Hood bumpers on G body - El Camino Central Forum : Chevrolet El Camino Forums
Notices
Old 11-05-2019, 04:17 PM
Wolfgang's Avatar
Wolfgang Wolfgang is offline
Year: 1980
NECOA #: 89038
Wolfgang will become famous soon enough
Default Hood bumpers on G body
Body shop removed and lost them . I can buy new ones. But what do they thread into.
Old 11-05-2019, 04:40 PM
78 Elk's Avatar
78 Elk 78 Elk is offline
Year: 1978
Region: 19(AK,ID,OR,WA)
NECOA #: 3102
78 Elk is a name known to all
Mine has a threaded square clip that pushes into the radiator support.
hagensen78
Old 11-05-2019, 04:41 PM
Russ Camino's Avatar
Russ Camino Russ Camino is offline
Torque Wrench
Region: 3 (DE,NJ,PA)
NECOA #: 90036
Russ Camino will become famous soon enough
Cool
Hi Leonard In my opinion the body shop should buy them
and replace where they go. Just my two cents. Russ
Old 11-05-2019, 04:44 PM
78 Elk's Avatar
Year: 1978
NECOA #: 3102
I agree the shop should take care of the problem, they made.
Old 11-05-2019, 05:45 PM
LilBrownJug's Avatar
LilBrownJug LilBrownJug is offline
Senior Member Site Supporter
Name: Chuck and Jane
NECOA #: 90002
LilBrownJug is on a distinguished road
Probably Macco what a waste there ..They have inclusions dips, orange peel , runs, you name it they ain't at fault.
There are no rocks on the road,,, unless you are bare foot!
Old 11-05-2019, 06:15 PM
kstmbowtie's Avatar
kstmbowtie kstmbowtie is offline
Year: 1980
NECOA #: 17632
kstmbowtie will become famous soon enough
I've seen multiple styles listed for sale online. I see you have an 80 as I. Here is a pic of where mine are located. Don't look at the mess of wires. Those have all been tidied up.
Sent from my SM-G950U using Tapatalk
Old 11-05-2019, 06:44 PM
Wolfgang's Avatar
Year: 1980
NECOA #: 89038
Let's make this clear . My car was not painted at Maaco and I will put this paint job on my car up against the best
Old 11-05-2019, 07:10 PM
Wolfgang's Avatar
Year: 1980
NECOA #: 89038
A little off the subject. Does this look like Maaco.
Click image for larger version
Old 11-05-2019, 10:53 PM
jlcustomz's Avatar
jlcustomz jlcustomz is offline
Model: Caballero
NECOA #: 19307
jlcustomz has a reputation beyond reputejlcustomz has a reputation beyond repute
Maaco near my work & a few others in my area actually can do that nice of a paint job if you know who to talk to & pay accordingly.
You may even find that style of hood bumpers in the help section at local auto parts stores as they were a common style, wouldn't hurt to have new anyways. There is also a 3rd bumper at the center of the windshield cowl, which needs occasional lube not to cause a squeak that sounds like it's coming from your dash.
No true hot rod is ever finished. If it doesn,t command respect, fear will do.
Old 11-06-2019, 05:54 AM
JJLT1 has a reputation beyond reputeJJLT1 has a reputation beyond reputeJJLT1 has a reputation beyond repute
as said
sometimes its a metal spring clip, in a square hole in the core support..
pics in the link
https://www.elcaminostore.com/el-cam...1978-1987.html
https://www.elcaminostore.com/engine...and-stops.html
sometimes its a square weld-nut on the core support
85-SS 95-LT1-383 4L60 8.5-3.73
Old 11-07-2019, 07:56 PM
pmnelson57 pmnelson57 is offline
NooB
Year: 1979
NECOA #: 17560
pmnelson57 will become famous soon enough
I searched for 2 years for a squeak coming from the dash area on my 79 until I just read your comment about the need to lube the 3rd hood bumper at the rear of the hood. It took me 30 seconds to fix a squeak that has annoyed me for ages. You are a genius!
  #12
Old 11-08-2019, 01:06 AM
Tripp Tripp is offline
Year: 1986
NECOA #: 82394
Tripp will become famous soon enough
Holy cow! I to have spent many hours under my dash looking for that squeak. Thank you very for that tip...
  #13
Old 11-09-2019, 09:11 AM
jlcustomz's Avatar
Model: Caballero
NECOA #: 19307
Phillip & Steve, glad I helped & I mentioned because so many don't know that while it is common knowledge to others. While I did figure it out all om my own in the early 90's before internet, (silicone grease for T-tops squeak issue) a simple google search or question post here would have got a quick answer. As with many of life's small annoying problems , it takes far less time to fix than talk about.
Here's a 2004 post:: https://www.elcaminocentral.com/showthread.php?t=2726
Forums are here partly so those of us who know or figured things out the hard way can spend more time enjoying their elky's & less fussing with it.
Please do a search first & then ask here if you don't find an answer.
Powered by vBulletin® Version 3.8.8
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
