Where can I get a 3-terminal wiper motor plug? - El Camino Central Forum : Chevrolet El Camino Forums
Go Back   El Camino Central Forum : Chevrolet El Camino Forums > Body & Chassis > Electrical Systems
Old 07-14-2018, 08:20 PM
any4xx any4xx is offline
Year: 1968
Model: El Camino SS
Region: 18(CA)
NECOA #: 88002
any4xx will become famous soon enough
Garage
Default Where can I get a 3-terminal wiper motor plug?
Title sums it up.
One of my scores of projects for my Ď68 has been to get the wiring all sorted out. Today I managed to get the wiper/washer motor working. But Iíve got 1/4Ē spade terminals on each wire going to the motor, as the three-terminal harness isnít there.
I scoured the Ďnet for a few hours looking for the correct plug, but have been striking out.
Any clues where I might be able to source one of these plugs that I can splice into my stock wiring?
Thanks,
Tom.
Old 07-15-2018, 07:00 AM
HKDUP87's Avatar
HKDUP87 HKDUP87 is offline
Year: 1985
Model: Conquista
Region: 18(CA)
NECOA #: 18458
HKDUP87 has a reputation beyond reputeHKDUP87 has a reputation beyond repute
Garage
look here,
https://www.classicindustries.com/sh.../wiper-motors/
https://www.google.com/search?q=1968...=1531659648986
(this post was written by a well used crash test dummy, on a closed course. No armadillos were harmed in the making of this post. Your mileage may vary. If you have a stiff upper lip lasting more than four hours, seek medical assistance. Reading this post may cause bleary eyes in men over 50, and is known to cause a significant reduction in brain cells....)
Knowledge before $$$$ is my new philosophy!!!!!!
Old 07-15-2018, 08:21 AM
Year: 1968
Model: El Camino SS
Region: 18(CA)
NECOA #: 88002
Garage
Hmmm... I did see that Camaro assembly at Classic Industries, but was hoping to find just the three-position plug all by itself rather than having to spend $30.00 on an entire harness. But I may have to resort to that.
The thought of crawling through salvage yards for a 50-year-old connector doesn’t appeal to me. Seems as if all the yards here in my area only keep cars within about 20 years old.
I’m shocked that some of the electrical suppliers seem to stock a thousand plugs for GM cars, but not that elusive plug.
Thank you.
Old 07-15-2018, 08:31 AM
Mr. Fin's Avatar
Mr. Fin Mr. Fin is online now
Deputy National Director Moderator
Year: 1959
Region: 18(CA)
NECOA #: 19689
Mr. Fin is a glorious beacon of light
Garage
Tom,
If you are asking about the wiper motor pig tail, you might find it is part of the engine harness. If that is the case, the pig tail may not be sold separately.
Old 07-15-2018, 09:26 AM
Year: 1968
Model: El Camino SS
Region: 18(CA)
NECOA #: 88002
Garage
Quote:
Originally Posted by Mr. Fin View Post
Tom,
Yeah... I certainly can buy an entire harness, but it seems like overkill. And it seems as if every other plug under the hood is available out there. Worst case is that Iím thinking of measuring the spacing of the voltage regulator harness and if itís the same, just pick up a pigtail for that and cut one lug off of it. Actually, thatís the second-worst case. I could just tape up the spade terminals in a way to keep them oriented correctly and put my OCD in the drawer.
Back out to the garage....
Thank you.
Tom
Old 07-15-2018, 05:12 PM
Rick's Avatar
Rick Rick is offline
Year: 1972
Model: El Camino Classic
Region: 13(TX)
NECOA #: 149
Rick is a name known to all
Garage
Tom
That type of connector is a Packard 56. A search using that term may make your life easier.
Rick Schaefer
Old 07-15-2018, 05:15 PM
trifiver's Avatar
trifiver trifiver is offline
Torque Wrench
Year: 1972
Region: 13(TX)
NECOA #: 1670
trifiver will become famous soon enough
Not sure if a 68 harness uses the same harness as a 72. I took my old plastic terminal covers (some from parts cars or old harnesses) and crimped in new Packard-56 terminals from Waytek.
  #8
Old 07-15-2018, 05:18 PM
Year: 1968
Model: El Camino SS
Region: 18(CA)
NECOA #: 88002
Garage
Yeah... you know... I think I can’t find it because it doesn’t exist. It looks like it’s supposed to be a double plus a single instead of a triple. I called a friend today with a ‘68 Malibu. Although his doesn’t have hidden wipers, it’s still a three-wire system: Two plus one.
