Looking: How fast - El Camino Central Forum : Chevrolet El Camino Forums
Old 12-02-2004, 02:04 PM
black93scort black93scort is offline
Junior Member
Gear Head
NECOA #: 4401
black93scort will become famous soon enough
Default Looking: How fast
Okay im looking at 1980 el camino with 350. They got the 350 froma 79 chevy truck I guess and its pretty much stock. Has dual exhaust (glasspacks) 4 barrel carb and a edelbrock intake. I want a car that can actually give people a good run. Im not expecting 12's but maybe mid 13 or 14's. Can someone estimate what my cars running now? good way to loose weight and get more horsepower. How much does a camino weigh? Do they weigh a lot compared to other v8s of the time or about average?
Old 12-02-2004, 03:47 PM
Mrapii's Avatar
Mrapii Mrapii is offline
Venerated Member
NECOA #: 2314
Mrapii has a spectacular aura about
You are probably looking at a 15-16 sec car assuming it still has the stock trans and rear axle. 5th Gen Elkys weigh around 3600 lbs and if you intend on using it on the street there is not much you can do to lighten it. All of the normal hotrod techniques: cam, heads, compression will increase the power but the quick and dirty is NOS. A 125hp shot will get your car into the 14s and with better gearing and a good cam maybe even into the 13s.
1979 El Camino\r\n1955 Chevrolet Del Ray\r\n1962 Corvette\r\n1966 Corvette Coupe
Old 12-02-2004, 04:19 PM
Junior Member
Gear Head
NECOA #: 4401
does it weigh about the same as mailbus of the time?
Old 12-02-2004, 04:33 PM
Junior Member
Gear Head
NECOA #: 4401
Oh I forgot to mention it has a shift kit if that helps it at all
Old 12-02-2004, 07:00 PM
12seccamino's Avatar
12seccamino 12seccamino is offline
Year: 1985
Model: El Camino SS
Region: 3 (DE,NJ,PA)
NECOA #: 3909
12seccamino will become famous soon enough
I have been around racing my entire life and I have seen many engine/trans/car combos. I would say you would be looking at 15 seconds 1/4 mile time. Add some headers, MSD ignition, and ignition timing, and you should be able to get it into the upper 14 second range. Just my guess, El Camino's about 3600lbs so the weight make it much harder to run 12's. good luck -Matt
Outta Control High Performance Customs
check out my El Camino and vote!
1985 Custom El Camino, 383ci w/Nitrous, th350, and 3:42 GN rear.
1992 GMC Typhoon, lots of goodies
2005 CBR 600RR
Old 12-02-2004, 08:51 PM
Junior Member
Gear Head
NECOA #: 4401
It might already have msd to not sure, ill go check tonight, I planned on a better exhaust system with headers, maybe a hydrualic cam? or just another cam dont know much about cams but yes to headers and maybe take the heads already on it and get them ported and polished. then try to reduce weight a little, fiberglass stuff I guess and definitely diff rearend. The gas is really hard because the throttle cable spring or whatever is hook from the carb to a loop on the engine that you use to hoist it so it really hard to push the gas down but when it shifts it will get up and go. I was thinking 3.73 gears I had them my mustang and they worked great
Old 12-02-2004, 08:57 PM
PPhem PPhem is offline
NECOA #: 1205
PPhem will become famous soon enough
i thought they were 3400 pounds
<('.'<)(^'.'<) (^'.'^) <( '.' )> (^'.'^) (>'.'^)(>'.')> EVERYBODY DANCE!!!
  #8
Old 12-02-2004, 10:07 PM
Year: 1985
Model: El Camino SS
NECOA #: 3909
It depends on the options. Power windows/locks, A/C transmission type all ad weight. My Stock '85 with no power options was 3590, and my 85 SS with every option was 3670 . I guess a no optioned V-6 base model would probably be about 3400-3500lbs.
  #9
Old 12-02-2004, 10:59 PM
SoSlowSS SoSlowSS is offline
Member
Loose Nut
NECOA #: 3941
SoSlowSS will become famous soon enough
If you want to go with fiberglass for weight reduction go to www.up22.com. I'm, personally looking at putting the whole fiberglass front clip and fiberglass tailgate on my car but being a poor 16 year old I'm gonna have to do alot of saving up lol. Also 3:73 are really good gears and I would say get those, but i have no clue what gears came in the 5th gen. As of right now i would say your car is good for probably a high 15 sec pass. Just my 2 cents
Landon
1970 Hell Camino
Out prowlin the streets, but strictly on an LT-1 and mustang diet (LS-1s are next)
I'd rather drive a honda instead of a ford because at least then I have an excuse to be slow
  #10
Old 12-02-2004, 11:52 PM
dennis68 dennis68 is offline
NECOA #: 2629
dennis68 will become famous soon enough
Glass parts suck on street cars. Unless you are SERIOUS about building a 1/4 mile car I wouldn't even consider glass parts. They don't save that much weight.
