Replacing a water pump. - El Camino Central Forum : Chevrolet El Camino Forums
Old 01-29-2015, 06:27 PM
olderndirt olderndirt is offline
Junior Member
NooB
Name: David Ronaldson
Year: 1983
Model: El Camino SS
Region: 19(AK,ID,OR,WA)
NECOA #: 12075
olderndirt will become famous soon enough
Default Replacing a water pump.
Replacing the water pump on my '83 El Camino 305 and have hit a stumbling block. The lower bolt on the right (driver) side of the pump is blocked by an adjustment slot on the steering pump bracket. I've loosened the pivot bolt, the aforementioned slot bolt and a bolt that allows adjustment on the air condition pump bracket. The steering pump will not budge - what am I missing? Do I have to remove it to get to the water pump bolt?
Old 01-29-2015, 06:39 PM
agoristmike's Avatar
agoristmike agoristmike is offline
Year: 1975
Region: 13(TX)
NECOA #: 23082
agoristmike will become famous soon enough
Garage
Any reason not to pull the PS pump off entirely?
"you don't have much money right now, so what money you have goes to
A. keep it running
B. make it run better/faster
C. safer
IN THAT ORDER!"
As spoken by Keyser sose.
Old 01-29-2015, 06:49 PM
JJLT1's Avatar
JJLT1 JJLT1 is offline
Year: 1985
Model: El Camino SS
Region: 13(TX)
NECOA #: 12122
JJLT1 has a reputation beyond reputeJJLT1 has a reputation beyond reputeJJLT1 has a reputation beyond repute
Garage
take the driver side bolt out of the PS pump,, then see if it will swing up out of the way..
sometimes you just gotta remove it..
JJ
Old 01-29-2015, 08:18 PM
p.ward7885's Avatar
p.ward7885 p.ward7885 is offline
Year: 1978
Region: 4 (MD,VA)
NECOA #: 12828
p.ward7885 has a spectacular aura about
Easiest way is to remove it. Just replaced my water pump last week.
Paul Ward
78 el camino
70 Buick GS
66 Toronado
Old 01-30-2015, 04:24 PM
Junior Member
NooB
Year: 1983
Model: El Camino SS
NECOA #: 12075
After applying some pressure with a #2 crowbar, was able to get a socket on the offending bolt. I had all? bolts remove from the steering pump but no lateral movement - something in the upper right rear was hanging on. Thanks for the responses.
Old 02-03-2015, 07:50 PM
El Diablo's Avatar
El Diablo El Diablo is offline
Year: 1973
Region: 16(CO,MT,WY,UT)
NECOA #: 12314
El Diablo will become famous soon enough
Your engine will notice the new pump.
Old's cool.
Old 02-03-2015, 08:09 PM
hotrodelco's Avatar
hotrodelco hotrodelco is offline
Year: 1981
Region: 13(TX)
NECOA #: 22020
hotrodelco has a reputation beyond reputehotrodelco has a reputation beyond repute
Garage
There is a hidden stud on the middle back of the pump, real hard to see and get to.
Once you go Rat, you never go back!
Guess what happens after your offended?
Nothing!
That's it!
Now be an adult and move on.
  #8
Old 02-03-2015, 11:18 PM
Year: 1975
Region: 9 (IN,KY,MI)
NECOA #: 13978
If I remember correctly, the mentioned stud has a nut on it, which can be reached by going across the rear of the pump. It's hard to see, but it's in there !
  #9
Old 11-04-2019, 01:48 PM
CCADAN's Avatar
CCADAN CCADAN is offline
Member
Twisted Wrench
Year: 1984
Model: Conquista
Region: 6 (FL)
NECOA #: 90346
CCADAN will become famous soon enough
Does anyone have picture of hidden nut on power steering pump, i can't get pump to budge.
  #10
Old 11-04-2019, 02:37 PM
JJLT1's Avatar
Year: 1985
Model: El Camino SS
Region: 13(TX)
NECOA #: 12122
Garage
think that's it,
top pic, down low just left of center..
2nd pic, bottom center..
Name:	ps header ac.jpg
  #11
Old 11-06-2019, 12:48 PM
CCADAN's Avatar
Member
Twisted Wrench
Year: 1984
Model: Conquista
Region: 6 (FL)
NECOA #: 90346
Thanks for pictures, I got it lose.
  #12
Old 11-08-2019, 08:45 AM
JJLT1's Avatar
Year: 1985
Model: El Camino SS
Region: 13(TX)
NECOA #: 12122
Garage
that one gets grimey and hard to see sometimes..
Quick Reply
Message:
Smilies
Options
Register Now
User Name:
Password:
Confirm Password:
Email Address
Email Address:
Log-in
You may post new threads
You may post replies
water pump carlfan Performance Modifications 6 07-07-2013 09:12 AM
Water Pump compmaker Engine Topics 10 06-17-2010 10:00 PM
Replacing wiper motor and pump caminosue Electrical Systems 3 05-09-2010 10:40 AM
water pump elka79 Engine Topics 2 11-07-2006 03:05 PM
water pump ? lowdown Engine Topics 1 03-07-2006 06:03 PM
Powered by vBulletin® Version 3.8.8
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
