Guages Don't work - El Camino Central Forum : Chevrolet El Camino Forums
Old 09-23-2004, 05:53 AM
Bloodline Bloodline is offline
Member
Loose Nut
Year: 1980
Model: El Camino Classic
Region: 21(CANADA (W. of ONT.))
NECOA #: 3874
Bloodline will become famous soon enough
Default Guages Don't work
Well after about a month of dealing, I finally got my El camino - 1980. Now, to start dealing with some of the problems. None of the factory guages work with the exception of the fuel guage and the speedo which does not record accurate speed - reads to high. The motor and tranny was converted from the factory equipment to a 396 cu.in. along with( I believe) a 350 transmission. Could it be that the guages are simply not hooked up? wiring harness changed? or do I need to replace the factory guages with after market guages? I have not really investigated the problem yet as I just picked up the Elky last evening. Grate to be an owner and any help would be much appreciated.
Old 09-23-2004, 06:06 AM
John Harris's Avatar
John Harris John Harris is offline
Past National Director
Year: 1983
Region: 2 (CT,MA,ME,NH,RI,VT)
NECOA #: 78
John Harris has a spectacular aura about
Garage
Welcome to the club, Robert. And welcome to the world of frustrating electrical problems! These are fairly common on 5th generation Elky's, and instrument clusters are right up there!
A wealth of info has been posted previously by our members and is here for you to read. Just click on "forums" at the top of our home page, and it will take you to past postings by folks who have solved similar problems. Go down to "Chassis and Body" and then find the sub-group "electrical". Find the several threads that mention guages and/cluster in the title and read on until you find the answers you need.
After you have exhausted this method, feel free to ask specific new questions about your problem and what you are doing. But I'm sure you'll find everything you are looking for.
While you are at it, remember the famous words of our 5th Generation Moderator, Ernie G.: "Search is your friend." Again, welcome!
Old 09-23-2004, 08:19 AM
John_Muha John_Muha is offline
NECOA #: 534
John_Muha will become famous soon enough
Since the fuel gage works and the engine was swapped out:
Guessing that the temp and oil senders, on the 350 engine are wrong. The fuel gage wouldn't be affected by the engine swap but the other 2 gages would. Chances are that the 350 engine contains idiot light senders and not gage senders.
Try taking the wire off the oil sender and grounding it (Key on). See if the oil gage starts moving around.
Old 09-29-2004, 08:36 PM
greywolf greywolf is offline
Year: 1984
Region: 12(MO,OK,KS)
NECOA #: 64
greywolf will become famous soon enough
Also in my car gage problems were caused by the connector that plugs into the back of the instrument cluster. When you pull the cluster you'll see how the connector is just copper tabs that ride on uninsulated tabs on the printed circuit. A shot of electrical contact cleaner (from Radio Shack) and gentle rub with scotch brite got the gages working fine.
As long as you have the instrument cluster out, check out the other threads here about improving the lighting on the gages -- paint the back of the black face panel with silver or white paint.
And welcome to the club...
You may not post new threads
You may not post replies
more guages??? JDCamino82 General BS Topics 4 01-05-2006 07:41 PM
Guages Miguel Interior Restoration 8 03-09-2005 10:10 PM
82 circle guages to older rectangle guages help dark_saterday Interior Restoration 1 01-18-2005 09:05 AM
1960 Guages Tazman Interior Restoration 0 06-07-2004 04:22 AM
guages crazy kc4mnp Electrical Systems 4 04-22-2003 08:14 AM