D’Oh!
  #9
Old 07-17-2018, 06:09 PM
sandblaster's Avatar
sandblaster sandblaster is offline
Year: 1985
Model: Conquista
Region: 3 (DE,NJ,PA)
NECOA #: 727
sandblaster has a spectacular aura about
Garage
Some styles of Packard 56 Connectors HERE :http://terminalsupplyco.com/Store/De...?CAT=DEL010010
  #10
Old 11-17-2019, 03:27 PM
heetseeker's Avatar
heetseeker heetseeker is offline
Junior Member
Twisted Wrench
Year: 1968
Region: 18(CA)
NECOA #: 91234
heetseeker will become famous soon enough
Garage
Quote:
Originally Posted by any4xx View Post
Title sums it up.
I'm getting ready to tackle the same issue with my 68. Previous owner didn't have the wiper motor wired so i'm starting from scratch. Any tips before I start disassembling the dash looking for solutions?
thanks!
  #11
Old 11-17-2019, 03:44 PM
Year: 1968
Model: El Camino SS
Region: 18(CA)
NECOA #: 88002
Garage
Quote:
thanks!
I never did find the proper plug, but I did sort out the wiring. A friend has a Ď68 also, but without the hidden wipers. Turns out they are completely different motors and switches. This is a picture of mine wired up with the hidden wipers.
  #12
Old 11-18-2019, 10:22 PM
heetseeker's Avatar
Junior Member
Twisted Wrench
Year: 1968
Region: 18(CA)
NECOA #: 91234
Garage
That helps! Thank you.
  #13
Old 11-30-2019, 02:02 PM
heetseeker's Avatar
Junior Member
Twisted Wrench
Year: 1968
Region: 18(CA)
NECOA #: 91234
Garage
Looks like i'll be starting from scratch with the wiring. I peeked up into the dash from underneath and couldn't see any wires coming down from the wiper switch. looks like that didn't get addressed when the PO wired up the dash. I've got to remove the dash to get the new heater head/cables and heater core installed so i'll tack that on to the list. looking for a schematic of the switch diagram...can't find it in the manual.
  #14
Old 12-02-2019, 11:07 AM
heetseeker's Avatar
Junior Member
Twisted Wrench
Year: 1968
Region: 18(CA)
NECOA #: 91234
Garage
Found my wires for the wiper motor! They were disconnected and tucked into the fender well area. Unfortunately, they are spade terminals not the Packard 56 stock configuration. They are also all black which doesn't help with the ease of wire placement on the motor and pump. I see on your pic that the yellow wire is the same on the left side of the pump connection and the middle on the wiper motor. I have that part figured out on mine. I used my multimeter to ring out the wiper switch position and corresponding wires, but can't find a wiring diagram for switch to motor wiring. Still looking. Also, since i'm new here, i'm having a problem viewing other posts' photobucket pictures....not that might help some if I can get that figured out!
  #15
Old 12-02-2019, 12:29 PM
Year: 1968
Model: El Camino SS
Region: 18(CA)
NECOA #: 88002
Garage
I think as long as you have the power to the center of the motor everything else can be done through trial & error without any risk of damage. I've seen the pump wired with the power on opposite sides in several places. The pump electrical is nothing more than a solenoid which retracts an arm and allows the wiper motor to engage the pump mechanism. I've tried wiring mine both ways and it works either way. I'm not sure what the "correct" way is though.
Quick Reply
Message:
Smilies
Options
Register Now
User Name:
Password:
Confirm Password:
Email Address
Email Address:
Log-in
You may post new threads
You may post replies
Can't get drain plug out of 66 66327elky Engine Topics 10 01-20-2017 10:40 PM
Can you determine the motor by the spark plug type? marcus Engine Topics 10 09-22-2013 01:18 PM
Where Can I Find a 2 Terminal Blower Motor? Lindsay Heating & Air Conditioning Systems 2 07-14-2013 07:53 PM
Can't get boots on plug wires Jack_K Ignition Upgrades & Discussion Forum 28 12-02-2011 02:53 PM
Is this possible without an "R" terminal on the so elkyholik70 Ignition Upgrades & Discussion Forum 1 05-04-2006 06:37 AM
Powered by vBulletin® Version 3.8.8
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