  #11
Old 12-03-2004, 12:15 AM
Junior Member
Gear Head
NECOA #: 4401
Only problem with the car is the steering is really loose. They got a steering wheel from a older camaro. I was told el caminos are heavy compared to other v8s. I figured theyd be lighter because they dont have back seat or snything like that. Are the much heavier then 80 model malibus. How much weight can I expect to loose on elcaminos with normal weight reductions, ac removal fiber glass hood, maybe remove the tailgate. If it has a decent 350 and the stock rearend should it be able to do a good burnout?
  #12
Old 12-03-2004, 11:39 AM
Mrapii's Avatar
Venerated Member
NECOA #: 2314
Malibus of the same vintage were lighter. Your idea of losing enough weight to make the Elky into a dragstrip terror is pure fantasy. What you need is better rear gearing and more power.
  #13
Old 12-03-2004, 11:46 AM
Junior Member
Gear Head
NECOA #: 4401
Im not expecting it to be loose like 500 pounds im just wondering if people are exaggerating how heavy the el camino is compared to other car.
  #14
Old 12-03-2004, 12:59 PM
Mrapii's Avatar
Venerated Member
NECOA #: 2314
What people and compared to what cars? It was a lightweight compared to a 1980 Cadillac DeVille but a porker compared to a 1980 Vega. I think you will find that practically everyone on this forum didn't really consider weight when choosing their Elky, we were primarily looking for a vehicle with unique styling. You realize of course that the 5th Gen El Camino still had body-on-frame construction when most similar cars of that period had lighter (but less desirable) unibody construction. If lightweight performance is your primary goal I would choose another vehicle.
  #15
Old 07-26-2012, 05:01 PM
BadNursie BadNursie is offline
Junior Member
Member
Year: 1985
Model: El Camino SS
Region: 19(AK,ID,OR,WA)
NECOA #: 22212
BadNursie will become famous soon enough
Well, all I can tell you is that my '85 rolls empty from the dump scale at just under 4,000 pounds, with a full tank and my fat but. Now, I don't weigh 400 pounds, so I'm guessing net weight, without fuel and me, would be about 3600. You could easily look it up.
If our friend wants a drag racer, then it's not so much the car as it is what you intend to do. A real drag strip terror requires a lot more than a big honking engine and four speed. By the time you deal with chassis issues, radiusing the wheel wells for big tires, and on and on, you might as well just get a tube chassis racer and have done with it.
I converted me stock set up (the 267? v8 and th350 were orig) to a 'truck' block 355 with Street & Performance TPI conversion kit. I couldn't pass my local smog inspection with the stock set up ('computer' carb) and it would have cost me nearly as much to repair that system as it was to go to the TPI. Naturally, I sail through the test, since I'm being tested as an '85 but my set up (currently) is more-or-less an '87 TPI Corvette induction w/ S&P's custom LT1 chip (no charge for me, an original customer, although it was like ten years later. Yes, S&P is good folks.) I've got headers, single cat, single 3" exhaust; roller valve train/cam w/ world heads (72cc combustion chambers for a est. 9:1 compression), adjustable fuel pressure reg., etc. 700R4 trans w/ stage II kit, 3.73:1 rear.
No, I don't drag race it, I haul stuff with it. My mechanic guesses we're in the 325-350HP, but unless you know where to get free dyno time, it's anybody's guess. The car moves out fast, will haul it 1000lb. limit uphill w/ no hard breathing, and I'm rarely embarrassed on the freeway on-ramp.
So, it depends on your goal here. I want a nice driving car. I get reasonable gas milage, about 20 in town, empty, maybe 25+ on the highway. I've power windows, a/c (when I can afford to keep it working) and a few suspension goodies. For an instant handling improvement (night/day) have a chassis shop install a set of urethane bushings. That and some proper shocks/springs will give you a different ride. I installed the police/taxi quick ratio steering box (I think the code is FE) and my car steer like no other Elky on the planet with this set up. I'm starving so as to buy a Hotchkiss rear suspension kit.
When it comes to spending money on your ride, the only limit is your bank account and credit. Nope, you won't sell it for a profit, either.
Good luck.
Quick Reply
Message:
Smilies
Options
Register Now
User Name:
Password:
Confirm Password:
Email Address
Email Address:
Postal Code
Required
Street Address
City
Your city or town
State or Province
Required
Location area within State
Country
Required
NECOA Region
Required
Year of Vehicle
Required
Make of Vehicle
Required
Model of Vehicle
Required
Real Name
Insurance
Log-in
Human Verification
You may post new threads
You may post replies
Need help fast! greygoose Engine Topics 4 03-18-2007 10:45 PM
need help fast!!! Jon_Lyle Electrical Systems 7 01-22-2007 04:25 PM
How fast is your 454 lS5 ? Ruti General BS Topics 19 06-17-2006 02:24 PM
Cold start-fast idle too fast - where is adjustment jjx Engine Topics 2 01-07-2006 03:37 PM
How fast.... Snaggle To0th General BS Topics 2 03-19-2005 10:40 AM
