What have you done to your El Camino today! - Page 270 - El Camino Central Forum : Chevrolet El Camino Forums
Notices
Go Back   El Camino Central Forum : Chevrolet El Camino Forums > General Topics > Site Topics
  #4036
Old 07-18-2019, 06:23 PM
Rick's Avatar
Rick Rick is offline
Year: 1972
Model: El Camino Classic
Region: 13(TX)
NECOA #: 149
Rick is a name known to all
Garage
Angry Ouch
Dropped it off at the paint shop to repair shopping cart damage.
Name:	20190715=5F_= 180230_1563232396433_001.jpg
Rick Schaefer
  #4037
Old 07-19-2019, 04:13 AM
123pugsy's Avatar
123pugsy 123pugsy is offline
Torque Wrench
Year: 1969
Region: 22(CANADA (Ontario and East)
NECOA #: 85874
123pugsy will become famous soon enough
Started tearing out the front drums. Springs and shocks tonight.
PUGSY
  #4038
Old 07-25-2019, 06:08 PM
78 Elk's Avatar
78 Elk 78 Elk is online now
Year: 1978
Region: 19(AK,ID,OR,WA)
NECOA #: 3102
78 Elk is a name known to all
Garage
I rerouted the cruise control wire from engine compartment to the transmission. Hope to drill hole through the firewall tomorrow.
hagensen78
  #4039
Old 07-25-2019, 06:48 PM
Russ Camino's Avatar
Russ Camino Russ Camino is offline
Torque Wrench
Year: 1985
Model: Conquista
Region: 3 (DE,NJ,PA)
NECOA #: 90036
Russ Camino will become famous soon enough
Garage
Cool Install Cowl Hood
Installed cowl hood hope to get it painted in the next week.
  #4040
Old 07-26-2019, 03:39 AM
123pugsy's Avatar
Torque Wrench
Year: 1969
NECOA #: 85874
Got the disc brakes, springs and shocks finished....a lot better now. I can practically let go of the steering wheel during a spirited stop.
  #4041
Old 07-26-2019, 05:47 AM
pitts64's Avatar
pitts64 pitts64 is online now
Year: 1969
Model: El Camino SS
Region: 8 (OH,WV)
NECOA #: 19572
pitts64 is a glorious beacon of light
Garage
Quote:
That's so nice coming from drums to disc.. I often forget how erratic the drums were, pulling to one side all the time..
I recently swapped to drilled and slotted rotors along with Porterfield pads, wow what a difference!!
  #4042
Old 07-26-2019, 06:11 AM
the road 1986 the road 1986 is offline
Torque Wrench
Year: 1986
Region: 8 (OH,WV)
NECOA #: 90640
the road 1986 will become famous soon enough
Changed out the stop light switch. The lights were working sporadically. Adjustment of the switch didn't help. Ohmed out erratically. Prices on the switch ranged from 6.87 to over 25.00. Easy fix.
  #4043
Old 07-26-2019, 08:07 AM
123pugsy's Avatar
Torque Wrench
Year: 1969
NECOA #: 85874
  #4044
Old 07-26-2019, 03:19 PM
crazywolfie crazywolfie is offline
Year: 1978
NECOA #: 81434
crazywolfie will become famous soon enough
swapped out the thermostat on the elcamino only to find out it already had a 180* thermostat in it. at least i was able to get the bolts out without breaking them and hopefully fixed the housing leak. i know the housing shouldn't need a gasket but i used one anyways. it has slowly been leaking on and off since i did the water pump.
78 elcamino 350 4bbl
81 dodge d150 318 670CFM Holley Street Avenger Carb
89 RamCharger 4x4 318/727/3.21 on 33's
93 ramcharger 2wd 318/518/3.55
  #4045
Old 07-26-2019, 03:56 PM
riatta riatta is offline
Year: 1985
Model: Conquista
Region: 13(TX)
NECOA #: 82218
riatta will become famous soon enough
Garage
Quote:
Nice where did you get it. I think that is next for me
  #4046
Old 07-26-2019, 05:49 PM
Torque Wrench
Year: 1985
Model: Conquista
NECOA #: 90036
Garage
Hello Got the hood from Lutty's Chevy Warehouse in
Cheswick Pa 15024 near my home. thanks
  #4047
Old 07-27-2019, 05:32 AM
jarhead's Avatar
jarhead jarhead is offline
Year: 1987
Region: 13(TX)
NECOA #: 11248
jarhead has a reputation beyond reputejarhead has a reputation beyond repute
Garage
The hood looks good painted semi-flat and then clear coated with satin. Keeps the glare from the sun down. Lots of cars have had flat black hoods from the factory and yours would too.
1987 El Camino,14 May 2017.. just turned over 635,000 miles. Engine never touched.. aka Pa's Car
Dang, I miss Ronald Reagan
more and more every day..
  #4048
Old 07-29-2019, 06:11 AM
any4xx any4xx is offline
Year: 1968
Model: El Camino SS
Region: 18(CA)
NECOA #: 88002
any4xx will become famous soon enough
Garage
Added a GPS speedometer module. Iíve got a new transmission and rear end coming for my car and will also be changing the rear tire size. Iím done playing with speedometer gears. I opted for the optional antenna and mounted it to the lower windshield trim at the rear of the right fender. It picked up the satellites immediately and works great. Nice for the tech-toy-type in me to also have elevation, compass heading, and outside temperature available to display. I also added a temperature module for a transmission temperature reading. Whenever I get around to adding cruise control Iíve got an easy speed output to tap now.
  #4049
Old 07-30-2019, 05:17 AM
pitts64's Avatar
Year: 1969
Model: El Camino SS
Region: 8 (OH,WV)
NECOA #: 19572
Garage
I've been working on adjusting the transmission modulator and got that good. I also tightened up the inner fender bolts to remove the rattles and squeaks.. Thinking about installing this Stereo 66 Reverb..
  #4050
Old 07-30-2019, 07:06 PM
donaldta's Avatar
donaldta donaldta is offline
Year: 1987
Model: El Camino SS
Region: 8 (OH,WV)
NECOA #: 10990
donaldta will become famous soon enough
Just gott'r back from two different shops. First a custom shop, got the headliner and sun visors all done, man they look nice. Then the mechanic for a complete front end rebuild. If it rattled, shake, bounced, rotated, squeaked, or turned, it got replaced! Now she feels like a new ride! And put in a new under hood insulation to finish off some badly needed TLC. I think she's ready for TX!
Quick Reply
Message:
Smilies
Options
Register Now
User Name:
Password:
Confirm Password:
Email Address
Email Address:
Postal Code
Required
Street Address
City
Your city or town
State or Province
Required
Location area within State
Country
Required
NECOA Region
Required
Year of Vehicle
Required
Make of Vehicle
Required
Model of Vehicle
Required
Real Name
Insurance
Log-in
You may post new threads
You may post replies
Pollen be darned. Today is El Camino day! Elkiebob General BS Topics 17 04-14-2015 05:42 PM
Almost burned the El Camino down today! FWI Electrical Systems 2 07-20-2006 08:12 PM
Please help my el camino caught on fire today and burned blue81elcamino General BS Topics 12 06-07-2006 09:26 PM
Just bought my 1970 El Camino today! FWI General BS Topics 22 03-22-2006 06:34 PM
installed AIRLIFT 1000 in 85 El Camino today Tomahawke Suspension & Steering 7 03-13-2006 09:04 AM
Powered by vBulletin® Version 3.8.8
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
