1 - 20 of 33 Posts
Tried searching but there seems to be so much out there but couldn't find anything related to a 2nd gear problem - 1981 El Camino V6 Auto- all stock and runs nice except for a new trans issue. It will not shift out of 2nd into third- 1st to 2nd is good but that's it. I did manage to get it to shift once after pumping the throttle real quick when it was running at a higher rpm in 2nd gear- trans oil is clean and comes to the mark when hot. I've always had manual trans in all my vehicles so this is new to me. I apologize if this might be a repeat question but I appreciate any heads up or starting points. 馃憤
Thanks, headed home now. Hopefully able to get under it this evening. Is the TV cable easy to adjust?
It adjusts at the carb. I don't remember exactly, I think there is a clip to pull and then open throttle wide open and re-set clip. Hopefully everything is good, the cable can actually get brittle and come off, had that happen on a 77 Malibu once. Good luck!
Discussion Starter #9
Thanks! On a vehicle that's almost 40 yrs old it wouldn't surprise me. Shifted great until recently and happend right out of the blue
Discussion Starter #13
I was hoping that was it..
That's what's weird, the pan is square with the front right corner (front passenger) is at an angle. Only like pan 2 and three. I'll get back under again and try to count the bolts.
There was another transmission called a TH350C.
I did a search and see it referred in threads for some 1981 models.
I am not sure if it had a throttle body cable.
Max, I may be confusing easily tonight. It happens some times.
I will ping a couple of the 5th Gen folks to verify if cable in your image is throttle body or downshift cable.
I think all three have knowledge of the 350 vs 350C
@464elky @JJLT1 @darbysan
Discussion Starter #17
No worries, I appreciate your input on it! Look forward to hopefully figuring this out- thanks again
Discussion Starter #19
Awesome great spot! I didn't even notice it- partly because the car is so low and I had to reach under to take pictures. Hopefully that cause majority of the problems. Is that a special hose/boot or can any hose work as a replacement?
1 - 20 of 33 Posts
