K....pick on the new guy....But again..why I'm not a big fan of HANES/Chiltons....Please read and analyse..."with the engine running, connect the terminal in this connector to a good chassis ground. When the diagnostic terminal is grounded with the key on , engine off, the ECM will display a "code 12" by flashing the check engine light. A code 12 is simply one flash, followed by a brief"..WITH ENGINE RUNNING...ENGINE OFF...???? I understand the whole idea of the one flash/2 flash, and I understand grounding the diagnostic terminal. I did this and I had no light of any sort flashing. That is why I asked if someone could confirm in a '80 CA 305 might be. What I've been able to figure out is that the C4 system, unlike the CCC system has no retentitve memory. ie: every time the key is turned off, any code clears...So simple logic would be why would there be a SES/check engine light, regardless of what Chiltons/Haynes prints. Evidently you can jumper the orange wire on the ECM to the battery and it will retain a code, but again this is what the Chilton's manual sez, but something about running 12 volts into the ECM, I'd rather have someone with practical knowlege confirm that makes sense. I know I had a good ground and I could hear what I assume is the solenoid in the carb cycling...just no light...Not trying to rub anyone the wrong way, and I'll freely admit I'm the stupid one here. I have an '80 CA 305 Corvette WITH the CCC /SES light so I thought I knew what I was getting into. Talk about stupid dripping from me...now I've got 2 '80 urchins. Not a fan of the General at this point....:???:
