B
blake22
·Guest
which is this?
yeah if you could measure the 22 for me that would be greaat. if i had a 17 gallon tank with a 22gal sending unit the gauge is going to read off right?I just measured the 17 gal tank I have in the garage. The filler neck is exactly 1" from the top of the tank. When I get a chance, I'll put the Elky on the lift and measure the 22" tank.
A 22 gal sending unit in a 17 gal tank will not read full. It will read empty properly. Between empty and full, you will always have slightly less in the tank than is showing on the gauge. For example, when the tank is 1/2 full, the gauge will show about .4 full ( 77% ratio). When you are approaching empty, it will get closer to accurate.yeah if you could measure the 22 for me that would be greaat. if i had a 17 gallon tank with a 22gal sending unit the gauge is going to read off right?
