Drum brake bleeder nut blocked - El Camino Central Forum : Chevrolet El Camino Forums
Notices
Old 11-21-2019, 03:45 PM
captainzoop captainzoop is offline
NECOA #: 90402
captainzoop will become famous soon enough
Default Drum brake bleeder nut blocked
The rear drum brakes on my car have bleeder nuts that are blocked by a housing of some sort. I can’t seem to find a way to get them off to get a wrench around the bleeder. Any ideas?
Click image for larger version
Old 11-21-2019, 03:51 PM
FlatBlack65's Avatar
FlatBlack65 FlatBlack65 is offline
Year: 1965
NECOA #: 21586
FlatBlack65 is a jewel in the rough
thin walled socket?
Old 11-21-2019, 04:37 PM
NECOA #: 90402
Originally Posted by FlatBlack65 View Post
thin walled socket?
Yes I could, but then I wouldn’t be able to get a hose on there to bleed it
Old 11-21-2019, 05:44 PM
69 SS396's Avatar
69 SS396 69 SS396 is offline
Year: 1969
Region: 7 (AL,GA,TN)
NECOA #: 19132
69 SS396 has a reputation beyond repute69 SS396 has a reputation beyond repute
Go buy some longer ones, use a thin wall socket take them out an put the longer ones in.
Then you can bleed.
Cheers, Sean
Proud owner of "Misty Meaner" 1969 Elky SS
SOLD
2005 Silverado crew cab named Betty(bam-ba-lam)Daily driver.
1984 GMC Short wide 2wd. 350/T350 Next project. (Strawberry Shortbed????)
When I get high I get high on speed
Top fuel funny car's A drug for me
My heart, my heart
Kick start my heart
Old 11-21-2019, 08:00 PM
NECOA #: 90402
Then you can bleed.
Dang, okay thank you. That’s what I’ll do then.
At the moment I have no brakes as my pedal goes to the floor. There’s fluid in the lines but also alot of air. If I bled the front two disc brakes would I be able to brake with them? I just need to move the car a couple of blocks.
Old 11-21-2019, 08:48 PM
roger1's Avatar
roger1 roger1 is offline
NECOA #: 2332
roger1 is a name known to all
I used an old wrench and socket and made my own tool for that.
1983 Choo Choo SS w/1996 LT1 and 4L60E -
1955 Bel Air Sport Coupe w/Ram Jet 350 and Tremec T56 Magnum
1957 Chevrolet 3200 pickup w/TPI and 700R4 -
2008 Corvette 3LT Coupe, LS3/6spd, Atomic Orange, all stock
Pictures:
Old 11-22-2019, 05:10 AM
pitts64's Avatar
pitts64 pitts64 is offline
Year: 1969
NECOA #: 19572
pitts64 is a glorious beacon of light
I got an old socket and ground it down around the sides. Just gravity bleed the rears, it takes a little longer but I think its the best way to get all the air bubbles out..
Old 11-22-2019, 05:26 AM
any4xx any4xx is offline
Year: 1968
NECOA #: 88002
any4xx will become famous soon enough
My initial thought would be to just replace both rear wheel cylinders. You already have no brakes. By the looks of the one this has not been a garage queen. Two new rear cylinders will have nice new bleeders and would be an easy swap.
Old 11-22-2019, 05:36 AM
B52bombardier1 B52bombardier1 is offline
Site Contributor
Year: 1970
Region: 14(AR,LA,MS)
NECOA #: 78882
B52bombardier1 is just really nice
+1 to new wheel cylinders. They are inexpensive and a good idea on old brake systems such as ours. You would hate yourself if you kept these old wheel cylinders and then leaked brake fluid on your new brake shoes.
Rick
Sent from my SM-G965U using Tapatalk
70 El Camino, 5.3L LS Engine, 4L60E Transmission
Old 11-22-2019, 09:08 AM
roger1's Avatar
NECOA #: 2332
My new cylinders still have a shrouded bleeder like the originals.
Old 11-28-2019, 05:41 PM
allenrider allenrider is offline
Model: Diablo
NECOA #: 72866
allenrider will become famous soon enough
I ran into the same problem a while ago. I believe that arrangement is pretty standard on G-bodies. GM made a special tool—$$$$, if you can find one. I used a deep well socket with a hose through the drive hole. Similar to a prior post. Used a pair of vicegrips to turn it. Messy but it worked.
  #12
Old 11-29-2019, 01:46 AM
elkybuick's Avatar
elkybuick elkybuick is offline
Elkybuick
Year: 1980
NECOA #: 19948
elkybuick will become famous soon enough
Don't forget Hoses if it has been sitting for a long time cheap but well worth it.
ElkyBuick
1980 El Camino
1973 Buick Riviera
Air Force Veteran
  #13
Old 11-29-2019, 05:12 AM
pitts64's Avatar
Year: 1969
NECOA #: 19572
Yep I would replace both hoses and cyls.. Spray the tubing down with Liquid Wrench or something like it a few days before installing..
Postal Code
Required
Street Address
Complete, verifiable Street or other address required (Hidden)
City
Your city or town
State or Province
Required
Location area within State
Which selection best describes the area of the State that you live in.
Country
Required
NECOA Region
Required
Year of Vehicle
Required
Make of Vehicle
Required
Model of Vehicle
Required
Real Name
Required. Your real name to be shown in your posts and profile.
Insurance
Please select your insurance company (Optional)
Powered by vBulletin® Version 3.8.8
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
