My 1964 elky restomod journey and question thread - El Camino Central Forum : Chevrolet El Camino Forums
Old 11-27-2019, 12:03 PM
Bux_64's Avatar
Bux_64 Bux_64 is offline
Junior Member
Twisted Wrench
Year: 1964
Region: 6 (FL)
NECOA #: 91822
Bux_64 will become famous soon enough
Garage
Default My 1964 elky restomod journey and question thread
alrighty so im posting here to talk about my 6fo's current state, my plans on restoring and or updating. I will also be asking questions along the way because this is very new to me. and because I second guess myself allot before doing anything I'm unfamiliar with. ( I have been searching the threads since joining here for gen 2's and the 64 elky. So if I post a question here and there is threads bout it already I'm apologizing now in advance) also I may call parts by wrong names or made up names, please correct me as needed!
so my keys for my daily pickup, house key and only key for the elky disappeared.. wife and I think our youngest ( she will be 2 in march) threw them away, she was fixated on putting things in the trash can. I needed door locks so I ordered the new ignition cylinder door locks and glovebox lock with matching key. well I thought id try and be awesome and remove the old ignition cylinder from the ignition switch with a flat head to turn it to ACC to remove it.. well that didnt work ... at all... I broke the flathead inside the cylinder and then with frustration I took a drill to it.. that didnt work so I looked online to order a new ignition switch. found a local autozone that actually had in stock a "64 el camino" ignition switch! JACKPOT!! well it didnt fit the harness clip.... ... so I decided I should of just ordered it from the online el camino store from the get. I was nervous about doing it now cause what if it doesnt fit like *** then id have to send it back. and I really hate having to do that with online purchases...
so for a few days I pondered about the harness clip and the ignition switch not lining up.. a lightbulb lit up and I thought to myself lets see if its a 64 chevelle ignition switch will line up ... it did! So is that normal with the chevell el caminos?
so first major thing ... I want to do is the head to tail complete update wiring harness.
I have very little knowledge on electricity and Id rather do that all in one shot rather than try back tracking problems back n forth on wires. plus the wires are 55 years old .
once the wiring harness is done ill put the dash back in ,
what recommendation do y'all have for headlights? I am looking at the LED low & high beams that are up on the el camino store online...
but in the mean time before that happens I want to start sanding and priming the car. I dont have a garage to be able to strip the car down completely and get at it. so was thinking about doing one section at a time. for ex. take a front fender off sand and prime completely then put back on and go about the car in that manner. good idea? bad idea?
also need to buy and install the weather stripping for the doors.
What parts are irreplaceable and I should make sure they are kept in good shape? I have a few buddies that tell me theres parts that I might not be able to find for this ol car.
when I bought this car it came with most of if not all the trims pieces and even some extra trims pieces. also came with a few bins of extra or original parts and even nos parts . ( dont know how to post pics on a new thread gonna research now so I can post pics of the parts)
to be continued....
BUX
64 El Camino
NOOBIE
Old 11-27-2019, 01:02 PM
69 SS396's Avatar
69 SS396 69 SS396 is offline
Year: 1969
Model: El Camino SS
Region: 7 (AL,GA,TN)
NECOA #: 19132
69 SS396 has a reputation beyond repute69 SS396 has a reputation beyond repute
Garage
A couple suggestions:
Get yourself a good shop manual and a body manual.
Bookmark Rockauto.com. They are a very good source for parts.
Also go to the gm heritage center and download needed info from there.
And CONGRATS on the 64. I want another one.
Cheers, Sean
Proud owner of "Misty Meaner" 1969 Elky SS
SOLD
2005 Silverado crew cab named Betty(bam-ba-lam)Daily driver.
1984 GMC Short wide 2wd. 350/T350 Next project. (Strawberry Shortbed????)
When I get high I get high on speed
Top fuel funny car's A drug for me
My heart, my heart
Kick start my heart
Old 11-27-2019, 01:08 PM
69 SS396's Avatar
Year: 1969
Model: El Camino SS
NECOA #: 19132
Garage
https://www.gmheritagecenter.com/doc...-El-Camino.pdf
Old 11-27-2019, 01:58 PM
B52bombardier1 B52bombardier1 is offline
Site Contributor
Year: 1970
Region: 14(AR,LA,MS)
NECOA #: 78882
B52bombardier1 is just really nice
Hello Ryan,
And good luck on your project. I will try to answer some of your questions.
1 - I went with an American Auto Wire new wiring harness - their "Classic Update" model. No major complaints with it and each wire is labeled along its length for easy installation. The instructions are well written and I recommend doing one circuit at a time and then test it using a good multimeter. This is what worked for me.
2 - Headlights? I'm using standard incandescent original lighting. With new wiring and clean grounds, you will likely be surprised at how well they can operate.
