700r into 69 elky. - El Camino Central Forum : Chevrolet El Camino Forums
Old 02-24-2013, 10:32 PM
moose866's Avatar
moose866 moose866 is offline
Director, Region 25
Year: 1969
Region: 25 (ALL OTHER)
NECOA #: 23486
moose866 will become famous soon enough
Default 700r into 69 elky.
Ok you blokes,who can help me with this one? Im thinking this will be pretty straight forward but just in case,will a 700 tranny go straight into a '69? Looks simple enough but if there is a hidden snag of some sort? I guess you would have done this job before tranny mike,only problem i would imagine could be the crossmember mounting. Being in oz bits and pieces are harder to get so i need to be a step ahead.
Cheers
Old 02-25-2013, 05:46 AM
nomader's Avatar
nomader nomader is offline
Year: 1972
Model: Spirit
Region: 10(IL,MN,WI)
NECOA #: 14196
nomader will become famous soon enough
Garage
moose, I did this swap in my 72. It is a direct bolt on as far as bell housing and linkage. my cross member had to be relocated rearwards about 1 1/2 inch. I needed to drill 2 new holes. also the drive shaft had to be shortened 3 inches. The only heads up I can provide is attach the T/V cable before installing the trans. make sure the plastic collar is seated firmly in place or you will have a good sized leak. ( found this out the hard way) The cable can be installed with the trans in but it would be easier when out ( again I found this out the hard way)
I need to try something different. instead of putting something where it wont get lost I am gonna put it where I can find it
Old 02-25-2013, 11:44 AM
moose866's Avatar
Director, Region 25
Year: 1969
NECOA #: 23486
G'day Nomader,thanks for the reply mate. Had e feeling the crossmember would be an issue,the rest looks simple enough.Now that i definately know i'll make sure the drill is sharp before i get into it!
Cheers.
Old 02-25-2013, 11:45 AM
moose866's Avatar
Director, Region 25
Year: 1969
NECOA #: 23486
And thanks for the tip on the cable
Old 02-25-2013, 12:07 PM
moose866's Avatar
Director, Region 25
Year: 1969
NECOA #: 23486
And thanks to Keyser for running me through how to post!
You may not post new threads
You may not post replies
700r Bigcricket Transmission & Drive line 6 02-17-2013 02:23 PM
700R fit? dannyre Transmission & Drive line 8 09-16-2011 11:03 AM
700R Swap 71BlueprintElk Transmission & Drive line 13 03-05-2008 05:38 PM
200R-4 vs 700R-4 kettbo Transmission & Drive line 8 03-19-2006 05:52 PM
2004R VS 700R razor376 Transmission & Drive line 12 04-19-2004 12:43 PM
