Replacing chrome trim 5th Gen El Camino door panel - El Camino Central Forum : Chevrolet El Camino Forums
Notices
Go Back   El Camino Central Forum : Chevrolet El Camino Forums > Body & Chassis > Interior Restoration
Old 10-31-2019, 11:33 AM
bazthespazz's Avatar
bazthespazz bazthespazz is offline
Torque Wrench
Year: 1984
Region: 19(AK,ID,OR,WA)
NECOA #: 20762
bazthespazz will become famous soon enough
Default Replacing chrome trim 5th Gen El Camino door panel
The chrome trim on the door panels of my '84 El Camino need to be replaced. I've found the chrome tape to replace the original but how do you get all the old stuff off so you've got a good smooth surface to work with?
Old 10-31-2019, 06:33 PM
the road 1986 the road 1986 is offline
Torque Wrench
Year: 1986
Region: 8 (OH,WV)
NECOA #: 90640
the road 1986 will become famous soon enough
I used a razor blade and goo-gone. Where did you find the new chrome tape at?
Old 11-01-2019, 04:36 AM
86_Caballero's Avatar
86_Caballero 86_Caballero is offline
Year: 1986
Model: Caballero
Region: 6 (FL)
NECOA #: 4902
86_Caballero has a spectacular aura about
Garage
This is one problem that frustrated me for years, and I may have found a solution. I tried a couple different "chrome tapes" only to find poor adhesion to the rubbery trim strip. I don't know if there are chemicals in that rubber piece or something else, but nothing I tried would remove it.
When I put in Dynamat kits I had some leftover Wenda tape. Not as shiny as the chrome stuff, but I figured it was better than nothing. Well, it sticks and holds.
So my solution was to use one layer of Wenda tape and then put on the chrome tape. Been holding for over 6 months.
I bought 1" wide chrome tape from Amazon which is a perfect width. Just have a steady hand. Any wrinkle in the Wenda tape will show in the chrome tape. You will need to cut the Wenda tape to 1 inch width.
86 Caballero Amarillo
85 Caballero Diablo
66,76,86 Corvette
01 Mustang GT
02 TransAm RamAir
14 Infinity QX50
Old 11-01-2019, 05:33 AM
2byoungagain 2byoungagain is offline
Member
Loose Nut
Name: Bruce L. DeHaven
Year: 1985
Model: Conquista
Region: 16(CO,MT,WY,UT)
NECOA #: 66153
2byoungagain has a spectacular aura about
I'm at the same place with my 85. I had good luck removing the old with a razor knife and sharp fingernails finished off with fine grit sandpaper. I was going to look for some chrome carbon fiber. Anyone have experience installing carbon fiber on the small plastic strips?
Old 11-01-2019, 10:39 AM
Torque Wrench
Year: 1984
NECOA #: 20762
The chrome tape I found was on Fleabay for under $10.00.
Old 11-01-2019, 10:56 AM
87next2last1's Avatar
87next2last1 87next2last1 is online now
Deputy Director Region 6 - Supporting Member Directors' Award Recipient
Year: 1987
Model: Conquista
Region: 6 (FL)
NECOA #: 16317
87next2last1 has a reputation beyond repute87next2last1 has a reputation beyond repute
Garage
I used this stuff & been on it for over 15 years & still looks great
https://www.ebay.com/itm/Chevrolet-M...QAAOSwdpxUYRVs
1987 EL Camino Conquista 4.3L
Old 11-01-2019, 12:55 PM
elcodude's Avatar
elcodude elcodude is offline
Year: 1978
Region: 18(CA)
NECOA #: 40969
elcodude has much to be proud of
Garage
This is what I did (took it a step farther) to replace the trim.
Post #22 Page 2 has an update with new pics of the process.
https://www.elcaminocentral.com/show...33#post1412433
Name:	Door Panel Trim  (20).jpg
  #8
Old 11-01-2019, 02:20 PM
LilBrownJug's Avatar
LilBrownJug LilBrownJug is offline
Senior Member Site Supporter
Name: Chuck and Jane
Year: 1983
NECOA #: 90002
LilBrownJug is on a distinguished road
Wife and I just removed all the shiny stuff, left the grey there. And it looks real good. But as a daily driver she's happy and if mamas happy leaver right there.
