68 327 build questions - El Camino Central Forum : Chevrolet El Camino Forums
Old 11-21-2019, 12:20 PM
EasyMoney71 EasyMoney71 is offline
NooB
Year: 1971
Region: 19(AK,ID,OR,WA)
NECOA #: 91376
EasyMoney71 will become famous soon enough
Default 68 327 build questions
Hey Everyone,
Just picked up a 68 250HP 327. Block has been bored .060 over, crank turned .010 new rods/flat top 4 relief pistons all weight matched and block has been decked .005 just to clean it up. Running a Summit cam 214/224 duration, 444/466 lift with 112 LSA. Old style Performer 2101 with a 76 Q-Jet. My question is about the heads that came with it. 601's that have been opened to 64cc, ported still using the 1.85 intake and 1.50 ex valves. I will be using a TH350 with 3.08's Just looking for a reliable daily driver I can pass tourists with. Any thoughts?
Old 11-21-2019, 02:51 PM
464elky's Avatar
464elky 464elky is offline
NECOA #: 8926
464elky has a reputation beyond repute464elky has a reputation beyond repute464elky has a reputation beyond repute
Should run pretty good.
84 Elky with 455 Stage 2 Buick, Tremec TKO600 5 speed, 8.5 3:23 posi 98 Acura CL custom upholstered seats, Dakota Digital Instrumentation-
Car Domain:
Another 3 to 9 years should finish it.
In year 10. Added FITech Fuel Injection. 40K miles and going strong.
Link to Garage:
Old 11-22-2019, 05:55 PM
Gremlinsteve's Avatar
Gremlinsteve Gremlinsteve is offline
Torque Wrench
Year: 1987
NECOA #: 77793
Gremlinsteve has a spectacular aura about
I agree
That cam is similar to the chevy 350 hp 327 cam
Old 11-22-2019, 08:23 PM
NooB
Year: 1971
NECOA #: 91376
Default 68 327
Thanks,
I thought the heads would work but no one around here had any info on them.
Old 11-23-2019, 11:13 AM
dieselhead dieselhead is offline
Year: 1968
NECOA #: 21706
dieselhead will become famous soon enough
"601's that have been opened to 64cc"
I don't know what a 601 head is but the '68 327's came with camel hump heads that didn't have any accessory holes on the ends and 64cc combustion chambers. The high performance "fuel injection" 327 heads had 2.02 intake valves and the combustion chamber was relieved for better flow around the valve. Is the 601 head a 305 head with small valves and 58cc combustion chambers?
Old 11-23-2019, 10:13 PM
LuvNLife LuvNLife is offline
Knuckle Buster
Year: 1978
Region: 7 (AL,GA,TN)
NECOA #: 10293
LuvNLife has a spectacular aura about
Yeah; the 601 is a 1980-86 267/305 head with the 58cc chambers.
Old 11-24-2019, 10:40 AM
Year: 1968
NECOA #: 21706
Your 327 should run fine with the 305 heads, auto trans and 3.08 gears. Even with 64cc combustion chambers and flat top pistons your CR will be 10:1 so you may not be able to run regular gas. I put a set of World Product 305 heads on the original rebuilt 350 in my '80 Chevy deer lease truck because it raised the CR from 8:1 to 9:5. I put a Comp Cams Extreme Energy cam in this truck at the same time and it runs great but I have to use mid range gas. If I had it to do over I would have used aluminum Trick Flow 305 heads and maybe I could run regular gas.
Old 11-24-2019, 03:59 PM
mycross247's Avatar
mycross247 mycross247 is offline
Year: 1982
Region: 16(CO,MT,WY,UT)
NECOA #: 91794
mycross247 will become famous soon enough
Default 060
hi 68 327 scrap the block 68 should be a lg jo crank same jo as a 350 so you can use a 010 350 block 060 327 over heating problems
Old 11-24-2019, 04:05 PM
mycross247's Avatar
Year: 1982
NECOA #: 91794
also i have a 68 327 and it is a lg jo rare steel crank out of a dump truck, had another 68 327 ,it was also lg jo crank i put 220 alum heads w/ small 420 cam and 600 holly, works great but not suppose to w/ big heads
Old 12-07-2019, 07:36 PM
67ELK 67ELK is offline
Site Contributor
Year: 1967
Region: 15(AZ,NM)
NECOA #: 91066
67ELK has a spectacular aura about
Should run just fine! Be sure to use a Good Radiator! An aftermarket like a Champion or a Cold Case will help to keep that .060 over block running cool.
Old 12-08-2019, 05:43 AM
pitts64's Avatar
pitts64 pitts64 is offline
Year: 1969
NECOA #: 19572
pitts64 is a glorious beacon of light
I've had excellent results with the Champion radiator..
That cam should be just right. So many time I see guys over cam engines for street motors. I am guilty myself, I ruined more good running engines with long duration cams then I care to remember lol...
Powered by vBulletin® Version 3.8.8
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
