Installed the Airlift 1000 package from Summit Was well Packaged and everything seems to work OK. What holds the spacer in the bottom of the spring in place. Mine look like they need to be adjusted into place. Is this normal.... ?
Sponsored Links | ||
What spacer are you talking about? Is it stock or come with the kit?
Jeff 78 El Camino SS, NECOA #395. |
Frankie, When you inflate the bag it will hold the spacer in place. One suggestion, run two air lines. If you have any questions feel free to ask.
Larry |
When you inflate the bags those spacers will be held in place. On the original bags I had one spacer for each bag but when I had to replace one bag Air Lift sent me a shorter bag and two spacers.
GUYS. thanks for the input, I did run two lines, and the bags are checking 15 lbs today. It is a little firm, but the rear end is higher, which I wanted. The handling is better, although I was sceptical of that. I am goin to re-adjust the hard rubber "spacer" to sit better in the spring, I am not satisfied with it partly sticking out. On my 85, I did have to remove a "cup looking thing" from the top of the springmount , in order for mine to fit. I guess that cup is to eliminate bottoming out of the spring, and to hold the spring in place. Anyway, the air bag now does that....... Thanks for the info, and I have monitored the forum for a while, and all the free advise is right on target, and also FREE>>>>>>>> what a great country... Tomahawke
You shouldn't have removed that "cup like thing" at the top spring mount. It's there to keep the spring from being displaced whne the shock fully extends. Put it back.
Maybe I did something wrong when I installed mine. The instructions said the rubber spacer went on top of the air bag, so to me that says the nipple on the air bag is pointing up. I took the spring out to install the air bag as I was doing some other suspension work at the same time. I removed the upper cup, ran the air line down through the hole left from removing the bolt out of the cup. Even with the shock removed and the suspension hanging, the spring is still tight against the upper cushion, so no fear of the spring coming out. It sounds like everyone else put the bag in so the airline was at the bottom?
#8
I have contacted Tech Support at AirLift. They advised me that the valve and spacers are installed on the bottom and not to remove the cup. The cup prevents the spring from being dislodged during full jounce.
Sponsored Links | |
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
Thread Tools | |
Display Modes | |
Thread | Thread Starter | Forum | Replies | Last Post |
another airlift 1000 question | horror | Suspension & Steering | 4 | 05-14-2013 07:09 AM |
Has anyone installed a 6.5L Diesel in their El Camino?? | 72 6.5L El Camino | Engine Topics | 31 | 11-01-2006 01:31 PM |
77 airlift suspension | Distalat | Suspension & Steering | 1 | 07-12-2005 06:53 AM |
airlift 100 air bags | aafrogman | Suspension & Steering | 16 | 04-05-2005 04:53 PM |
I installed my Edelbrock Performer 750 today! | Supercharged 86 | General BS Topics | 2 | 12-19-2004 07:16 PM |
