Voltmeter gauge - El Camino Central Forum : Chevrolet El Camino Forums
Notices
Old 11-20-2019, 04:36 PM
dconwffw dconwffw is offline
Torque Wrench
Year: 1971
NECOA #: 81898
dconwffw will become famous soon enough
Default Voltmeter gauge
I am installing an aftermarket voltmeter gauge and was wondering if I dont have any tabs on the fuse box to use, can I splice into the power wire on the radio and then ground it. The only tab I have left is the battery tab that has power to it all the time and not sure if I can hook it there. I know you are to hook it up to a keyed 12v power source and that's why I wondered if I can splice into the radio power wire
Old 11-20-2019, 05:11 PM
464elky's Avatar
464elky 464elky is offline
NECOA #: 8926
464elky has a reputation beyond repute464elky has a reputation beyond repute464elky has a reputation beyond repute
It will work fine connected to the ign power for the radio.
84 Elky with 455 Stage 2 Buick, Tremec TKO600 5 speed, 8.5 3:23 posi 98 Acura CL custom upholstered seats, Dakota Digital Instrumentation-
Car Domain:
Another 3 to 9 years should finish it.
In year 10. Added FITech Fuel Injection. 40K miles and going strong.
Link to Garage:
Old 11-20-2019, 05:23 PM
Torque Wrench
Year: 1971
NECOA #: 81898
Next question, do I need to use the same size wire when splicing or can I use 12 ga going into the radio harness
Old 11-20-2019, 06:01 PM
B52bombardier1 B52bombardier1 is offline
Site Contributor
Year: 1970
Region: 14(AR,LA,MS)
NECOA #: 78882
B52bombardier1 is just really nice
Your new voltmeter won't consume more than a tiny fraction of an amp - very low amount of current draw. That 12 gauge will be fine but probably is overkill and could be much thinner.
Also, don't be surprised if your new gauge indicates perhaps .8 volts or so lower than if you used a multimeter and measured for DC volts at the battery. At least this is the situation for me and is due to voltage drops in the wire.
Rick
70 El Camino, 5.3L LS Engine, 4L60E Transmission
Old 11-20-2019, 06:06 PM
rtatwk's Avatar
rtatwk rtatwk is offline
Deputy Director Region 6 - Supporting Member
Year: 1987
Model: Diablo
NECOA #: 15623
rtatwk has a reputation beyond reputertatwk has a reputation beyond repute
Larger size wire will make no difference to function. Same size would also be fine in the arms length(?) or less involved with the connection. Voltage drop due to 'line loss' increases with the length between connections with DC current, and can be reduced with increased wire size moving further from the DC power source. Not a factor between fuse box and instrument panel for sure. Sorry some of this observation is sort of engineering lingo from former times reviewing fire alarm system plans for condos or other large buildings.
In simpler terms...If Neil (464elky) says it will work. It will work!
Old 11-20-2019, 06:28 PM
Torque Wrench
Year: 1971
NECOA #: 81898
Thanks I wasnt too sure since electrical is not my strong suit. Only other thing I could of done was splice in to the wire already hooked into the ignition tab on the fuse box
Old 11-21-2019, 05:49 AM
464elky's Avatar
NECOA #: 8926
To feed a voltmeter you could use 22 ga. It draws very little amperage as Randy said. 12 ga would be overkill FOR A VOLTMETER.
Old 11-21-2019, 05:56 AM
pitts64's Avatar
pitts64 pitts64 is offline
Year: 1969
NECOA #: 19572
pitts64 is a glorious beacon of light
Voltage is pressure, Amperage is the amount of electricity flowing.. Electricity much like water. Voltage is water pressure and current/amperage is gallons used...
Old 11-21-2019, 07:10 AM
JJLT1 has a reputation beyond reputeJJLT1 has a reputation beyond reputeJJLT1 has a reputation beyond repute
put a small alligator clip on it and clip it to a key-on fuse holder clip in the fuse box,
or get a fuse tap.. just put it on the load side of the fuse..
85-SS 95-LT1-383 4L60 8.5-3.73
Powered by vBulletin® Version 3.8.8
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
