quadrajet problems - El Camino Central Forum : Chevrolet El Camino Forums
Notices
Old 12-17-2011, 07:33 AM
Dave B. Dave B. is offline
Year: 1984
Region: 1 (NY)
NECOA #: 13406
Dave B. will become famous soon enough
Default quadrajet problems
Having idle problems with a 1984 El Camino 305 W/ a c.c.c quadrajet. I bought a rebuilt Carb. from Guaranteed carburetors out of Largo, Fla. I have returned carb. once & been advised carb. is fine & to check my linkage. If you start car & do`t rev. it up it idles @ 750 rpm. If you rev it up to 2000 rpm & let off it only idles down to 1200 rpm. With all linkage unhooked you can manually push on carb. & it goes to idle. With linkage hooked up ,you can bump accelerator pedal & car will idle.
Had car to my local garage & they discovered that if while car is idling @1200 rpm ,you shut car off you can see carb. relax. Seems like this would be a problem w/ vacuum holdig carb. partially open ??
I` m going to see if I have a diagram of where vacuum hoses go on carb. Anybody got any other suggestions ??
Dave B.
Old 12-17-2011, 08:06 AM
jarhead's Avatar
jarhead jarhead is offline
Year: 1987
Region: 13(TX)
NECOA #: 11248
jarhead has a reputation beyond reputejarhead has a reputation beyond repute
Garage
On my 87, the arm that connects the throttle to the cruise control was sticking at the cruise diaphram. I sprayed some carb cleaner on the linkage and its cleared up for now.
1987 El Camino,14 May 2017.. just turned over 635,000 miles. Engine never touched.. aka Pa's Car
Dang, I miss Ronald Reagan
more and more every day..
Old 12-17-2011, 08:13 AM
CANTED's Avatar
CANTED CANTED is offline
Year: 1970
Region: 6 (FL)
NECOA #: 6858
CANTED is just really nice
Does it have an A/C idle up solenoid?
Jim
Old 12-17-2011, 08:27 AM
Year: 1984
Region: 1 (NY)
NECOA #: 13406
Default quadrajet carb
Carb. has been checked w/ all linkages unhooked. Does have a/c solonoid, but had that moved aside also. Thank for replying. I` m still looking for vacuum digram, called a vacuum control information label. It`s supposed to be under hood, but after27 years it`s no longer there. anyone have one they can take a picture of ??
Dave B.
Old 12-17-2011, 08:43 AM
jarhead's Avatar
Year: 1987
Region: 13(TX)
NECOA #: 11248
Garage
my 87 still has one but not sure it would be compatible with the 84. Anyone on here know? it its the same i'll take one at lunch and post it..
Old 12-17-2011, 10:00 AM
Year: 1984
Region: 1 (NY)
NECOA #: 13406
Default quadrajet carb.
Thanks for checking. I don`t know if 87 would be the same. I found one for a 84 @ the El camino store & ordered it. They do list them for several different years though so they must be different. Hopefully diagram will help solve my problem.
Dave B.
Old 12-17-2011, 04:02 PM
Year: 1975
Region: 9 (IN,KY,MI)
NECOA #: 13978
If you have cruise control, you could remove the cable from the carb & try it that way. Has to be something simple going on there......
  #8
Old 12-17-2011, 08:28 PM
jarhead's Avatar
Year: 1987
Region: 13(TX)
NECOA #: 11248
Garage
Name:	2011-12-17 12.08.18-1.jpg
ID:	1782Here's the diagram form my 87. Hope it helps
  #9
Old 12-17-2011, 08:34 PM
jarhead's Avatar
Year: 1987
Region: 13(TX)
NECOA #: 11248
Garage
Attachment 1782Here's the diagram form my 87. Hope it helps
  #10
Old 12-18-2011, 05:24 PM
Year: 1984
Region: 1 (NY)
NECOA #: 13406
Default engine topics
Jarhead,
Thanks for the diagram, I don`t know if 87 &84 are the same. Iwill try it while I`m waiting for new one I ordered.
Dave B.
  #11
Old 12-18-2011, 07:33 PM
Skandolis's Avatar
Skandolis Skandolis is offline
Year: 1977
Region: 14(AR,LA,MS)
NECOA #: 19697
Skandolis has a spectacular aura about
i have alldata on my laptop, and i can't print it but it shows the exact same diagram for the 84 as the one jarhead posted GL
  #12
Old 12-18-2011, 07:37 PM
Skandolis's Avatar
Year: 1977
NECOA #: 19697
sorry too soon not quite the same, it also has a canister control valve and purge tvs on the t circuit of the 84
  #13
Old 12-18-2011, 08:26 PM
Skandolis's Avatar
Year: 1977
NECOA #: 19697
sorry for the multiple posts, finally figured out how to print the image, if anybody can delete my two previous posts that would be appreciated
  #14
Old 12-18-2011, 09:32 PM
Daddymav's Avatar
Daddymav Daddymav is offline
Member
Loose Nut
Year: 1979
Region: 15(AZ,MN)
NECOA #: 20556
Daddymav will become famous soon enough
Do you happen to have the vacuum routing for a '79 231 V6? I'm fighting to pass emissions and I'm not sure if all my hoses are set up right.
1979 El Camino 231 V6 AT (CA model)
Jerry was a race car driver, Drove so God darned fast.
Never won a checkered flag, but never came in last.
-Primus
  #15
Old 12-18-2011, 09:51 PM
87next2last1's Avatar
87next2last1 87next2last1 is offline
Deputy Director Region 6 - Supporting Member Directors' Award Recipient
Year: 1987
Model: Conquista
Region: 6 (FL)
NECOA #: 16317
87next2last1 has a reputation beyond repute87next2last1 has a reputation beyond repute
Garage
I found this !! Hope it helps !!
1987 EL Camino Conquista 4.3L
Quick Reply
Message:
Smilies
Options
Register Now
User Name:
Password:
Confirm Password:
Email Address
Email Address:
Postal Code
Required
Street Address
City
Your city or town
State or Province
Required
Location area within State
Country
Required
NECOA Region
Required
Year of Vehicle
Required
Make of Vehicle
Required
Model of Vehicle
Required
Real Name
Insurance
Log-in
You may post new threads
You may post replies
4160 Holley carb problems,off idle problems. crazymike67 Performance Modifications 8 03-06-2014 03:33 PM
84 305 Quadrajet texaselky Parts for sale 1 05-29-2008 09:00 PM
Rochester Quadrajet 4MV divorced Choke problems Marzullo_73 Engine Topics 2 08-07-2007 08:47 AM
quadrajet mod rod123 Performance Modifications 0 12-04-2004 06:59 AM
Rochester Quadrajet problems jez Engine Topics 10 11-22-2003 05:47 PM
Powered by vBulletin® Version 3.8.8
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
