1 - 3 of 3 Posts
1965 factory A/C. Wiring diagram has a B/OR from firewall plug to blower motor. Was this wire just clipped at factory when vehicle had A/C? Two different diagrams for the A/C, Two different types? Wiring at that point is pretty bad. Any help would be greatly appreciated.
welcome Chris
with or w/o AC it would still have the blower wiring for the heater..
whats it doing or not doing??
do you have a meter or test light ??
is it getting power to the switch and/or motor??
check the ground connections on/from the motor..
found some online diagrams, but not much more help than this 1
https://www.elcaminocentral.com/d2/articles/wiring/652.gif
:texas:
I have the factory assembly manuals and wire diagrams. Without A/C the Black/orange stripe (from the firewall plug) goes to the blower. With A/C it is a purple wire. They do show a green coming from the passenger side as clipped when it has A/C. Right now only low/medium speed, have a new relay coming. I can't just "make it work", i need it back to original. At this time i have to assume that the Black/orange stripe is clipped also, just that the assembly manual doesn't indicate that.
1 - 3 of 3 Posts
