heater core replacement help - El Camino Central Forum : Chevrolet El Camino Forums
Old 01-26-2005, 06:02 PM
200chevyelky 200chevyelky is offline
Motor Mouth
NECOA #: 4657
200chevyelky will become famous soon enough
Default heater core replacement help
what is the easiest way to replace the heater core. the one with less cussing
200v6 1979 el camino. changed my mind i'm going with a 350 for my elky
Old 01-26-2005, 09:12 PM
spoonplugger spoonplugger is offline
Year: 1986
Model: Caballero
Region: 7 (AL,GA,TN)
NECOA #: 1271
spoonplugger will become famous soon enough
There ain't no best way nor easy way. The only model avialble requires more cussin.
86 caballero, 350 cid, TH350C
Old 01-26-2005, 09:42 PM
396driver 396driver is offline
Motor Mouth
NECOA #: 2560
396driver will become famous soon enough
recently, I took out the inner fender-well on a 70 camino for exhaust manifold replacement without removing the fender. While peering up under the fender, I could see the blower motor and the nuts to the heater core cover. I think, although i've not done this, that the easiest way to change the heater core would be to remove the inner fender well; it's about 9 or 12 bolts, but first take out the battery. I believe once the nuts are removed from the heater core cover in the engine compartment, then the heater core enclosure could be removed on the inside of the car and the core then replaced (drain and disconnect hoses first no doubt - oh yea, remove rim).
Ok, granted I've not done this yet, but maybe someone could agree or disagree with my theory.
1970 El Camino 396 SS - Fantom Blue (was white - it's now blue again),
blue interior bench, factory posi, TH400
1970 El Camino 396 SS - Emerald Green
black interior buckets, TH400
Old 01-27-2005, 04:20 AM
Bobs 81 Bobs 81 is offline
Motor Mouth
Year: 1981
Model: Conquista
Region: 9 (IN,KY,MI)
NECOA #: 1510
Bobs 81 will become famous soon enough
You didn't say if you had Air or not. If you have Air, It'll take you about an hour. without Air, about a half hour. All work is done without removing the inner fender. (unless you need to remove the AC box for other reasons.) Core without Air, about $20. with Air about $35 as I recall. I changed two of my Elcamino 5 th gen this past year, one with Air, one without. For more info on the 'how to's ', check out the 'Search' here on the site. Hope this helps Bob
81 conquista 350-700r4, changed frame, yr 7 of 3 yr pr
81 229
78 EC 305 2bbl 700R/4 daily driver
Central lower Michigan
Old 01-27-2005, 08:51 AM
7d8ss's Avatar
7d8ss 7d8ss is offline
Year: 1978
Model: El Camino SS
Region: 8 (OH,WV)
NECOA #: 31
7d8ss has a spectacular aura about
Try typing "heater box" into the search engine
Z15 EL
NECOA Member#31
ECC Member#13
13.664 @ 100.56 ~ Gallery
Old 01-27-2005, 03:10 PM
Mrapii's Avatar
Mrapii Mrapii is offline
Venerated Member
NECOA #: 2314
Mrapii has a spectacular aura about
On a 5th Gen do not remove the fenderwell. The job is pretty straightforward and consists of removing the top part of the HVAC box.
Some tips: be careful about prying off the top of the HVAC box because there are some screws that are hidden and hard to find. Three large nuts that hold the top to the firewall are accessed by removing the wiper arms and lower windshield trim. Good luck.
1979 El Camino\r\n1955 Chevrolet Del Ray\r\n1962 Corvette\r\n1966 Corvette Coupe
Old 01-27-2005, 06:21 PM
Motor Mouth
NECOA #: 2560
Hmmm. I guess my theory is all wet, but wait, is it true for 70 that the inner well does not have to be removed to get to the nuts holding the cover of the heatercore. I ask because I can't see some of the nuts until I remove the inner fender well.
Oh yea, the reason I removed the inner fenders to replace the exhaust manifold was because I wanted to repaint the sides of the engine without the manifolds attached, and it was far easier without the inner fenderwells.
  #8
Old 01-27-2005, 06:26 PM
John Harris's Avatar
John Harris John Harris is offline
Past National Director
Year: 1981
Model: Caballero
Region: 2 (CT,MA,ME,NH,RI,VT)
NECOA #: 78
John Harris is of outstanding character
Garage
Winter is a great time to remove those inner fender wells and clean them up and repaint. If you've got them out, now is the time to do so. You won't believe the difference it makes in your appearance. You can see the before and after in my photo album on the third page. A real low cost improvement, for sure.
  #9
Old 01-27-2005, 07:42 PM
Motor Mouth
Year: 1981
Model: Conquista
NECOA #: 1510
Your OK 396driver, the original post here was for a fifth gen. and for those, you don't need to pull the inner fender to replace the core. Only if your going to pull the whole AC box. Hope this clears that up. Bob
  #10
Old 01-27-2005, 10:31 PM
Motor Mouth
NECOA #: 2560
thanks
  #11
Old 01-28-2005, 04:17 AM
87ElCamino 87ElCamino is offline
Year: 1987
NECOA #: 560
87ElCamino has a reputation beyond repute87ElCamino has a reputation beyond repute87ElCamino has a reputation beyond repute87ElCamino has a reputation beyond repute87ElCamino has a reputation beyond repute87ElCamino has a reputation beyond repute
Quote:
Originally Posted by Bobs 81
... a fifth gen. and for those, you don't need to pull the inner fender to replace the core. Only if your going to pull the whole AC box.
That's right. It's all been discussed here previously. Biggist tip I can give is: If you're absolutely positive you have removed all the screws, and the top still won't budge, don't try to pry the top off, find the rest of the screws holding it down. BTDT Good luck.
Search is your friend.
  #12
Old 01-28-2005, 07:59 PM
Motor Mouth
NECOA #: 4657
thanks for the info i'll be changing it out this week end. hopefully it will go good
Quick Reply
Message:
Smilies
Options
Register Now
User Name:
Password:
Confirm Password:
Email Address
Email Address:
Postal Code
Required
Street Address
City
Your city or town
State or Province
Required
Location area within State
Country
Required
NECOA Region
Required
Year of Vehicle
Required
Make of Vehicle
Required
Model of Vehicle
Required
Real Name
Insurance
Log-in
Human Verification
You may post new threads
You may post replies
Heater Core Replacement - 68 elcam caminojunkie Heating & Air Conditioning Systems 6 03-05-2011 07:27 AM
87 heater core 86 Pace Car Heating & Air Conditioning Systems 9 08-21-2009 06:36 AM
82 heater core questions Isagani Heating & Air Conditioning Systems 4 11-14-2005 06:51 PM
Heater Core 2HF Heating & Air Conditioning Systems 3 09-30-2004 05:23 PM
Heater Core for a 75 JDLCam Heating & Air Conditioning Systems 3 12-02-2003 05:43 PM
