Moving a 4speed Hydro from a Camaro to Camino, Help! - El Camino Central Forum : Chevrolet El Camino Forums
Notices
Old 02-05-2012, 07:55 AM
Joebobb9 Joebobb9 is offline
Junior Member
Member
Year: 1979
Region: 6 (FL)
NECOA #: 21065
Joebobb9 will become famous soon enough
Default Moving a 4speed Hydro from a Camaro to Camino, Help!
I am currently using a th200 (metric) 3 speed in my '79 El Camino. My friend has a '79 Camaro with a th400 and want's to part with it, so here is my question: is there a way to install his floor shift pattern transmission to work on my column shift?
Thank you in advance!
Old 02-05-2012, 07:57 AM
Junior Member
Member
Year: 1979
Region: 6 (FL)
NECOA #: 21065
Don't know where "want's" came from....grammar fail
Old 02-05-2012, 10:25 AM
464elky's Avatar
464elky 464elky is offline
Year: 1984
Region: 6 (FL)
NECOA #: 8926
464elky has a reputation beyond repute464elky has a reputation beyond repute464elky has a reputation beyond repute
Garage
The th400 is also a 3 speed. If you are looking for overdrive you will need a 2004r or a 700r4.
Does his show the OD position? Maybe you have the transmissions confused as to model #.
84 Elky with 455 Stage 2 Buick, Tremec TKO600 5 speed, 8.5 3:23 posi 98 Acura CL custom upholstered seats, Dakota Digital Instrumentation-
Car Domain:
Another 3 to 9 years should finish it.
In year 10. Added FITech Fuel Injection. 40K miles and going strong.
Link to Garage:
Old 02-05-2012, 10:32 AM
theelcaminoman's Avatar
theelcaminoman theelcaminoman is offline
Year: 1980
Region: 10(IL,MN,WI)
NECOA #: 20262
theelcaminoman has a spectacular aura about
TH400s are definitly 3 speeds. And your engine prolly wont like turning all the extra heavy duty stuff inside a TH400. Your mpg will go down
1980 El Camino
305, 200-4R, open diff
CAUTION: WORK IN PROGRESS
2004 F-250 Harley-Davidson
V10, 4x4, Daily Driver
KIDS in the back seat may cause ACCIDENTS...
ACCIDENTS in the back seat may cause KIDS...
NO BACK SEAT = NO ACCIDENTS!
Old 02-05-2012, 11:07 AM
JJLT1's Avatar
JJLT1 JJLT1 is offline
Year: 1985
Model: El Camino SS
Region: 13(TX)
NECOA #: 12122
JJLT1 has a reputation beyond reputeJJLT1 has a reputation beyond reputeJJLT1 has a reputation beyond repute
Garage
http://www.maliburacing.com/auto_tranny_id.htm
JJ
Old 02-05-2012, 11:04 PM
TrannyMike's Avatar
TrannyMike TrannyMike is offline
TrannyMike
Year: 1985
Region: 18(CA)
NECOA #: 18805
TrannyMike has a reputation beyond reputeTrannyMike has a reputation beyond repute
Unless your friend did a conversion on his car it came with a 350. That would fit right into your car with only a few minor changes. If it's a 400 I'd pass on it. It's a strong trans but likes to eat up horsepower and takes some mods to the drive-line that require shortening it and converting the front u-joint and yoke. The crossmember needs to be changed too. There are few less costly changes also to make it fit. The best trans conversion is to a 200-4R. It costs more than a 350 but is worth it, and then I'd go with different rear end gears. Find out what it is first, then I can tell you in more detail what you'd need to do.
Mike
Old 02-06-2012, 12:36 PM
Junior Member
Member
Year: 1979
Region: 6 (FL)
NECOA #: 21065
It is more than likely a th200-4r, I will confirm this the next time I take a look at it. If that is the case, the conversion from the 200, I am assuming, should not be that difficult. I appreciate any advice on this matter and thank you all for actually being helpful unlike many other forums.
Quick Reply
Message:
Smilies
Options
Register Now
User Name:
Password:
Confirm Password:
Email Address
Email Address:
Log-in
You may post new threads
You may post replies
78-81 4speed jrbharley1 RPO Codes 8 05-16-2015 05:33 PM
will a 4speed tranny work on a lt1 87caballerokid LT1/LS1/EFI Tech 5 03-01-2012 08:16 PM
79 El Camino less engine/trans - moving, must sell jmhollis Parts for sale 9 06-02-2006 12:53 PM
T350 TO A 4SPEED ONELOWELCAMINO Transmission & Drive line 3 06-17-2004 09:40 PM
Info on my '79 4speed ????? BadBubba For New Forum Members Only 7 10-10-2003 09:39 PM
Powered by vBulletin® Version 3.8.8
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
