System Advice (head unit and kick panels) - El Camino Central Forum : Chevrolet El Camino Forums
Go Back   El Camino Central Forum : Chevrolet El Camino Forums > General Topics > Audio
Old 02-25-2013, 10:52 AM
teamcurtis's Avatar
teamcurtis teamcurtis is offline
Member
Loose Nut
Year: 1964
Region: 18(CA)
NECOA #: 23596
teamcurtis will become famous soon enough
Garage
Default System Advice (head unit and kick panels)
I just got a 64 and Im looking to upgrade the stereo a bit and could use some input as to
What headunit to get (single din or retro sound original dash)
Which speakers to power with the amp (6.5 or 6x9)
I have...
-1 JL audio W1v2 sub in a sealed box (10")
-Kendwood 4 channel amp. (50x4 rms or 180x2 rms)
Variable high-pass filter (50-200 Hz, 12 dB/octave)
Variable low-pass filter (50-200 Hz, 12 dB/octave)
-Plastic kick panels with 6 1/2 speakers
-plates behind the seats with 6x9 speakers
-a crappy head unit in the glove box
My music choices are all over the map, but i prefer tight hitting bass to low rolling bass
I plan on running one set of speakers with the head unit, the sub and the other set with the amp.
Question 1
I'm torn between getting a mid/low level traditional single din head unit in the glove box, vs putting a retro sound stereo in the original dash spot.
A single din will have preamp outputs specifically for the sub. Will this make a big difference with the amp Im running?
Question 2
Do I put more power to the front speakers or will those plastic kick plates just flex if i drive a real speaker in that spot?
Ill prob replace which ever set of speakers I the amp to.
Ive had this amp running the same sub before and a set of component speakers and I liked the way it sounded. Im also only looking to spend a few hundred dollars.
'64 El Camino
383 stroker, dougs headers, roller cam, headers, 12 bolt posi 3.73
Old 02-26-2013, 10:46 AM
teamcurtis's Avatar
Member
Loose Nut
Year: 1964
Region: 18(CA)
NECOA #: 23596
Garage
nothing?
no audio freaks in here?
Old 02-26-2013, 12:23 PM
Ductape's Avatar
Ductape Ductape is offline
Motor Mouth
Year: 1979
Model: Caballero
Region: 16(CO,MT,WY,UT)
NECOA #: 18375
Ductape is a jewel in the rough
I have...
Question 1
Question 2
I would say that the head unit is up to you, whatever your peferance is. I really like the aftermarket one, cause they have set up for rca amp output.
Plus some of them have bluetooth ability, so you can use your phones in your car without having to take it out of your pocket.
As to the more power in the front speakers, I would put the front ones to the head unit, and power the back speakers with the amp. That way you would get better sound, and not be overbearing in the front of the car.
The amp, if its a 4 channel, should have rca inputs for front and rear channels, just be sure your head unit has dual outputs for the amp too. eiher front and rear or sub with another output will do just fine.
Good luck with the project.
Old 02-26-2013, 12:41 PM
teamcurtis's Avatar
Member
Loose Nut
Year: 1964
Region: 18(CA)
NECOA #: 23596
Garage
thanks for the reply.
so i guess i should be more specific
1) do any of the retro look units have good sound? (i know they all have 2 sets of rca out)
2) some units have 3 sets of RCA (front rear sub) some are just 2 sets and you use rear for the sub. Is a sub specific rca any better than using a rear?
Old 02-26-2013, 02:08 PM
psycho74's Avatar
psycho74 psycho74 is offline
Member
Twisted Wrench
Year: 1974
Model: El Camino SS
Region: 4 (MD,VA)
NECOA #: 22012
psycho74 will become famous soon enough
Garage
if you want tight fast bass try a 10 inch sub and be sure to follow the rules of amp wiring, never run the power anywhere near signal wires, you may be able to use your stock head if you like its features and the just run everything into a four Chanel amp and a mono block for the sub some amps have a high level input that will take the wires from the original speakers then output a higher power so you can go from a 12 or so watt to more like 55 + for each speaker, also be sure to match the ohm rating of the speaker to the ohm rating of the amp.
Old 02-26-2013, 03:05 PM
jlcustomz's Avatar
jlcustomz jlcustomz is offline
Year: 1983
Model: Caballero
Region: 6 (FL)
NECOA #: 19307
jlcustomz has a spectacular aura about
Audio will always be an opinionated subject, here's a few of mine.
Though I've never owned a retrosound type reciever, I think their geared more twoards non audiophile type people. I prefer a high end aftermarket reciever to do more of what I want. there are even some of them that you can hide the unit. I'm also old school in that I like an external passive eq with lots of control(real knobs), but that's just me. More sound control IS better, such as sub specific for sub.
On amps, I prefer those with a truer power rating & a large amp can be kept at a lower input level to keep distortion down. Big amps can give cleaner sound, not just louder.Speakers last longer with clean sound.Amps are always best run off a good rca signal as opposed to a high level signal which has more distortion from radio's amp.
For front kick panel speakers, I prefer component ones such as infinity kappa with separate tweeters which can be better aimed.
On rear 6x 9 s, separate the back of the speaker's airspace from the front, even if it's something simple such as carpet to do so.
On subs, sealed boxes are the tightest sounding, but not the loudest.Good boxes help. I did a downfiring setup in the 83 elco in the smugglers area.
On budget some places are always cheaper than others on good stuff, one local shop near me is cheaper than best buy on better versions of the same brands. I have some stuff from pawn shops, some from re-using. Have a 1988 infinity rsa450 amp still wearing out subs in my work truck. You can always improve & add on to a system later, better amp(s) , better speakers.
