What have you done to your El Camino today! - Page 225 - El Camino Central Forum : Chevrolet El Camino Forums
Notices
Go Back   El Camino Central Forum : Chevrolet El Camino Forums > General Topics > Site Topics
  #3361
Old 02-11-2018, 07:06 AM
Menatour's Avatar
Menatour Menatour is offline
Torque Wrench
Name: Archie Fitzgerald
Year: 1978
Model: El Camino SS
Region: 7 (AL,GA,TN)
NECOA #: 84074
Menatour will become famous soon enough
Garage
Good morning all,
I replaced column yesterday, mind you the 85 monte carlo column was no fun changing all the crap out to make it work.
But, its all in and working!!!
Today I am hoping to swap out the steering box over to the fast ratio unit.
Discovered the plastic timing chain cover of the vortec variety is leaking, again (POS).
Menatour
"Drive Fast and Take Chances"
  #3362
Old 02-11-2018, 07:08 AM
Drycreek Drycreek is offline
Year: 1985
Model: Caballero
NECOA #: 32017
Drycreek will become famous soon enough
Quote:
Originally Posted by bbailey_33 View Post
that is amazing, nice work
  #3363
Old 02-12-2018, 03:04 PM
78 Elk's Avatar
78 Elk 78 Elk is offline
Year: 1978
Region: 19(AK,ID,OR,WA)
NECOA #: 3102
78 Elk is a name known to all
Garage
Gluing the plastic to the inside of the dash behind the E Brake handle wasn't going to work. I finally figured out a way to stop the handle from pulling through the dash. I used a 1/64 body shim. I bent the top down to an L shape. Then trimmed 1/8 inch off each leg. This made a tight fit and the handle doesn't pull through the dash.
hagensen78
  #3364
Old 02-12-2018, 03:48 PM
1986Choo's Avatar
1986Choo 1986Choo is offline
Member
Loose Nut
Year: 1986
Region: 9 (IN,KY,MI)
NECOA #: 85850
1986Choo will become famous soon enough
Getting the brakes taken care of and collecting some estimates on paint and body work.
  #3365
Old 02-13-2018, 11:06 AM
78 Elk's Avatar
Year: 1978
NECOA #: 3102
Garage
When I installed the dash cap I couldn't get the four screws to line up with the holes on the firewall. So while I had it loose I drilled the holes out from the under side of the dashboard. It is now secured and only 2 holes to fix in the defroster vent.
  #3366
Old 02-13-2018, 05:45 PM
1986Choo's Avatar
Member
Loose Nut
Year: 1986
NECOA #: 85850
The same thing as yesterday, more quotes on paint and body.
  #3367
Old 02-14-2018, 03:29 PM
78 Elk's Avatar
Year: 1978
NECOA #: 3102
Garage
I broke the plastic studs for the speedometer, in my gauge cluster. So I am working on a replacement cluster housing. Am painting it with SEM light oak.
  #3368
Old 02-14-2018, 10:14 PM
Mr. Fin's Avatar
Mr. Fin Mr. Fin is offline
Deputy National Director Moderator
Year: 1959
Region: 18(CA)
NECOA #: 19689
Mr. Fin is a glorious beacon of light
Garage
Front Disc Brake Conversion.
Eckler's and others sell a disc brake conversion kit for the 59 Impala. They do not say it but it also works on any full size 59 Chevy. It took me a bit to get all the parts and then some additional time to tear everything down, clean everything up and install the kit.
Here is the good the bad and the ugly of the kit and the process. One great thing is that the kit comes with everything you need and step by step instructions. First time conversion pitfalls do happen and some of the instruction were misleading. The kit sets each front disc on a separate line and there is a coupler included to patch into the rear line. You do have to bend each of the lines and that is a bit complicated if the engine is in place. I had to remove the old front cross line and bend the new one in the middle to match the old line then feed the line into place and finish by bending the two ends to match. Otherwise there are to many bends to wrap it under and around the frame and engine.
The Disc brakes and brackets mounted in minutes with no issues. The instructions indicate that the toe will need to be adjusted in 3/8" on each side which was an easy adjustment to make.
The only issue with the kit is that it works fine as long as you do not have a generator and PS pump in tandem, like my 59 does. with this factory set up, I could not use the power booster. That was disappointing since I was hoping to have power disc brakes.
After everything was set up I made a newbie mistake and did not change the master push rod to the lower setting on the brake pedal. This caused the travel to be excessive and gave me a false sense that the master was bad. Once I moved the push rod to the lower pedal position, the brake pedal gave instance response.
Why add disc brakes in the first place on a vehicle that was not designed to have them? Safety. Drum brakes tend to fade when they get hot and increase the stopping distance. Discs, on the other hand retain effectiveness under the same conditions. So for all of you that had been thinking, "I sure would like to upgrade my Elky to disc brakes." go for it. This was my first attempt and for the most part, it bolted right up with minimal stress.
  #3369
Old 02-15-2018, 06:13 AM
Nicks 1984 elcamino's Avatar
Nicks 1984 elcamino Nicks 1984 elcamino is offline
Year: 1984
Region: 8 (OH,WV)
NECOA #: 23695
Nicks 1984 elcamino is a jewel in the rough
Garage
Put the battery charger on battery #2.
  #3370
Old 02-15-2018, 07:10 AM
t113's Avatar
t113 t113 is offline
Year: 1975
Model: El Camino Classic
Region: 14(AR,LA,MS)
NECOA #: 37746
t113 will become famous soon enough
Garage
Mine went back on full-time daily driver duty. (My '10 Chally decided she didn't like the oil ring in cylinder #2)
  #3371
Old 02-15-2018, 07:05 PM
78 Elk's Avatar
Year: 1978
NECOA #: 3102
Garage
Started reinstalling my refurbished gauge cluster today.
  #3372
Old 02-16-2018, 01:14 PM
78 Elk's Avatar
Year: 1978
NECOA #: 3102
Garage
Finished installing the refurbished gauge cluster. Next step checking out the steering column.
  #3373
Old 02-18-2018, 03:35 AM
Menatour's Avatar
Torque Wrench
Year: 1978
Model: El Camino SS
NECOA #: 84074
Garage
Quick Ratio Steering Box is in (YEAH).
Larger sway bar installed, Rear Sway Bar re-Installed, and should get the Gabriel Coil over shocks installed today. Everything seems to be moving and working properly.
  #3374
Old 02-18-2018, 01:58 PM
78 Elk's Avatar
Year: 1978
NECOA #: 3102
Garage
I found another Buick steering column in my collection of parts. I'm trying to clean up and repaint it. Then plan to install it.
  #3375
Old 02-20-2018, 10:27 AM
78 Elk's Avatar
Year: 1978
NECOA #: 3102
Garage
I installed the steering column yesterday.
Quick Reply
Message:
Smilies
Options
Register Now
User Name:
Password:
Confirm Password:
Email Address
Email Address:
Log-in
You may post new threads
You may post replies
Pollen be darned. Today is El Camino day! Elkiebob General BS Topics 17 04-14-2015 05:42 PM
Almost burned the El Camino down today! FWI Electrical Systems 2 07-20-2006 08:12 PM
Please help my el camino caught on fire today and burned blue81elcamino General BS Topics 12 06-07-2006 09:26 PM
Just bought my 1970 El Camino today! FWI General BS Topics 22 03-22-2006 06:34 PM
installed AIRLIFT 1000 in 85 El Camino today Tomahawke Suspension & Steering 7 03-13-2006 09:04 AM
Powered by vBulletin® Version 3.8.8
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
