1 - 14 of 14 Posts
Here's a pic of a 120 MPH police speedometer I installed in my '78. You will also need the the hair spring. To be sure of accuracy I a had a speedo shop calibrate.
Here are the part numbers if you can still locate them
87 Choo Choo
Ooooo...purdy! Nice job and good information!
Question: If there's no key in the ignition and the speedo is at 0 mph, how can it be turning 1,400 rpm's? :lol:
Don't really know. It's been that way since day one. Now with the ignition on and engine not running it will go to 0. Engine at idle it reads about 650 rpm.
Super Moderator
What are in the two delco packages?
Small envelope is the hair spring for the 120 MPH speedometer. The box was for the 120MPH police instrument bezel. Those are the GM part numbers. Happy hunting for those interested.
What do you mean by "police" speedometer? Is it the same as the 120 speedo out of a MCSS or no? I found an 88 MCSS in local JY with 120 still in it 8O so i think I'll be picking that up perty soon!
The 79-83 Malibu 9C1 Police pursuit cars had a 120 MPH speedo with 2MPH increments.
:mrgreen:
The tachometer in my 86 MCSS and in my Elky never read zero when the engine is off. They seems to stay at whatever the RPM was when I turned off the engine.
:mrgreen:
thx Ernie... if im not mistaken theres also a difference in looks from that one to the MCSS version... I like this one more, but the MCSS one will match the rest of my guage cluster. Plus its easier to get a hold of.
That's right, the color and the font of the numbers are different. To match your 86 Elky you need the speedometer from a 86-88 MCSS.
:mrgreen:
if you notice his gauges are blue faced , the newer 1's are orange face
and if you notice also th newer are 115 not 120
if got the orig speedo from both cop cars long time ago , in the wrecking yards
also the monte SS tach in the newer 1's redine at 5500 not 5000
part #'s are no good.... sad, i really need a speedometer that goes past 85 seeing as how the rest of my car does. guess im off to the junkyard.
Director Region 13 (TX) Emeritus
there is a way to do it
If you want a speedometer that reads 115MPH the easy way to get it is take regular 85 MPH buy a appliqué from Lauren engineering install it and send the speedo of to have it calibrated. You can also change the face on all your instruments to white face and then have the speedo calibrated for about $40 or $50 bucks. It will cost you much less money than an original 115 MPH speedo, on e-bay they usually go for around $150 and more. Finding one in a junk yard would be pure luck. Harald
1 - 14 of 14 Posts