Hope this gives you some direction.
No true hot rod is ever finished. If it doesn,t command respect, fear will do.
Old 02-27-2013, 10:45 AM
teamcurtis's Avatar
Member
Loose Nut
Year: 1964
Region: 18(CA)
NECOA #: 23596
Garage
Quote:
did you read the main post?
  #8
Old 02-27-2013, 11:14 AM
teamcurtis's Avatar
Member
Loose Nut
Year: 1964
Region: 18(CA)
NECOA #: 23596
Garage
im not sure what to say to be more clear as to the advice im looking for
I have the amp, the sub and the box i will be using.
The questions are
1) a vintage look vs normal aftermarket headunit in the glove box.
sound
  #9
Old 02-27-2013, 11:20 AM
teamcurtis's Avatar
Member
Loose Nut
Year: 1964
Region: 18(CA)
NECOA #: 23596
Garage
grrrrr stupid computer
questions
1) a vintage look unit vs normal headunit int he glove box
-sound quality of the vintage styles
-is a true sub rca output any better than just using a rear channel rca output
2) which speakers to drive with the amp.
-one set will be run with the head unit, the other with the amp?
-can the plastic kickpannels house a good component speaker or will they just rattle and flex?
  #10
Old 02-27-2013, 03:12 PM
jlcustomz's Avatar
Year: 1983
Model: Caballero
Region: 6 (FL)
NECOA #: 19307
1 -Look is a matter of personal opinion. the retrostyled units don't REALLY look like an original radio anyway &are not as good of a sound quality as many of your normal units.
And yes, get a true sub output for a sub, most have independant volume level control & crossover control(usually 80/120 hz,some have more features to better control bass level sounds).
2- Plastic boxes should be fine, if not use some sound dampening material in them.Using what you have(4 channel amp) ,I'd run the sub off 2 channels, rear off other 2 channels, front off head unit for now, & consider later on getting a better amp for sub & using the kenwood for front & rear.
Sorry if I didn't properly answer you questions the first time{I kinda did). Was also trying to give you a little general advice based on 30 years of loud stereos.
  #11
Old 02-28-2013, 10:29 AM
teamcurtis's Avatar
Member
Loose Nut
Year: 1964
Region: 18(CA)
NECOA #: 23596
Garage
cool thanks, your answers were more focused than others
hopefully this weekend ill pull the speakers that are intalled and see what quality they are. Head unit too. Its a clarion, but i have no idea what model so it could be ok or total crap.
if im replacing the speakers and speaker boards behind the seat anyway, would you recommed using 6x9s or 6.5 components back there (front will be 6.5 2 ways)
  #12
Old 02-28-2013, 02:55 PM
jlcustomz's Avatar
Year: 1983
Model: Caballero
Region: 6 (FL)
NECOA #: 19307
6x9s are fine( more speaker area, more mid bass). Just remember what I said about the backside of the speakers being sealed off from the front . 6x9's generally sound more natural with a larger airspace ,as they usually have a trunk for a backside.
Modern recievers do have more features for the money than they used to, my 1988 jvc for $379 from crutchfield had dolby c for the cassette player. Clarion has some good stuff, I have their parametric eq in my work truck, which has a volume control to use instead of the head unit's & cuts down on amp noise at low volume. Some less expensive brands have some good products. Pioneer premier series is one I see around here.
  #13
Old 02-28-2013, 04:56 PM
jojothetattooboy's Avatar
jojothetattooboy jojothetattooboy is offline
Motor Mouth
Year: 1981
Model: El Camino SS
Region: 10(IL,MN,WI)
NECOA #: 22672
jojothetattooboy will become famous soon enough
Garage
[QUOTE=jlcustomz;471080]1 -Look is a matter of personal opinion. the retrostyled units don't REALLY look like an original radio anyway &are not as good of a sound quality as many of your normal units.
The Retro Sound Model 2 has the Subwoofer output with crossover and level control. The video on the website has a run through of the features on the display screen. It looks identical to my "modern" Alpine as far as features.
I don't want to cut the dash in my 1981 El Camino....the Retro Sound seems like a logical choice.
  #14
Old 02-28-2013, 05:11 PM
jlcustomz's Avatar
Year: 1983
Model: Caballero
Region: 6 (FL)
NECOA #: 19307
I,ve always heard that most older reto styled units weren't that great, hopefully most newer one's are.
Like Craftsman tools , it can vary who actually makes some of these things.
  #15
Old 03-01-2013, 09:23 AM
teamcurtis's Avatar
Member
Loose Nut
Year: 1964
Region: 18(CA)
NECOA #: 23596
Garage
one of the companies is actually fairly local to me. perhaps ill go take a listen in person.
or even power it thru my car without installing it.
I agree about cutting the dash. i would only do a non retro look in the glove box. leaving the stock stereo in place
You may not post new threads
You may not post replies
5th Gen Kick Panels O. D. Showtime Parts for sale 3 01-06-2011 05:55 PM
Rear kick panels In a '79 Madness Interior Restoration 3 12-06-2010 04:18 PM
custom kick panels for 6 1/2s 200chevyelky Audio 20 05-02-2006 02:03 PM
3rd gen interchangle kick panels ?? cleanelco Interior Restoration 2 11-15-2004 11:58 PM
Speakers in kick panels? Malice in Wonderland Electrical Systems 7 02-06-2004 11:51 AM
