Electric choke problem - Q-jet - El Camino Central Forum : Chevrolet El Camino Forums
Notices
Old 04-11-2012, 02:38 PM
Beepster's Avatar
Beepster Beepster is offline
Year: 1987
Model: El Camino SS
Region: 13(TX)
NECOA #: 20479
Beepster is a jewel in the rough
Default Electric choke problem - Q-jet
Got the new intake and Q-jet installed. Everything was fine, and choke was fine. Went for a haircut on Monday, she was busy, so was going to go home. Wouldn't start. Pulled cleaner, and choke was fully closed (flooded). Forced it open and put something in to wedge open so I could start it. That worked. Got home, pulled the blocking piece out, and choke fully engaged. No work on it yesterday (wife in hospital). Today, turned on the ign switch and tried to measure voltage on choke. No joy. The choke adjuster will adjust the flaps open, so it APPEARS the choke is OK, but then, I really don't know. This is a Mountain Man carb, so I have faith it's good. Where does the wire go from the choke? It appears to be light blue, and I traced it down to the crossing on the bell housing, but couldn't find a light blue wire coming on across to go into the cabin. Maybe I can backtrack from inside. Where does the wire (and color) end up to get the 12V to work the choke? For now, I'm leaving the choke fully open, as it will at least run that way.
Bruce
'87 Elkie: 350CID; 700r4; B&M shifter; buckets; AC; PS; PB; PW; PL; PM; Sony Blutooth; Kenwood rear spkrs.
'56 Chevy BelAir: 350CID; 5-spd Tremec; AC; PS
'10 VW Jetta: 2.5L, 5-cyl; 6-spd auto; AC; PS; PB; PW; PM; PL.
Old 04-11-2012, 02:50 PM
jpmdaddy's Avatar
jpmdaddy jpmdaddy is offline
Venerated Member RIP
Year: 1966
Region: 13(TX)
NECOA #: 20314
jpmdaddy is of outstanding character
if it is set up like my 82, there is an oil pressure switch just to the drivers side of the distributor. Power comes in from the fuse panel, there are 3 wires total, a brown one, a green one and the light blue one you are speaking of.
Purpose of oil pressure switch is to keep choke from engaging if there is no oil pressure. Don't fully understand how that is supposed to work, but my switch had leaked so much oil that the insulation on all 3 was cracked and exposed bare wire. The green and brown wires go back into harness and into the interior near the brake booster, light blue goes down into harness over the bell housing and then up to the choke.
Old 04-11-2012, 03:03 PM
Beepster's Avatar
Year: 1987
Model: El Camino SS
Region: 13(TX)
NECOA #: 20479
And, I be thankin' ya kindly fur da help. See ya at Belton!!!!!!
Old 04-11-2012, 03:05 PM
jpmdaddy's Avatar
Year: 1966
Region: 13(TX)
NECOA #: 20314
Welcome, but sorry, won't be making it to Belton
Year: 1975
Region: 9 (IN,KY,MI)
NECOA #: 13978
If there's a shorting problem in that blue wire, like from missing insulation/bare spot etc, maybe a fuse is blown (?) if there is one in that circuit....
So the engine has to be running to check for voltage on the blue choke wire, like jpmdaddy mentioned.
Of course the oil pressure switch itself can fail too, so if no voltage, OK fuse etc, it could be the pressure switch.
Old 04-11-2012, 03:59 PM
ccc's Avatar
ccc ccc is offline
Year: 1986
Model: El Camino SS
Region: 19(AK,ID,OR,WA)
NECOA #: 21252
ccc is a name known to all
the switch mentioned above controls the choke and oil lite you will get no voltage through it without oil pressure. you can bypass it one will be hot key on and the choke wire.connect them together.if the choke now works replace the pressure switch.i may be mistaken but i think it gets its power from the same fuse as the power locks. i worked on an 87 a couple years ago with the same issue
Old 04-11-2012, 05:03 PM
rnhart3's Avatar
rnhart3 rnhart3 is offline
Site Contributor
Year: 1979
Region: 2 (CT,MA,ME,NH,RI,VT)
NECOA #: 17856
rnhart3 will become famous soon enough
Garage
I think the fuse is marked C/H.........