There are no rocks on the road,,, unless you are bare foot!
  #9
Old 11-01-2019, 02:57 PM
old goat's Avatar
old goat old goat is offline
Year: 1985
Model: Conquista
Region: 10(IL,MN,WI)
NECOA #: 23551
old goat has much to be proud of
Garage
Cool That's how mine are!
They show up as a light blue grey. But if I ever find the patience I do like the chrome look!
Old Goat
  #10
Old 11-01-2019, 04:11 PM
Year: 1987
Model: Conquista
Region: 6 (FL)
NECOA #: 16317
Garage
I painted the ones on my 84
  #11
Old 11-07-2019, 06:32 PM
Mosvold Mosvold is offline
Junior Member
Member
Year: 1985
Region: 14(AR,LA,MS)
NECOA #: 86346
Mosvold will become famous soon enough
What are those seats out of?! They look comfy and match well.
  #12
Old 11-07-2019, 07:26 PM
78 Elk's Avatar
78 Elk 78 Elk is online now
Year: 1978
NECOA #: 3102
78 Elk is a name known to all
Garage
Here is a picture of the panel we (wife and I) made using a strip from EBay. We used the glue that came with the strips.
hagensen78
  #13
Old 11-08-2019, 07:45 AM
BillyJack's Avatar
BillyJack BillyJack is offline
Year: 1987
Model: Conquista
Region: 3 (DE,NJ,PA)
NECOA #: 13628
BillyJack has a reputation beyond reputeBillyJack has a reputation beyond repute
Garage
I redid mine with some chrome tape I got from a local vendor who does striping & graphics for the local car dealers.
Careful prep work is the key. After removing the upper panels, I cleaned the old failing chrome to remove any residual vinyl dressings, then folded up a small pad of 220 sandpaper to dislodge any loose pieces, feather any edges and provide a good surface for the new material to bond. One more cleaning wipe with alcohol removed any remaining contaminants and sanding residual. The material I had was wider than the existing moldings, so I carefully laid the new self adhesive tape on the upper edge of the molding, pulling it tight enough to not have any bubbles or wrinkles, but not to stretch the tape, only to have it shrink it up later.
The corner had to be carefully miter cut with a sharp Xacto blade. Once I was satisfied with the look, I used a thin but soft rag to press everything down securely, then carefully trimmed the lower edge where it overlapped on the vinyl, cutting through the foil, but not into the vinyl. Reinstall the upper panel and admire your handiwork.
Don't have a picture, since I'm at work, but it's still looking good after 10 years.
Bill
  #14
Old 11-08-2019, 09:13 AM
greywolf's Avatar
greywolf greywolf is offline
Year: 1984
Region: 12(MO,OK,KS)
NECOA #: 64
greywolf is just really nice
Garage
My plan is to paint that plastic to match the exterior.
Keeping the Sport in SUV
  #15
Old 11-11-2019, 11:12 AM
ELClemente's Avatar
ELClemente ELClemente is offline
Member
Knuckle Buster
Year: 1978
Model: El Camino SS
NECOA #: 77521
ELClemente will become famous soon enough
Garage
had leather seat covers from "LSeat" installed and door panels wrapped left "chrome" trim off but had seam sewn into panel to mimick shape of trim strip
https://www.elcaminocentral.com/albu...ictureid=28754
Quick Reply
Message:
Smilies
Options
Register Now
User Name:
Password:
Confirm Password:
Email Address
Email Address:
Postal Code
Required
Street Address
City
Your city or town
State or Province
Required
Location area within State
Country
Required
NECOA Region
Required
Year of Vehicle
Required
Make of Vehicle
Required
Model of Vehicle
Required
Real Name
Insurance
Log-in
You may post new threads
You may post replies
Powered by vBulletin® Version 3.8.8
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
