So here are the photos after install of the Mechman 170 amp alternator.
After installing the Mechman I fired up the car and before adding any accessories this is what I got, 14.6v.
USB voltmeter is about the same.
DD cluster shows about 14v.
With AC and headlights off and radio off at idle I get a nice 14.2v on the USB display.
DD cluster shows about 13v which is consistent for being a little lower.
Back to the battery with everything above mentioned, running at idle.
Now for the Charge Path Test. It is a tiny bit better, but overall still a fail.
DD and Edlebrock are reading about the same.
So, here are the Mechman instructions for performing a Charge Path and Ground Path test. It is important to note that the text box corresponds to the photo on the side of it, not bewlow or above it.
So, I am going for a long drive tomorrow and a car show on Sunday. This will be another nice opportunity for a test.
Overall I am happy with the startup performance. The road test will help alot.
I plan to install a large 4 gauge wire from the Alternator to the battery tomorrow and will leave the existing 10 gauge wire in place that connects to the junction splice. This was the recommended strategy and wire size according to Mechman. I will retest the Charge and Ground paths tomorrow after the wire upgrade. It would be nice if I can reduce that Charge Path test to below 0.1v.
