Heater control panel - El Camino Central Forum : Chevrolet El Camino Forums
Old 02-26-2013, 04:01 PM
Asymmetrix Asymmetrix is offline
Junior Member
NooB
Year: 1977
Region: 19(AK,ID,OR,WA)
NECOA #: 23475
Asymmetrix will become famous soon enough
Default Heater control panel
So, I have just about finished installing my ac delete kit. Now that I have removed all of the AC components, its seems silly to keep the AC control panel in the car. Can I just install a panel from a model that didnt have AC, and if so, is it just remove the old one and install the new one, or is there different wiring, etc that I need to worry about? Also, if so, where do you think I could find one. The junkyards out here suck for my 77.
Old 02-26-2013, 05:20 PM
Skandolis's Avatar
Skandolis Skandolis is offline
Year: 1977
Region: 14(AR,LA,MS)
NECOA #: 19697
Skandolis will become famous soon enough
if you can find one the non ac control panel should be a direct swap, if you don't mind my asking, where did you get the delete kit?, what all came with it? i have been considering deleting the ac on my 77, i don't use it and it would free up a lot of space under the hood/dash, and make a spot for a second alternator. i was intending to just make a new heater/blower plenum and get rid of the monster box under the hood, but if i can find something premade i might prefer to go that way.
77 Classic with one piece main 350, .60 over,Flattops, vortec heads, edelbrock single plane,2800 stall converter, 1-3/4 heddman headers,lt4 "hotcam", tbi running at 22psi ,3.73 gears custom tune with a lot of fuel and a scary amount of timing.......
Old 02-26-2013, 06:04 PM
ccured ccured is offline
Motor Mouth
Year: 1978
Region: 5 (NC,SC)
NECOA #: 9545
ccured will become famous soon enough
Quote:
Never worked with them but I know a delete.com has a body kits. $350-$375 iirc. Think it comes with heater core , blower fan and motor and panel. Looked at it for my gbody
Old 02-28-2013, 11:36 AM
Junior Member
NooB
Year: 1977
NECOA #: 23475
http://acdelete.com/
Crazy simple install too.
Old 03-05-2013, 12:00 PM
bdbaggr bdbaggr is offline
Junior Member
Member
Year: 1985
Model: El Camino SS
Region: 18(CA)
NECOA #: 23662
bdbaggr will become famous soon enough
im in need of a part inside the control panel, the lever stuck so i took apart the heater/ac controls and found a semi round plastic gear that separated and locks the levers up. if you have an assembly in working order let me know and ill buy it from you. im having trouble locating an exploded view to identify the exact part. thanks! tim
You may not post new threads
You may not post replies
ac/heater control knob bdoggelectric Heating & Air Conditioning Systems 2 06-30-2010 03:20 AM
heater control valve 85elky85 Heating & Air Conditioning Systems 2 10-24-2007 02:35 PM
83-87 AC/Heater Control 87SS Ebay / Craigslist Alert 0 12-29-2005 10:06 AM
blue corner on the Heater Control Panel 8baxter8 Heating & Air Conditioning Systems 1 06-20-2005 04:21 AM
78-87 taillights and non-ac heater control panel spy007 Ebay / Craigslist Alert 0 05-22-2005 02:31 PM
