'83 gauge gremlins - El Camino Central Forum : Chevrolet El Camino Forums
Old 02-25-2013, 12:49 PM
leadmine leadmine is offline
Member
Twisted Wrench
Year: 1983
Model: Caballero
Region: 5 (NC,SC)
NECOA #: 8413
leadmine will become famous soon enough
Default '83 gauge gremlins
'83 Caballero.Neither the coolant temp. gauge or the oil pressure gauge have ever worked very well:
Replaced oil pressure sender (for gauge) and gauge worked well for a few days and then pegged beyond 60 pounds as soon as ignition turned on; the indicator needle remains in that position. Tried disconnecting connector wire, and, grounding the wire - same result. Replaced the sender again, pulled a new wire from the sender to the printed circuit connector, bought reman gauge cluster. No change.
Same thing for temp gauge, except that it doesn't/never did register any temp change. Same replacements as above.
There is evidently some circuit problem beyond these two gauges, but I don't have a clue where or how to start testing. All suggestions will be greatly appreciated. It would probably be easier to install aftermarket mechanical gauges but I'm not throwing in the towel yet.
Thanks, leadmine
Old 02-25-2013, 02:50 PM
Scottm's Avatar
Scottm Scottm is offline
Site Contributor
Year: 1977
Model: El Camino Classic
Region: 13(TX)
NECOA #: 22827
Scottm will become famous soon enough
Garage
Have you tried the ground straps from engine to chassis? I just installed mechanical gauges since mine has idiot lights. I left one ground off and they all went hay wire. Also how aboout your printed circut?
See mine has a broken strand wich is the ground lead for the oil light.
Hope that helps
Farpotshket (Yiddish)
Something that is all fouled up, especially as the result of attempts to fix it–repeatedly making something worse while trying to fix it.
You may not post new threads
You may not post replies
electrical gremlins jarhead Electrical Systems 22 01-28-2013 06:33 AM
Gremlins in my 85 oemluath Electrical Systems 24 04-27-2012 07:15 AM
Site Gremlins? FIRST ELKY 4 ME General BS Topics 5 12-22-2010 06:13 AM
More Electric Gremlins MixedUp Electrical Systems 4 08-03-2004 02:47 PM
Gremlins in the wiring.... 81_64Caminoman Electrical Systems 5 10-15-2003 06:50 PM
