1 - 3 of 3 Posts
The original spindles are starting to wear and I'll like to find a factory replacement instead on 2" drop.
it says
Reconditioned stock spindle. Includes castle nut and washer.
73-77 MIDSIZE 69$ ea
1973-77 Intermediate GM Spindle, Right
1973-77 Intermediate GM Spindle, Left
Reconditioned 1973-1977 intermediate GM spindles. Uses the larger bearings.
1973-1977 Midsize GM
1970-1978 Camaro
notes say
Verified Reply - Eric Yes this will fit a 1976 Monte Carlo.
Verified Reply - Eric Yes these spindles can be used on a 1975 Chevelle stub.
You will need to use the outer bearing and race set that comes with this spindle.
These are for an 11" rotor.
get the casting numbers off them right and left, and post up here
so we can do a search...
I was going to recommend these yesterday. However, if you look in the upper right hand corner, both left and right hand sides are on back order.
Regards Brian
1 - 3 of 3 Posts
