Who knows where this hose goes? - El Camino Central Forum : Chevrolet El Camino Forums
Old 06-26-2013, 07:53 PM
Mrbud's Avatar
Mrbud Mrbud is offline
Motor Mouth
Year: 1982
Model: El Camino SS
Region: 9 (IN,KY,MI)
NECOA #: 14758
Mrbud will become famous soon enough
Default Who knows where this hose goes?
I just finished putting valve seals on my 82 and Have this small hose left over. Can't seem to find a place for it. Believe it's for the AC Control panel. Also How much coolant does it take to refill AC after a Vacuum Out of the system? Thanks for any answers in advance Bud
1982 El Camino
Original 305 Upgrade cam
Holley Port Fuel Injection
Choo Choo Conversion Package
1949 Chevy Sport Coupe
Camaro Clip 327 30 over
Holley 4 barrel
1940 Dodge Coupe in Progress
318 with a 727 auto
Small Stable
Old 06-26-2013, 08:06 PM
rnhart3's Avatar
rnhart3 rnhart3 is offline
Year: 1979
Region: 2 (CT,MA,ME,NH,RI,VT)
NECOA #: 17856
rnhart3 will become famous soon enough
Garage
pic?
Jim
1979 El Camino, retired daily-driver,
current frame-off resto project
1986 Monte SS, mild 350, headers, elec cooling
fan,"A" Pillar gauges, subtle
modifications to transmission, #3 son is a trans tech...
1986 Monte SS T-Tops, for parts...
1985 El Camino
1986 El Camino
1991 S10 pick-up
1997 Chevrolet Tahoe 2 dr.
1981 Malibu wagon with 9C1 drivetrain...parts?...or drive?
"Too many parts cars to mention....."
Old 06-27-2013, 05:20 AM
Mrbud's Avatar
Motor Mouth
Year: 1982
Model: El Camino SS
NECOA #: 14758
You are right that would help
http://tinypic.com/r/2i7n7f5/5
Old 06-27-2013, 05:37 AM
HP11's Avatar
HP11 HP11 is offline
Year: 1983
Model: Conquista
Region: 18(CA)
NECOA #: 21671
HP11 has a spectacular aura about
Garage
If I recall correctly, that one goes to the water control valve in the heater hose. It's early. I'll go out and check later if no one has confirmed it by then. If you copy and paste the IMG code from tinypic, it will show up in your post. Like this:
2005 Pontiac GTO (My Car)
2004 Ford Ranger EDGE Supercab (My Daily Driver)
2010 Mercedes Benz C300 Sedan (Wife's Car)
2014 Kia Rio LX (Wife's Daily Driver)
Certified HVAC/MVAC technician. (retired)
Old 06-27-2013, 06:50 AM
gilby's Avatar
gilby gilby is online now
Year: 1974
Model: El Camino Classic
Region: 18(CA)
NECOA #: 10426
gilby has a reputation beyond reputegilby has a reputation beyond repute
Garage
Quote:
http://i44.tinypic.com/2i7n7f5.jpg
...X 2 on the water valve for the heater..
..1974 Conquista
..1979 GMC Caballero
..2003 Impala
..2015 Spark
Old 06-27-2013, 09:55 AM
Mrbud's Avatar
Motor Mouth
Year: 1982
Model: El Camino SS
NECOA #: 14758
This is what is hooked to the Heater valve now looks like it goes down below. Havn't followed it down yet
Old 06-27-2013, 10:56 AM
JJLT1's Avatar
JJLT1 JJLT1 is offline
Year: 1985
Model: El Camino SS
Region: 13(TX)
NECOA #: 12122
Garage
I don't know maybe the efe at the end of the pass side exhaust manifold..
can you trace it out??
JJ
  #8
Old 06-27-2013, 11:04 AM
HP11's Avatar
Year: 1983
Model: Conquista
Region: 18(CA)
NECOA #: 21671
Garage
Quote:
I have no idea what that meansbut the line in question connects to the heater valve. If you follow that plastic line from the heater valve, I'll bet it has a piece of vacuum hose on the end that connects to the one in the original picture. That's how mine is.
  #9
Old 06-27-2013, 05:25 PM
Mrbud's Avatar
Motor Mouth
Year: 1982
Model: El Camino SS
NECOA #: 14758
I'll Trace it down tomorrow see what it is hooked to should There be a t connector there?
  #10
Old 06-30-2013, 08:29 PM
Mrbud's Avatar
Motor Mouth
Year: 1982
Model: El Camino SS
NECOA #: 14758
Finally, Got time to check it out They had the heater valve hooked to this it is a 3 inch size can with a linkage is this to have vacuum line run to it instead? also what is it? is it for the transmission?
[/IMG]
  #11
Old 06-30-2013, 09:21 PM
JJLT1's Avatar
Year: 1985
Model: El Camino SS
Region: 13(TX)
NECOA #: 12122
Garage
I believe that's the EFE,, its a valve in the exhaust pipe that closes to heat the intake/carb. up faster..
  #12
Old 07-01-2013, 04:36 PM
Mrbud's Avatar
Motor Mouth
Year: 1982
Model: El Camino SS
NECOA #: 14758
Thank You JJLT1, So if I have the smog off and I'm now running a Holley Throttle body injection system. I can leave this unhooked or should I still have vacuum running to it to keep it working so it won't stick?
  #13
Old 07-01-2013, 05:40 PM
JJLT1's Avatar
Year: 1985
Model: El Camino SS
Region: 13(TX)
NECOA #: 12122
Garage
yea you can leave the efe can unhooked,, if you don't have to deal with emissions??
I would just check to see if it is stuck or not,, I think they have a spring in them to open the valve..
just let it stay open all the time..
normally it would only need vacuum from a thermal switch when the motors cold..
your throttle body probably warms up ok..
it probably doesn't go to that first hose pic,, like Hp11 said.. hook it to the heater control valve..
  #14
Old 07-01-2013, 08:20 PM
Mrbud's Avatar
Motor Mouth
Year: 1982
Model: El Camino SS
NECOA #: 14758
Ok Thanks. For the help Need a new small hose off the Heater Valve. the old one was brittle and broke when I connected them. Will check the spring. Thanks Bud
Quick Reply
Message:
Smilies
Options
Register Now
User Name:
Password:
Confirm Password:
Email Address
Email Address:
Postal Code
Required
Street Address
City
Your city or town
State or Province
Required
Location area within State
Country
Required
NECOA Region
Required
Year of Vehicle
Required
Make of Vehicle
Required
Model of Vehicle
Required
Real Name
Insurance
Log-in
Human Verification
You may post new threads
You may post replies
Hose candy SAL79ELCO Product Review 3 07-29-2012 09:22 AM
do i need a new radiator hose? 84elcoconquista Engine Topics 11 05-26-2012 08:49 PM
Upper rad. hose to use runneroad Engine Topics 5 11-28-2011 09:40 AM
new guy ? about pcv hose. 45rpmdude For New Forum Members Only 7 08-08-2010 05:09 AM
87 Heater Hose TEE????? vtakiaman Heating & Air Conditioning Systems 4 03-01-2009 06:01 AM
