What have you done to your El Camino today! - Page 275 - El Camino Central Forum : Chevrolet El Camino Forums
Notices
Go Back   El Camino Central Forum : Chevrolet El Camino Forums > General Topics > Site Topics
  #4111
Old 09-20-2019, 02:59 PM
heetseeker's Avatar
heetseeker heetseeker is offline
Year: 1968
NECOA #: 91234
heetseeker will become famous soon enough
Washed the 68 and took it for a spin. Came home, mopped up the antifreeze on the passenger floor mat and ordered some parts. After hunting season, new shocks, tuning and I start body work.
  #4112
Old 09-24-2019, 10:50 AM
tomicamino's Avatar
tomicamino tomicamino is offline
Region: 24(EUROPE)
NECOA #: 89510
tomicamino will become famous soon enough
Was at wheel dyno today, 258 hp from engine, quite good, stock 305 is making 170 hp
  #4113
Old 09-24-2019, 05:27 PM
Rick's Avatar
Rick Rick is offline
Year: 1972
Model: El Camino Classic
NECOA #: 149
Rick is a name known to all
Must make a VERY nice driver.. Good job with it.
Rick Schaefer
  #4114
Old 09-25-2019, 05:09 AM
pitts64's Avatar
pitts64 pitts64 is offline
Year: 1969
NECOA #: 19572
pitts64 is a glorious beacon of light
Jacked the rear end up and tightened the exhaust and what ever else I could see. Adjusted the rear brakes, weird how the drivers side wears out faster then the passenger side, I have no self adjusters, I can't find original GM self adjusters, the after market ones are real cheap..
The car seems to run better with the exhaust tightened and not leaking, it sounds much better. Some times I wish I had mufflers a little louder then the Dynomax super turbos.. I'm tempted to get those long 40" glass packs. They should be on the quiet side yet have a rumble..
  #4115
Old 09-25-2019, 12:04 PM
123pugsy's Avatar
123pugsy 123pugsy is offline
Torque Wrench
Year: 1969
Region: 22(CANADA (Ontario and East)
NECOA #: 85874
123pugsy will become famous soon enough
I love my glass packs. Not too loud cruising but they sing real nice when I get into it.
PUGSY
  #4116
Old 09-28-2019, 11:33 AM
78 Elk's Avatar
78 Elk 78 Elk is offline
Year: 1978
Region: 19(AK,ID,OR,WA)
NECOA #: 3102
78 Elk is a name known to all
I was able to splice in the wires to the brake pedal.
hagensen78
  #4117
Old 09-29-2019, 05:29 AM
pitts64's Avatar
Year: 1969
NECOA #: 19572
Thanks Pugsy.. Which ones do you have?
  #4118
Old 09-29-2019, 06:02 AM
123pugsy's Avatar
Torque Wrench
Year: 1969
NECOA #: 85874
Hold it, sorry. I just remembered. With my 327 I had a drone sound coasting down around 1200 RPM's and lower. When I swapped the 5.3, it was good after that.
Thrush, 2-1/2" about 24" long.
The 327 had stock cast iron manifolds.
The 5.3 has 2014 Camaro iron manifolds.
Not sure if it was the manifolds or the engine that took away the drone.
  #4119
Old 10-30-2019, 06:23 PM
78 Elk's Avatar
Year: 1978
NECOA #: 3102
I changed the battery in mine. It lasted 9 and 3/4 years. Same brand Interstate.
  #4120
Old 11-01-2019, 06:43 PM
any4xx any4xx is offline
Year: 1968
NECOA #: 88002
any4xx will become famous soon enough
Now the fronts match the rears.
In what can best be described as a complete waste of money, I swapped out my Ď68 factory disc brakes for a set of Wilwood disc brakes. Ever since adding the Strange rear with the Wilwood discs things just didnít look proper with the big cast iron calipers up front. So to protect my fragile ego...
Click image for larger version
  #4121
Old 11-02-2019, 09:23 PM
JerRol79ELC's Avatar
JerRol79ELC JerRol79ELC is offline
Loose Nut
Year: 1979
Region: 5 (NC,SC)
NECOA #: 77130
JerRol79ELC has a spectacular aura about
What a process to replace my oil pan. After pulling the 4 speed, bellhousing, clutch, etc. I had to remove the starter and the passenger side header to remove the passenger side motor mount bolt. Now in the process of sanding the passenger side header for repainting and then lift the engine to remove the driver side header for repainting, then finally change the pan while the engine is lifted...
  #4122
Old 11-07-2019, 11:21 PM
tomicamino's Avatar
Region: 24(EUROPE)
NECOA #: 89510
Made new exhaust system from front to rear, disassembled rear end and control arms from the car, exhaust waiting for final welding
  #4123
Old 11-08-2019, 03:35 PM
78 Elk's Avatar
Year: 1978
NECOA #: 3102
I painted the plastic brackets that go around the headrest with SEM light Oak. They were red. My wife made covers back in 2005 that were red. We are changing the covers on the headrests to match door panels and visors.
  #4124
Old 11-09-2019, 06:09 AM
tsunami69 tsunami69 is offline
NooB
Year: 1971
Region: 24(EUROPE)
NECOA #: 90736
tsunami69 will become famous soon enough
last week the startermotor died, this morning a new one installed.
  #4125
Old 11-09-2019, 01:30 PM
78 Elk's Avatar
Year: 1978
NECOA #: 3102
Here is a picture of the headrest my wife made in 2005. We are taking them out and recovering them to match the seat. Hope I can post pictures of the new ones shortly.
https://i.imgur.com/S0DItPd.jpg
Postal Code
Required
Street Address
Complete, verifiable Street or other address required (Hidden)
City
Your city or town
State or Province
Required
Location area within State
Which selection best describes the area of the State that you live in.
Country
Required
NECOA Region
Required
Year of Vehicle
Required
Make of Vehicle
Required
Model of Vehicle
Required
Real Name
Required. Your real name to be shown in your posts and profile.
Insurance
Please select your insurance company (Optional)
Pollen be darned. Today is El Camino day! Elkiebob General BS Topics 17 04-14-2015 05:42 PM
Almost burned the El Camino down today! FWI Electrical Systems 2 07-20-2006 08:12 PM
Please help my el camino caught on fire today and burned blue81elcamino General BS Topics 12 06-07-2006 09:26 PM
Just bought my 1970 El Camino today! FWI General BS Topics 22 03-22-2006 06:34 PM
installed AIRLIFT 1000 in 85 El Camino today Tomahawke Suspension & Steering 7 03-13-2006 09:04 AM
Powered by vBulletin® Version 3.8.8
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
