lt1 radiator/coolant lines???? - El Camino Central Forum : Chevrolet El Camino Forums
Old 03-23-2005, 03:56 PM
kender kender is offline
Member
Knuckle Buster
NECOA #: 1823
kender will become famous soon enough
Default lt1 radiator/coolant lines????
I'm doing a 95 lt1(camaro) swap into an 80 elky. I have gone through the helm manual and have just found out that the lt1 has 4 coolant line running to the radiator from it ( not including the resivoir bottle) there are 3 from the water pump( 2 large and 1 small) and 1 from the throttle body. aside from getting a 95 camaro radiator what can I do to still use the stock elky radiator. also I have the heater flow control valve for the lt1 and it has 3 ports for coolant and one vacum port??? what do I do with these.
thanks for the info.
Go Hard Or Go Home !!!
Old 05-23-2005, 02:49 PM
Elcaminoss31316 Elcaminoss31316 is offline
Member
Motor Mouth
NECOA #: 1690
Elcaminoss31316 will become famous soon enough
.. I'd recommend you use the radiator from a 3rd gen f-body (i.e. 91' Z-28 ) Aluminum and works much better.. bolt in deal.. Modine 951 at the parts store!
Anyhow.. The thermostat exit goes to the lower nipple on your radiator while the exit cast into the water pump goes to the upper.. Don't run a hose to the Throttle Body.. excess heat, you don't need it! Run that to the nipple of the radiator just below the overflow nipple/ cap.. That hose comes from the back of the heads to prevent steam pockets!
There are three smaller nipples on the water pump.. the two that are on the left side of the pump as your facing the motor are for the heater core, hook them up like your factory ones did.. the one on the lower right, under the cast exit, can be blocked off.. I've run one like that without problem...
Have fun and Good Luck!
Tom
80' Elky (IROC SS) 430hp - T56 6-spd
96' Cadillac STS Diamond White
02' X1 Sportster
Old 05-30-2005, 08:30 AM
STIR CRAZY's Avatar
STIR CRAZY STIR CRAZY is offline
Member
Knuckle Buster
Year: 1959
Region: 18(N.CA,N.NV)
NECOA #: 3030
STIR CRAZY will become famous soon enough
Default COOLANT LINES
I put a LT-1 in my 59. if you look in the gallery of my motor you will see I made a bypass that runs directly into the upper radiater hose so you can run your stock radiater.
You may not post new threads
You may not post replies
coolant leak ELBMINO Engine Topics 15 09-25-2008 11:05 PM
How much liquid coolant?? Uli Engine Topics 9 07-27-2008 09:09 PM
Coolant from radiator being blocked??? ElCamino65 Engine Topics 4 01-21-2008 06:35 AM
Fine lines now repro's metal air shock lines for 70-72 elkys resq302 Body Restoration 1 07-13-2006 06:34 PM
coolant reservoir PunkRican General BS Topics 2 03-21-2004 05:42 PM
