Conversion to Hydro Boost Brake System - 1970 El Camino - Page 4 - El Camino Central Forum : Chevrolet El Camino Forums
Go Back   El Camino Central Forum : Chevrolet El Camino Forums > Drivetrain & Performance > Brake Systems
  #46
Old 08-20-2018, 02:30 PM
elcaminoss69's Avatar
elcaminoss69 elcaminoss69 is offline
Torque Wrench
Name: el camino SS
Year: 1969
Model: El Camino SS
Region: 24(EUROPE)
NECOA #: 31017
elcaminoss69 will become famous soon enough
Garage
Hello all,
just a quick question about the return lines to the power steering pump.
Would it be possible and a good or bad idea to run the return line from the power steering pump to the original hose connection from the reservoir
and
for the return line from the hydro boost unit drill a hole into the reservoir and use a connection like this Name:  ATP-FTG-100_450.jpg
Size:  29.2 KB of course using a nut on the inside of the reservoir.
Just to stay away from the T-connection.
  #47
Old 08-20-2018, 03:49 PM
kolo kolo is offline
Member
Twisted Wrench
Name: Steve Kolodziejczak
Year: 1970
Model: El Camino SS
Region: 5 (NC,SC)
NECOA #: 65346
kolo will become famous soon enough
Garage
Thank you for the info and pictures
  #48
Old 08-20-2018, 11:25 PM
Old Bear's Avatar
Old Bear Old Bear is offline
Site Contributor
Name: Gale and his cats
Year: 1970
Region: 18(CA)
NECOA #: 38617
Old Bear has a reputation beyond reputeOld Bear has a reputation beyond repute
Garage
Quote:
Originally Posted by elcaminoss69 View Post
Hello all,
and
for the return line from the hydro boost unit drill a hole into the reservoir and use a connection like this Attachment 106734 of course using a nut on the inside of the reservoir.
Shear Performance modified the '70 Gen 1 pump by adding a second return line to the reservoir, converting to Shear Performance specially design AN fittings. I don't think they needed to modify the pump. They welded (possibly brazed) the fitting to the PS reservoir.
I'm not sure why they had a local company custom build that connector. Possibly they added something to reduce fluid aeration. They welded the fitting. I will ask them to see if they can clarify for us.
Take A Kid To A Car Show
  #49
Old 08-29-2018, 08:34 PM
Zx1truth's Avatar
Zx1truth Zx1truth is offline
Site Contributor
Torque Wrench
Year: 1969
Region: 18(CA)
NECOA #: 89086
Zx1truth will become famous soon enough
Hi guys....I just had Lee and Son in Fullerton Ca. install my CCP Hydrotech system on my 1969 El Camino and they did a awesome job!!! Lee and his son Jeff are kool guys and pay attention to detail. Lee said most people don't install the conversion correctly because the instructions are wrong!!!! He has done over 50 installs of this kit all successfully and was doing a 55 Chevy along with mine last week.
While he was doing it I had him install a 4 piston Wilwood front disc system on also. Very happy with the results! For those who are interested here is Lee's info.
Lee and Son
711 S. Harbor Blvd
Fullerton, Ca.
714)446-1295
Name:	master install.jpg
Name:	master hoses.jpg
  #50
Old 08-30-2018, 01:16 PM
Torque Wrench
Name: el camino SS
Year: 1969
Model: El Camino SS
Region: 24(EUROPE)
NECOA #: 31017
Garage
Hello Zx1truth
could you please post some pictures how the return line to the power steering pump reservoir was made.
Thanks.
  #51
Old 09-04-2018, 07:33 PM
Zx1truth's Avatar
Site Contributor
Torque Wrench
Year: 1969
Region: 18(CA)
NECOA #: 89086
Hello Zx1truth
Thanks.
OK........on the first top pic the non braided line is the non pressure return line tee'd into the non pressure side of the pump line. It works flawlessly. Lee said the instructions said to pump it to a pressurized line......NOT!
Hope these help.
Name:	pump and PS lines.jpg
Name:	pump hoses.jpg
  #52
Old 09-09-2018, 12:28 PM
Torque Wrench
Name: el camino SS
Year: 1969
Model: El Camino SS
Region: 24(EUROPE)
NECOA #: 31017
Garage
Hello Zx1truth,
thank you very much for the pictures. Looks very good.
One more question how is you breaking now.
  #53
Old 09-09-2018, 07:13 PM
Zx1truth's Avatar
Site Contributor
Torque Wrench
Year: 1969
Region: 18(CA)
NECOA #: 89086
Hello Zx1truth,
It is a freaking awesome system. Stops on a dime and gives you change! LOL!!! I could not be happier to say the least!
  #54
Old 09-10-2018, 08:10 PM
pitts64's Avatar
pitts64 pitts64 is offline
Year: 1969
Model: El Camino SS
Region: 8 (OH,WV)
NECOA #: 19572
pitts64 is a glorious beacon of light
Garage
Wow!!! Thank you for shearing your build with us!! My 3500 Chevy work truck has hydro boost and its fantastic!!
  #55
Old 11-19-2018, 01:19 PM
Old Bear's Avatar
Site Contributor
Year: 1970
Region: 18(CA)
NECOA #: 38617
Garage
I mentioned that the hardware kit included a clevis that provided the ability to adjust the distance before the brake pedal started to engage the brakes.