Jim
1979 El Camino, retired daily-driver,
current frame-off resto project
1986 Monte SS, mild 350, headers, elec cooling
fan,"A" Pillar gauges, subtle
modifications to transmission, #3 son is a trans tech...
1986 Monte SS T-Tops, for parts...
1985 El Camino
1986 El Camino
1991 S10 pick-up
1997 Chevrolet Tahoe 2 dr.
1981 Malibu wagon with 9C1 drivetrain...parts?...or drive?
"Too many parts cars to mention....."
  #8
Old 04-12-2012, 12:58 PM
Beepster's Avatar
Year: 1987
Model: El Camino SS
Region: 13(TX)
NECOA #: 20479
This is what I have found: The oil circuit consists of a canister like a fuel filter with a post, and it has only ONE connection. There are no other wires there. I followed the schematic from the choke that wound thru connectors and wound up at a "heater choke relay" on the schematic. Unfortunately, I can't find anything like that under the hood. Since the emissions systems have been removed, that probably was too, and a connection made somehow to get voltage to the choke. I have additional "ign" outlets on the fuse panel, and I'm seriously considering just running a wire from one of them and connecting to the blue wire in the engine compartment. I checked my '56 this morning, and, as long as the ignition switch is on, 12V is applied, so what would be the difference in this case? The '56 has been rewired with proper wiring from AAW, and if that works, why shouldn't this work? Anyone got a better solution/suggestion????
  #9
Old 04-12-2012, 08:36 PM
Year: 1975
NECOA #: 13978
The oil pressure switch keeps the choke off if the ignition is on & engine not running. A scenario would be having the ign on (engine off) for a while, and the choke getting hot & open, and a cold engine that needs the choke etc when it gets started.
Mine is wired onto an IGN section of the fuse block, on my Malibu...been that way for years.
  #10
Old 04-13-2012, 05:42 AM
JJLT1's Avatar
JJLT1 JJLT1 is offline
Year: 1985
Model: El Camino SS
Region: 13(TX)
NECOA #: 12122
JJLT1 has a reputation beyond reputeJJLT1 has a reputation beyond reputeJJLT1 has a reputation beyond repute
Garage
may help
i cant see the diagram??
https://www.elcaminocentral.com/showthread.php?t=16801
JJ
  #11
Old 04-13-2012, 10:56 AM
ccc's Avatar
ccc ccc is offline
Year: 1986
Model: El Camino SS
NECOA #: 21252
look between the engine and firewall for a connector that looks just like the one on your ac dryer switch, it should be to the right of the dist.i just pulled the entire engine and wireing trom my 86 and will post you a pic of how the plug looks and where it is supposed to be it will take me a few so will return
  #12
Old 04-13-2012, 11:18 AM
ccc's Avatar
ccc ccc is offline
Year: 1986
Model: El Camino SS
NECOA #: 21252
  #13
Old 04-13-2012, 11:19 AM
ccc's Avatar
ccc ccc is offline
Year: 1986
Model: El Camino SS
NECOA #: 21252
  #14
ccc's Avatar
ccc ccc is offline
Year: 1986
Model: El Camino SS
NECOA #: 21252
  #15
Old 04-13-2012, 11:22 AM
ccc's Avatar
ccc ccc is offline
Year: 1986
Model: El Camino SS
NECOA #: 21252
the plug has a light green wire ,a dark gree/w white stripe and 2 brown w/white stripes wires
Quick Reply
Message:
Smilies
Options
Register Now
User Name:
Password:
Confirm Password:
Email Address
Email Address:
Log-in
You may post new threads
You may post replies
EGR, electric/manual choke, what? whiteshadow Performance Modifications 24 09-04-2010 08:43 AM
electric choke 74elko Electrical Systems 2 03-18-2008 11:01 PM
electric choke SKIDMARK Electrical Systems 3 07-16-2006 02:22 PM
Electric choke conversion Snaggle To0th Engine Topics 5 09-06-2005 02:11 AM
Manual choke or electric choke? eightysix Engine Topics 6 02-10-2004 10:29 AM
Powered by vBulletin® Version 3.8.8
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
