Old 02-25-2013, 09:33 AM
darbysan's Avatar
darbysan darbysan is offline
Year: 1985
Region: 17(NV)
NECOA #: 910
darbysan is of outstanding character
If it's a true manual choke, then you will have to close it to start your vehicle when it's cold, and then open it as the vehicle warms up. It is not something you can set once and forget. They are a pain, and the reason the thermostatic chokes were invented.
'85 SS, Wicked Ruby Red, Gm Crate 350, Vortec heads,TPI, Serp, TES headers, Choo Choo nose, Acura Leather heated buckets, 2004 Gp Console and Shifter, 8.5 GN rear with 3.73, GN 200-4r, Craftec Tonneau w/ Electric release, Power Mirrors, Electronic HVAC, ZQ8 rims, Blazer Front brake upgrade, LS1 rear brake upgrade.
Old 02-25-2013, 09:37 AM
Tony W's Avatar
Year: 1981
Region: 15(AZ,MN)
NECOA #: 19522
Quote:
This I know. Will replacing the thermostatic choke (If possible) fix this issue and allow me to remove the manual device??
Old 02-25-2013, 10:47 AM
melissadunagan's Avatar
melissadunagan melissadunagan is offline
Year: 1981
Model: Conquista
Region: 13(TX)
NECOA #: 12939
melissadunagan will become famous soon enough
yes
the ferret lady
Old 02-25-2013, 12:14 PM
rnhart3's Avatar
rnhart3 rnhart3 is offline
Year: 1979
Region: 2 (CT,MA,ME,NH,RI,VT)
NECOA #: 17856
rnhart3 will become famous soon enough
Garage
you'll have to get a choke vacuum break also
Jim
1979 El Camino, retired daily-driver,
current frame-off resto project
1986 Monte SS, mild 350, headers, elec cooling
fan,"A" Pillar gauges, subtle
modificatons,currently at the trans shop
for HD upgrades
1986 Monte SS T-Tops, for parts...
1985 El Camino
1986 El Camino
1991 S10 pick-up
1997 Chevrolet Tahoe 2 dr.
1981 Malibu 9C1 wagon...parts?...or drive?
"Too many parts cars to mention....."
Old 02-25-2013, 12:42 PM
Tony W's Avatar
Year: 1981
Region: 15(AZ,MN)
NECOA #: 19522
Quote:
So I need to replace both units together??
  #8
Old 02-25-2013, 01:27 PM
NEURON NEURON is offline
Member
Loose Nut
Year: 1985
Region: 18(CA)
NECOA #: 23153
NEURON will become famous soon enough
I love manual chokes, I like to be in control. Here in SOCAL you can't pass smog with a manual choke. The only downside to manual chokes, and I believe that's why they went away, is people tend to over choke or forget to fully turn it off.If you have the dinero I would save the money you would put into getting the choke operational towards a Mountain Man rebuilt and start enjoying your Elky and life in general.
  #9
Old 02-27-2013, 03:30 PM
Tony W's Avatar
Year: 1981
Region: 15(AZ,MN)
NECOA #: 19522
Ok so here's the setup I inherited. You can see how the manual choke was installed on the choke thermostat.
Some have suggested that I hit the linkage with carb cleaner to possibly free them up , while others say replace the the thermostat and and the part attached to it all together. I really like the way she runs (minus fiddling with the choke issue) and don't necessarily want to replace the carb unless I absolutely have no choice.
Also I found this connector just laying here and have no clue what it goes to. I can't help but think that with its proximity to the choke it was the connected to the it at some point. Any help there also would be great. Click image for larger version
ID:	5224Click image for larger version
Also when I manually moved the linkage it's REALLY notched.
  #10
Old 02-27-2013, 04:34 PM
rnhart3's Avatar
Year: 1979
NECOA #: 17856
Garage
Looks there is a choke-pull already there (but does it work?)...that wire is probably the hot lead for the electric thermostatic choke spring.
Makes you wonder why the PO did what he did. You have to start from scratch, verify all components, and I would attempt to return to OE operation, that's just me though...
  #11
Old 02-27-2013, 04:57 PM
darbysan's Avatar
Year: 1985
Region: 17(NV)
NECOA #: 910
My guess is the spring behind that black plastic cover is broken- common problem. You can buy a kit with a new spring, and it comes with screws that replace the three rivets. You have to drill out those rivets, pop the cover off, and insert the new spring. Not hard at all, once you get the rivets out.
I can only guess that the wire you showed is the choke wire. The connector is not a choke connector, but rather something aftermarket. Start the car, and then check for 12V on that wire. Voltage there would indicate that it is likely the choke wire.
Here's a kit that has the choke coil, screws and connector pigtail.
http://www.ebay.com/itm/ROCHESTER-EL...item257afcc7cc
  #12
Old 02-27-2013, 07:49 PM
Tony W's Avatar
Year: 1981
Region: 15(AZ,MN)
NECOA #: 19522
The thing is I don't know if this carb came with an electric or manual choke to begin with. The Rochester P/N 17088152 tells me it came with a P/N CC139 but the maintenance manual carb P/N E4ME calls for P/N
EC-8281-C.
  #13
Old 02-27-2013, 09:41 PM
darbysan's Avatar
Year: 1985
Region: 17(NV)
NECOA #: 910
It's not factory. Manual chokes went out in the 50's.
  #14
Old 02-28-2013, 03:47 AM
Tony W's Avatar
Year: 1981
Region: 15(AZ,MN)
NECOA #: 19522
Sorry I misled you. I know the manual choke isn't factory. He told me he installed it. I just don't know what came with it originally , the choke with the blade type connector or the one with what looks like a screw driver slot in the center.
  #15
Old 02-28-2013, 03:54 AM
Tony W's Avatar
Year: 1981
Region: 15(AZ,MN)
NECOA #: 19522
Just bought the kit. Thanks Darbysan!!
You may not post new threads
You may not post replies
78 elky rearend into an 82 elky Mark58 Transmission & Drive line 6 10-27-2010 05:51 PM
elky new B just got a 1980 elky need to find parts derek1980_elky General BS Topics 3 08-13-2010 02:07 PM
