Conversion to Hydro Boost Brake System - 1970 El Camino - Page 3 - El Camino Central Forum : Chevrolet El Camino Forums
Notices
Go Back   El Camino Central Forum : Chevrolet El Camino Forums > Drivetrain & Performance > Brake Systems
  #31
Old 02-04-2017, 10:55 PM
Tokageroh Tokageroh is offline
Year: 1983
Model: Conquista
Region: 4 (MD,VA)
NECOA #: 18616
Tokageroh will become famous soon enough
I am using the hydratech braking system in my 83 elky, since im using a "cammy' motor. I found that for this generation your going to need a shorter master cylinder which hydratech does sell as oem and a wilwood style will end up hitting the bottom of the hood as these units stick out more then vac assist units.
Since i was doing a full tear down on my elky anyway i replaced front calipers with ssbc 2 piston units, rear wheel cylinders with enlarged ones (s10 i think), all the hoses are now braided lines. and the hard-lines are all stainless. i even added an adjustable proportioning valve, and line lock to the mix.
it takes a little while to get the air bubbles out of the booster unit, as i found out. even after the rest of the system wasn't making any noise from bubbles, some inevitably got trapped in the unit due to it being the highest point in the ps system. Now that its been run for awhile and the air pockets are out. I feel like my car stops better then most cars ive driven on the road.
  #32
Old 06-17-2017, 04:36 AM
AliceSML79's Avatar
AliceSML79 AliceSML79 is offline
Member
Twisted Wrench
Name: Alice Patricia Arthington
Year: 1970
Region: 12(MO,OK,KS)
NECOA #: 80402
AliceSML79 will become famous soon enough
I'm looking into a conversion like this when I get my 1970. after I'm set up to transport my chair first thing on the list is safety upgrades. and the way people drive where I live I been wanting to do a hydro boost setup. I have debated if a 12.19" wildwood breaks conversion would go well on a set up like that or staying disk drum would be okay with hydro boost. id only go 12.19 so I could clear the 15" wheels I want to use. looking at willwood's Front Brake Kit Part No.: 140-10510-DR and Rear Brake Kit – Part No.: 140-2112-DR.
  #33
Old 06-17-2017, 05:52 AM
B52bombardier1 B52bombardier1 is offline
Site Contributor
Year: 1970
Region: 14(AR,LA,MS)
NECOA #: 78882
B52bombardier1 is just really nice
I'm considering a stroker 383 as a crate replacement engine for my car running whatever cam they put in it. I wonder if it will not make enough vacuum to need a boost kit like this. I'm also replacing the front drum brakes on my 70 El Camino with disks.
These upgrades are still a while in the future but this thread is a very interesting discussion.
  #34
Old 06-17-2017, 09:38 AM
Old Bear's Avatar
Old Bear Old Bear is offline
Site Contributor
Name: Gale and his cats
Year: 1970
Region: 18(CA)
NECOA #: 38617
Old Bear has a reputation beyond reputeOld Bear has a reputation beyond repute
Garage
Depending on how close to turn key your crate engine is when shipped, your builder should be able to give you a good idea of the expected vacuum.
I would think a call to BluePrint would get you an answer to help with budgeting engine and brakes (vac produced by their different 383 offerings).
http://blueprintengines.com/index.ph...ng/gm-383-main
  #35
Old 06-25-2017, 02:24 PM
AliceSML79's Avatar
Member
Twisted Wrench
Year: 1970
NECOA #: 80402
would u recommend adding some kind big brake system to go with the hydro boost system like willwood? I know they require bigger rims but I want car that can put u thru the windshield to stop in a emergency.
  #36
Old 06-25-2017, 02:52 PM
Old Bear's Avatar
Site Contributor
Year: 1970
Region: 18(CA)
NECOA #: 38617
Garage
My budget would only allow one or the other.
The blower cam was making a decision.
So far, I am doing OK with just hydroboost, so I will not be upgrading to bigger brakes.
I still need to budget for upcoming rear drums, and better shoes and pads.
I know you like blue 70 El Caminos. Below is an image just before dusk sets of Blue Thunder with original 17 inch Boyd Coddington two piece JunkYard Dog rims.
They are similar to the 5 spokes you were looking at earlier. They are now reproduced as a one piece.
https://www.summitracing.com/search/...s?N=4294920356
  #37
Old 06-25-2017, 07:27 PM
AliceSML79's Avatar
Member
Twisted Wrench
Year: 1970
NECOA #: 80402
so the stock brakes with new pads and shoes work really good with the hydro boost huh. I found a OEM GM color called forest green I really like.