After the install, my brakes were dragging just a little. Before heading home, Justin had showed me how to adjust the pedal clevis assembly.
To orient you to the image below, turn upside down looking up into the area behind the dash board. Put the top of your head against the rubber brake pedal.
You can loosen the locking nut and remove the clevis pin. Turn the clevis on the adjustor rod to lengthen or shorten the distance. Put the pin back and secure it. Tighten the adjustor lock nut. Test them out.
  #56
Old 10-29-2019, 06:14 PM
rushgator's Avatar
rushgator rushgator is offline
Ministry of Broke Things
Year: 1972
Region: 13(TX)
NECOA #: 2834
rushgator is a name known to all
Garage
Gale,
This has been an awesome write up. I'm considering going hydro boost, at the recommendation of my mechanic. Just started the research today. So, since it's been a year since your last update on the subject, any new observations, etc.?
Also, it seems POL has some nice products at competitive pricing. https://www.performanceonline.com/hy...hevy-chevelle/ Any thoughts on them, pro or con?
1972 El Camino, 1986 El Camino, 1972 Chevelle, 1957 BelAir, 2009 Pontiac G8 GT
"Wind-In my hair-Shifting and drifting-Mechanical music-Adrenalin surge"--Rush, Red Barchetta
  #57
Old 10-29-2019, 07:42 PM
Old Bear's Avatar
Site Contributor
Year: 1970
Region: 18(CA)
NECOA #: 38617
Garage
Three part answer.
This is a 50 year old vehicle, so I am OK to drive in the slow lane. Fwy lanes had been repainted and the car that was merging onto fwy, no longer could go straight like they could 10 days earlier. I needed to do a panic stop in the slow lane from 60 down to 20 with a semi tractor on my right. Locked all 4 tires and straight as could be until the trailer tires went passed me. The hydraboost applied the pressure. However stopping straight goes to Sheer Performance for adjusting the rest of the brake system well for me.
DStinch and FauxRS use electric vacuum assist and are happy with their solutions. See their comments above. May be less $. Check FauxRS post for his good links.
I did look at POL Performance Online.
Check post #18.
Notes:
Hydrtech had new Bosch units, where POL is rebuilding units.
Hydratech has a billet firewall bracket.
Hydratech hardware kit with hose looks to have additional parts.
POL may save some you some $.
  #58
Old 11-07-2019, 01:15 PM
Torque Wrench
Name: el camino SS
Year: 1969
Model: El Camino SS
Region: 24(EUROPE)
NECOA #: 31017
Garage
@rushgator and all others,
sorry for not giving a feedback on my rebuild. And my English writing.
First of all the braking is "einfach nur geil".
You really have to look at your mirror that the car behind you is not to near before you step on the paddle because never ever they are expecting that an old car can stop on a very short distance.
I am more than happy that I did spend the money for this rebuild.
So where did buy the system and why?
First I did look on the internet and yes you can get the unit on e-bay and from some
tuning shops.
But it is not only the unit you need hoses, fittings and some other parts.
Because I had to get the system over to Germany so I was looking for a complete set
and here "Old Bear" did mention the company "hydratechbraking".
So I did visit their website and did call them they were very helpful did answers all my questions even the stupid ones.
So I did sleep on night and the next day I did order the system from hydratechbraking.
1964 - 1972 General Motors 'A' Body Hydraulic Brake Assist Unit - Model # 3014
Some weeks later I did get a nice black box.
Did open it and was very pleased how nice the parts were packed.
Then I did start with the installation and what should I say it was going just fine.
The instructions are very good and will guide you through the installation.
And if something is not clear believe it or not you can call them even after you did buy the system and they will help you out.
It might by that you will not need the help because you can ask other people in you area and the chances to get the right answers will be much higher than here were I am in Germany were every shop tells you yes we can fix it and then you pay a lot money and when you have your car back it is sometimes even worse.
I would say spend some more money and get a rebuild kit which is really plug and play.
And not were you have to walk on a Sunday to AutoZone because some fittings are missing.
Will see to get some pictures made on the weekend.
  #59
Old 11-07-2019, 08:06 PM
Old Bear's Avatar
Site Contributor
Year: 1970
Region: 18(CA)
NECOA #: 38617
Garage
Glad the hydroboost brake system worked well for you.
Looking forward to the images of your installation.
www.HydraTechbraking.com is my thoughts for best full kit if you have limitations on putting a kit together.
I have heard that Paul has also assembled a good Customer Support Team.
Tags
brakes, hydraboost, hydratech, hydro bost, hydroboost
Quick Reply
Message:
Smilies
Options
Register Now
User Name:
Password:
Confirm Password:
Email Address
Email Address:
Log-in
You may post new threads
You may post replies
Manual Brake Conversion on a 1980 El Camino malibudave1978 Brake Systems 27 01-25-2017 02:03 PM
Moving a 4speed Hydro from a Camaro to Camino, Help! Joebobb9 Transmission & Drive line 6 02-06-2012 12:36 PM
74 El Camino Rear Disc brake conversion FrankJames Brake Systems 3 12-25-2008 10:11 PM
Needed!! Brake conversion kit for the rear. My car 1970. pez486 Brake Systems 2 11-27-2008 09:11 PM
Brake boost opinions? vrooom3440 Brake Systems 9 12-12-2004 07:33 PM
Powered by vBulletin® Version 3.8.8
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
