1 - 3 of 3 Posts
· Senior Member
On my 72 gmc sprint there is the regular fuel line coming out of the sending unit but on the upper corners of the tank are seperate fuel lines going to a black box mounted on the box rail about the tank that has a line going to the charcoal cannister , all replacement tanks do not have the black box and no other el camino that I have seen has this set up . Has anyone seen the same set up or have knowledge what the black box may be ? I would think it is a filter of some form .
· Master Wrench
not sure, ill crawl under mine tomorrow to see if i can find anything similar, 70 and 72 are both 3rd gens so theres a good chance they have the same set up. can you get a pic of it?
· Senior Member
I have it all bolted back up , so pictures aren't possible , if your sending unit has two fuel lines coming from it then you have the other style with no black box. The one i have has two lines,one at each front corner for venting and only one line emerging from the sending unit for fuel pick up. I am trying to figure if it is a gmc thing or if its a calfornia emissions thing. I have had other 3 gen elkys and chevelles and do not recall seeing this set up before.
1 - 3 of 3 Posts
