Ok got something odd happening but dunno what to do or what it means. The outside temp has been rising but I've had other 80-90 deg days since this and not had a problem.
This is an 86 with a 305 new water pump, roughly 50/50 mix new thermo * high performance 160 deg. has huge opening. radiator and engine block have been tested for for leaks and clogs both hold up well. up until recently it's been hovering the 180-200 range and the 200 range is generally running around stoping here stoping there over and over. should this be happening?
I don't have any coolant on the dipstick after it's been sitting or after running. no oil floating in the coolant.
no white smoke coming out the back. either while getting on it or tenderly loving it.
I'm discombobulated as to what it is.