  #38
Old 06-28-2017, 07:47 AM
cquester5 cquester5 is offline
Year: 1969
Model: El Camino SS
Region: 6 (FL)
NECOA #: 56954
cquester5 will become famous soon enough
Garage
Here is my 1969 OEM color "Fathom Green"
Confucius say: It's OK to let a fool kiss you,
.......but, never let a kiss fool you!
My 1969 SS build thread
  #39
Old 07-14-2018, 03:14 PM
trifiver's Avatar
trifiver trifiver is offline
Torque Wrench
Year: 1972
Region: 13(TX)
NECOA #: 1670
trifiver will become famous soon enough
Here are a couple of pictures of my 72 Hydro Boost installation. Have not tried it. ElCo is still a project on jack stands. Big valve covers and a solid roller cam with low idle vacuum drove the decision.
  #40
Old 07-14-2018, 09:06 PM
Old Bear's Avatar
Site Contributor
Year: 1970
Region: 18(CA)
NECOA #: 38617
Garage
Larry
Thank you for adding good quality images to this thread.
Once you have had a chance to use it for a while in normal driving, it would be good to hear your thoughts.
Take A Kid To A Car Show
  #41
Old 07-15-2018, 10:50 AM
trifiver's Avatar
Torque Wrench
Year: 1972
Region: 13(TX)
NECOA #: 1670
I’m close to getting it running. But without doors, glass and front sheet metal, I’ll be limited to my drive way and the neighborhood if I dare!
  #42
Old 07-24-2018, 02:20 PM
trifiver's Avatar
Torque Wrench
Year: 1972
Region: 13(TX)
NECOA #: 1670
Update: I put power steering fluid in and turned the motor over with a remote starter switch to build some pressure and test for leaks. Bad leak! Turns out that the return fitting on the Hydro Boost had a crack. Took the unit out because the fitting threads broke off inside the unit. Got that out and ordered an eBay replacement but stainless instead of brass. Hopefully I will get it back in this weekend and try again for other leaks. Is it just me?
  #43
Old 07-24-2018, 02:53 PM
fauxrs fauxrs is offline
Year: 1966
Region: 18(CA)
NECOA #: 21184
fauxrs has a reputation beyond reputefauxrs has a reputation beyond repute
https://www.powerperformancenews.com...acuum-booster/
https://www.elcaminocentral.com/showthread.php?t=227858
PRO: cheaper than other aftermarket vacuum pumps, uses OEM componants, quiet, still works if motor stalls.
CONS: none I've experienced, we've installed this on two vehicles, its completely invisible.
  #44
Old 07-24-2018, 03:48 PM
Old Bear's Avatar
Site Contributor
Year: 1970
Region: 18(CA)
NECOA #: 38617
Garage
Larry
Your images don't show that part of the install. Were you using brass banjo A/N connectors? Is that what broke?
  #45
Old 07-28-2018, 07:35 AM
trifiver's Avatar
Torque Wrench
Year: 1972
Region: 13(TX)
NECOA #: 1670
It was the brass return fitting that came with the unit. I had adapted it to AN-6 using a union. The extra length probably acted as a lever and helped create a condition where if bumped the brass could crack and eventually break. The replacement will avoid the union as it has an AN/6 male. The little piece of threads on the top right is what broke. Second picture shows the new fitting in place.
Tags
brakes, hydraboost, hydratech, hydro bost, hydroboost
Quick Reply
Message:
Smilies
Options
Register Now
User Name:
Password:
Confirm Password:
Email Address
Email Address:
Log-in
You may post new threads
You may post replies
Manual Brake Conversion on a 1980 El Camino malibudave1978 Brake Systems 27 01-25-2017 02:03 PM
Moving a 4speed Hydro from a Camaro to Camino, Help! Joebobb9 Transmission & Drive line 6 02-06-2012 12:36 PM
74 El Camino Rear Disc brake conversion FrankJames Brake Systems 3 12-25-2008 10:11 PM
Needed!! Brake conversion kit for the rear. My car 1970. pez486 Brake Systems 2 11-27-2008 09:11 PM
Brake boost opinions? vrooom3440 Brake Systems 9 12-12-2004 07:33 PM
Powered by vBulletin® Version 3.8.8
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
