No reverse - El Camino Central Forum : Chevrolet El Camino Forums
Old 02-25-2013, 12:30 PM
radioactive_rx's Avatar
radioactive_rx radioactive_rx is offline
Junior Member
NooB
Year: 1970
Model: El Camino SS
Region: 13(TX)
NECOA #: 23645
radioactive_rx will become famous soon enough
Default No reverse
I have a 70 SS that I've just droped a 454 I bought from a guy that had it in his slingshot dragster. The install went fine but the 400 short tail tranny is acting strange. I have forward gears. I am not sure the linkage is right but it pulls forward in every gear except Neutral. The best I can tell even reverse is pulling forward!
Is there something these drag racers do to these transmissions to eliminate the reverse? I have another 400 laying around but I am not excited about doing a tranny swap at this point. Any suggestions.
Old 02-25-2013, 12:33 PM
moose866's Avatar
moose866 moose866 is offline
Director, Region 25
Year: 1969
Region: 25 (ALL OTHER)
NECOA #: 23486
moose866 will become famous soon enough
G'day Steve,Icant answer your question but it sounds like you will be doing that tranny swap mate,
Cheers
Old 02-25-2013, 01:04 PM
Skandolis's Avatar
Skandolis Skandolis is offline
Year: 1977
Region: 14(AR,LA,MS)
NECOA #: 19697
Skandolis will become famous soon enough
i have had a th350 that the linkage was broken between the parking pawl and the shift valve that did that.........maybe something to check, one of the tranny gurus will likely join in soon to help ya out,
GL
77 Classic with one piece main 350, .60 over,Flattops, vortec heads, edelbrock single plane,2800 stall converter, 1-3/4 heddman headers,lt4 "hotcam", tbi running at 22psi ,3.73 gears custom tune with a lot of fuel and a scary amount of timing.......
Old 02-25-2013, 01:42 PM
minoridertim's Avatar
minoridertim minoridertim is offline
Site Contributor
Year: 1986
Model: Conquista
Region: 13(TX)
NECOA #: 19736
minoridertim has a spectacular aura about
Garage
Welcome Steve, from Tyler. I don't have your answer, but someone will shortly. Hope to meet you, and see your Elky at our annual gathering in Belton May 11th. Keep an eye on Region 13 forum for updates. Enjoy the site, and your cruck.
Tim
86 El Camino Conquista 1st and Only Owner (350, th350, 273 posi, 17mpg)
84 El Camino Conquista (cruiser)
Old 02-25-2013, 08:39 PM
TrannyMike's Avatar
TrannyMike TrannyMike is offline
Deputy Director, Region 18
Year: 1985
Region: 18(CA)
NECOA #: 18805
TrannyMike is of outstanding character
If it feels like pulls forward in neutral the forward clutch is engaged. Does the fluid smell burnt? It can have red fluid and still smell burnt. I've seen overheated plates warped and not being able to disengage.
Mike
Old 02-26-2013, 08:47 AM
Junior Member
NooB
Year: 1970
Model: El Camino SS
Region: 13(TX)
NECOA #: 23645
I dont think the fluid was burnt, but it was hard to tell since Ive replaced most of the fluid. The dipstick of course smells and looks clean.
Old 02-26-2013, 11:31 AM
TrannyMike's Avatar
Year: 1985
Region: 18(CA)
NECOA #: 18805
Have you dropped the pan to look for metal or clutch material? I neglected to answer your question about guys eliminating reverse for drag racing. The answer is no, reverse isn't removed. You've probably watched dragsters do their burn outs and then back up. You don't ever see them pushed back.
You may not post new threads
You may not post replies
Reverse went out kevinrom Transmission & Drive line 13 02-11-2013 08:28 AM
Muncie won't go into reverse burntove Transmission & Drive line 4 09-29-2012 04:20 AM
Goes in reverse:not forward dirtynails Transmission & Drive line 6 02-19-2009 06:49 AM
200-4R slipping in reverse dwinters Transmission & Drive line 0 01-16-2009 09:20 AM
no reverse amp88fan Transmission & Drive line 2 05-11-2008 01:20 PM