3 - As long as your panels are not too rusty or dented, I'd leave them on while sanding them. This avoids needing to learn how to do panel alignment and you can always take them off later if you are not happy with your initial efforts.
4 - Weatherstripping? "Steele" or "Metro" make good rubber. I think what I have is made by "Soffseal" (? spelling) and it fits well but still leaves a gap at the top of the window frame. I have since learned that the factory people would bend the window frame to close this gap but I'm not going to do that. I have somewhat cured this problem using other methods.
5 - I would not throw any of your old parts away yet and yes, some will not be available. Even an old rusty part is better than no part at all. Somebody around here might have what you need.
The best advice I have for you is to try doing something in your rebuild every day. Every. Single. Day. Even if you can only get 15 minutes devoted to some obscure project with your EC, those little bits of time will add up.
70 El Camino, 5.3L LS Engine, 4L60E Transmission
Old 11-27-2019, 02:40 PM
ELKYBILL's Avatar
ELKYBILL ELKYBILL is offline
Year: 1964
Model: El Camino Classic
Region: 22(CANADA (Ontario and East)
NECOA #: 73706
ELKYBILL will become famous soon enough
Garage
Good luck on your project Ryan,I'll be following!
"WARMING THE PLANET 8 CYLINDERS AT A TIME"
Old 11-27-2019, 03:36 PM
Bux_64's Avatar
Junior Member
Twisted Wrench
Year: 1964
Region: 6 (FL)
NECOA #: 91822
Garage
awesome thank you I got them saved now! I do have to copies of the complete of how to assemble the whole car [IMG][IMG]
[/IMG]
Old 11-27-2019, 03:47 PM
Bux_64's Avatar
Junior Member
Twisted Wrench
Year: 1964
Region: 6 (FL)
NECOA #: 91822
Garage
hey rick thank you !
1. thats who I have book marked for the wiring harness
2. im gonna look up those bulbs. if they are cheaper than going LED more than likely ill go
that route.[IMG] the one bulb that does work is the sylvia and the other three bulbs are GE sealed beams. was surprised they are actually glass bulbs and not bulbs behind plastic
[/IMG]
3. the reason I was thinking to take the panels off was to get rid of any rust hiding behind
them
4. noted
5 ohhh nooo I wasnt gonna throw away any parts I have the original nuts and bolts in bags
covered in rust.
thank you very much!
Quote:
Originally Posted by B52bombardier1 View Post
Hello Ryan,
  #8
Old 11-27-2019, 03:50 PM
Bux_64's Avatar
Junior Member
Twisted Wrench
Year: 1964
Region: 6 (FL)
NECOA #: 91822
Garage
Thanks Bill! your 64 is beautiful love the stance
  #9
Old 11-27-2019, 04:01 PM
Bux_64's Avatar
Junior Member
Twisted Wrench
Year: 1964
Region: 6 (FL)
NECOA #: 91822
Garage
Some of the extra parts that came with car
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
  #10
Old 11-27-2019, 04:04 PM
ELKYBILL's Avatar
Year: 1964
NECOA #: 73706
Garage
Quote:
Thanks Ryan!
  #11
Old 11-28-2019, 02:28 PM
Harleydude's Avatar
Harleydude Harleydude is offline
Year: 1964
Region: 21(CANADA (W. of ONT.))
NECOA #: 16790
Harleydude will become famous soon enough
Garage
Wow, gold mine for the extra parts. Good luck. 64's rule!
  #12
Old 11-30-2019, 06:24 AM
Walt's Avatar
Walt Walt is offline
Member
Loose Nut
Year: 1964
Region: 5 (NC,SC)
NECOA #: 90330
Walt will become famous soon enough
Garage
Hello Bux_64, if you can get in touch with LOCKJAW on this site, he is very knowledgeable on the 64's, and has built a few of them, one of which I bought, good luck with your project and you are the right place for info!!!
  #13
Old 11-30-2019, 04:24 PM
ELKYBILL's Avatar
Year: 1964
NECOA #: 73706
Garage
Quote:
Checked out your garage Rodger...nice '64!!
  #14
Old 11-30-2019, 05:21 PM
Bux_64's Avatar
Junior Member
Twisted Wrench
Year: 1964
Region: 6 (FL)
NECOA #: 91822
Garage
thats most of them still have some others. im digging the two tone on yours, I'm curious on how the back and the bed was done paint wise.
  #15
Old 11-30-2019, 05:24 PM
Bux_64's Avatar
Junior Member
Twisted Wrench
Year: 1964
Region: 6 (FL)
NECOA #: 91822
Garage
Awesome thank you will keep that in mind!
Quick Reply
Message:
Smilies
Options
Register Now
User Name:
Password:
Confirm Password:
Email Address
Email Address:
Log-in
You may post new threads
You may post replies
Powered by vBulletin® Version 3.8.8
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
