So what do you do when your El Camino project car is going too slow? Buy another one! It will be four years next December that I've been working on my 1979. Due to scope creep it has become a complete rebuild. All the bodywork is done, all the rust removed, matte blue paint laid on it, and the LS/4L60E fitted. But all the details are dragging on. Every interior piece is new, door glass, seats, etc, etc, and it's taking a while to assemble it all. After I spent two weeks building ducts for the Nostalgia Air unit I had enough, and looked on Facebook market place to find this:
I found it near Tampa, with a 2000 Silverado engine already swapped in. It also had a 4L60E that "just need to be wired" ha ha. But the price was right and the engine was strong. It has a lot of rust on doors, quarters, rockers, but it's mostly solid. Just like the last one I got, it was living in a trailer park. We dragged it home and I cleaned it and pressure washed it.
I quickly figured out the trans had a bad pump, so I pulled it and had the pump replaced. It also really did need some different wiring to the trans, so I got that done. It had no exhaust other than truck exhaust manifolds, so I did some internet shopping and built an exhaust for it.
I put Flowmaster 50s on it, but it looks like I don't have a picture. I also had to notch the aftermarket crossmember, but no photos, since it looks like my iPhone is taking all the pictures in HEIC format(?)
There were lots of other fixes. One of the brake lines was rusted through, and a couple fuel lines, so I got new ones made and put them in. The master cylinder was stuck. Finally I was able to drive it around the block, but the trans wouldn't shift. I downloaded TunerPro and PCM Hammer, and figured out that it had a tune for a manual transmission, so there was no programming to control the trans. I found a file for a 2000 Silverado with an auto and loaded that, and the trans started shifting.
I had to get a driveshaft made. The driveshaft that was in there someone had welded the u-joints to the yoke, so I replaced that. The radiator was this useless aluminum thing with a couple small fans, so I "borrowed" the F-body radiator and fans from the long-term project, and made a wiring harness with relays for the fans. The AC blower moved air, but only out the defrost vents, so I added a vacuum port to the intake manifold and hooked it to the AC, and that got air coming out the vents. The lack of AC hoses still meant no AC, though.
The battery was behind the drivers seat, so I moved it back under the hood. The PCM was stuck inside the air filter box, so I put in an S-10 coolant tank with PCM mount on the top. I put together a simple cold air intake. It was still pretty messy, but at least it worked.
The serpentine belt was rubbing on one of the radiator hoses, so I got an idler relocation kit off Amazon and fixed that. There was only one fuse in the fuse block so I went through that and replaced fuses as necessary and fixed wiring. Finally I could drive it around the neighborhood, but I still didn't trust it. The tires were dry rotted, so I "borrowed" the ones off the project car. I had to roll the rear fenders to make them fit, and they still rub some.
The pinion seal leaked, so I replaced it. The suspension creaked and swayed, so I put in poly bushings up front, and replaced the ball joints and sway bar bushings and all the tie rod ends and steering components. That helped a lot, but the steering was still really loose.
After looking on this forum I found a write-up on how to tighten the tilt steering, and that really transformed the car.
Now I can drive the car with a little more energy, and it's fun. I can't get to crazy, because the tires rub in the rear on bumps, and in the front when I turn hard in reverse. Here's a bad picture of how it looks now. It's storming here now, and I didn't want to take it outside for a photo.
There still a lot of things to be done. Today I got a box in the mail with lowering springs, shocks, and big sway bars for front and rear, so those will be going on. I'll put on aftermarket adjustable rear trailing arms with poly bushings. After that it's time for new wheels and tires to stop the rub. I'm thinking 18x8 wheels with 4.5" backspacing.
It needs wiring from the trans position switch, so I can keep the starter from working except in park and neutral, make the backup lights work and tell the PCM when the car is in park or neutral.
I want to get all three AC hoses made and replace the compressor and accumulator so I can have AC before it gets hot in south Florida again.
The headlights are dim, the wipers need replacing, the washer fluid bottle is cracked, there's no speakers for the radio.
The big problem is that the rear window leaks. Just like the other project, it's rusted around the window. On that one I had the window removed and the body guy cut out all the rust and fabricated new sheet metal. I sort of like the patina on this one, so I'm wondering if I can just pump a bunch of caulk in there. If not, I'll have the body guy remove the window and fix the rust. But that will require removing the interior, which means that I'll want to fix the holes in the floor, and put down sound deadening, and maybe put in mounts for bucket seats, and while I'm in there I can replace the carpet, and do a few more things. That's what happened with the other project, and why it's been under construction for almost four years. I just want to drive this one, but I don't want it full of water, so I guess I need to fix it.
Also I was looking at Vortech superchargers on Amazon. Those things are cheap! And it looks like they just bolt in.
