Speedo has quit - El Camino Central Forum : Chevrolet El Camino Forums
Old 10-23-2019, 02:59 PM
crice63's Avatar
crice63 crice63 is offline
Year: 1975
Region: 14(AR,LA,MS)
NECOA #: 30369
crice63 is a jewel in the rough
Default Speedo has quit
On my first drive after the 60th show i heard a noise under the car, sounding mostly like a playing card flapping against some bicycle spokes. I stopped and looked to see if something was caught rubbing the wheels, but no. As I continued it clicked for another minute or two, then it stopped, as did my speedometer. Am I right to guess that the problem is down at the transmission connection? It never made noise at the gauge cluster, nor did I have shaking or bouncing of the needle.
1975 El Camino Classic
Old 10-23-2019, 03:26 PM
Mr. Fin's Avatar
Mr. Fin Mr. Fin is offline
Deputy National Director Moderator
Year: 1959
NECOA #: 19689
Mr. Fin is a glorious beacon of light
You are most likely correct. there is a speedometer cable that attaches to the outside of the transmission. It is connected to a gear in the housing of the trans. As the gear spins the cable spins and thus the gauge shows the revolutions. In most cases the cable inside of a plastic sheath fails and the cable needs to be replaced. Another failure could be the gear itself. Either way you can disconnect the cable and determine if it still has integrity. While you are there you can check the speedo gear to see if it still has a full set of teeth.
Both are fairly easy to replace and not an expensive fix.
Old 10-23-2019, 04:23 PM
JJLT1 has a reputation beyond reputeJJLT1 has a reputation beyond reputeJJLT1 has a reputation beyond repute
x2 Mr.Fin
take the cable off the trans and
you can test the speedo and the cable with a reversible drill ..
lube the cable too,,
the bad news is the cable comes out from the top end..
85-SS 95-LT1-383 4L60 8.5-3.73
Old 10-24-2019, 03:39 PM
Robert Jordan's Avatar
Robert Jordan Robert Jordan is offline
NECOA #: 70513
Robert Jordan will become famous soon enough
and a pain the in arse to get your hands up into that dash with all the wires.
Old 10-26-2019, 01:51 PM
crice63's Avatar
Year: 1975
NECOA #: 30369
Driven gear is broken. Driving gear looks ok. Here are the pics for confirmation. I ran the drill on the cable and that all works fine. Interestingly, the bolt that holds the gear in is exactly 10mm, not 3/8 or 5/16, which suggests to me it’s a newer tranny, right? Did they ever make the 350th with metric fasteners?
Naturally I Managed to push the broken gear down toward the transmission. Can I drive it with that floating around in there until the new gear gets here? I fished around with a coat hanger but no luck.
Also, my speedo was running just a tad high. At 70 it would read 76-77, at 80 it read 90. Should I get a different replacement gear? If so, which one? My tires are 26” diameter and I think the rear gears are 2.56. Looks like that purple drive gear is said to be 10 tooth. The calculator at https://www.tciauto.com/speedometer-gear-calculator#350 gives me 19.83788519173135. 19 teeth is natural color- 20 teeth is blue. So adding a tooth should make it spin a tad slower?
Click image for larger version
Old 10-26-2019, 07:51 PM
Mr. Fin's Avatar
Year: 1959
NECOA #: 19689
Each tooth represents about 10 MPH so your theory sounds good. AS for driving the truck with broken parts floating around in the trans, I would say don't. they could break up and who knows where they end up. Clean any broken parts out before you go any further.
Old 10-26-2019, 08:31 PM
crice63's Avatar
Year: 1975
NECOA #: 30369
I poked around in there again and that gear has disappeared. Not sure where it could have gone from that tail pocket. I need a new method.
Old 10-27-2019, 07:18 PM
crice63's Avatar
Year: 1975
NECOA #: 30369
Picked up a harbor freight bore scope, works pretty well, but still couldn’t see the broken gear. It might be time to work on that slow front seal leak.
Old 10-28-2019, 06:06 AM
464elky's Avatar
464elky 464elky is offline
NECOA #: 8926
464elky has a reputation beyond repute464elky has a reputation beyond repute464elky has a reputation beyond repute
Each tooth on the driven gear is about 3 mph
84 Elky with 455 Stage 2 Buick, Tremec TKO600 5 speed, 8.5 3:23 posi 98 Acura CL custom upholstered seats, Dakota Digital Instrumentation-
Car Domain:
Another 3 to 9 years should finish it.
In year 10. Added FITech Fuel Injection. 40K miles and going strong.
Link to Garage:
Old 10-28-2019, 07:58 AM
crice63's Avatar
Year: 1975
NECOA #: 30369
I looked at many pics of th350 tails online and it seems like there is only one place the broken piece could be, which is under the governor gear. If that gear spins counterclockwise, which it appears to, it should be alright. But I'm going to try not to drive it until I can fish it out. The new gears are in the mail from summit (19 and 20 tooth, will try the 20 first). We shall see.
Old 10-28-2019, 10:48 AM
NECOA #: 70513
You just need a plastic magnet .......
  #12
Old 10-28-2019, 11:47 AM
1 genuine southern spotted long tail ""plastic magnet""...
https://www.bing.com/images/search?q...aw&FORM=HDRSC2
  #13
Old 10-28-2019, 05:25 PM
freche's Avatar
freche freche is offline
Torque Wrench
Region: 1 (NY)
NECOA #: 39978
freche will become famous soon enough
On a turbo 350 there's four bolts that hold the tail cover on....pull driveshaft undo 4 bolts and pull cover.Its pretty much a sealed cavity except for a weep hole for lubrication.Theres a spring clip that holds gear onto output shaft.
  #14
Old 11-11-2019, 11:42 AM
crice63's Avatar
Year: 1975
NECOA #: 30369
Well, nothing is as easy as it sounds. In addition to the 4 bolts there is the exhaust support beam that has to be removed as well. But, done and done. The new blue gear had broken also, so I tested the cable again. It worked with the reverse drill but I couldn't turn it with my fingers, so I pulled out the whole cable and replace it with the one from the parts car. I took out the inside and greased it with white lithium. Replacing the speedometer back in the housing is a bear--didn't finish before dark. Possibly I had the cable routed incorrectly--does anyone know offhand if it comes through the square hole directly behind it or the round cutout to the right? So that is where I will pick up maybe Tuesday? As a post mortem my son pulled the wire out of the old cable and it was nearly impossible to get out. It wasn't broken or kinked, so I guess it was just frozen somehow.
Oh, also, the broken piece of gear was indeed resting under the governor gear. I couldn't get it out by hook or by crook--several different hooks including the plastic magnet shown above, various coat hangers and wires. Now the tailpiece of the transmission and the exhaust hanger are really clean and nice--should look strange to anyone who might look under there now.
  #15
Old 11-13-2019, 09:19 AM
crice63's Avatar
Year: 1975
NECOA #: 30369
All wrapped up. Putting the speedo back in the cluster housing was more difficult that it should have been. With the cable coming in through the cutout on the right, the speedo would not sit down straight—the cable wanted to pull it to the left. The pic is from my 75, and the 73 Laguna parts car is similarly routed, and this 77 was also. So I rerouted it through the square center cutout and after several tries got it to sit down straight. Everything works well. In fact, with the newly greased speedo, the needle is so smooth—even my S10 speedo isn’t that smooth. Apparently I’m so used to jerky that it had become natural. Now I will know.
Powered by vBulletin® Version 3.8.8
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
